Old Jan 20, 2013, 08:13 PM
kd8x is offline
Find More Posts by kd8x
United States, NC, Concord
Joined Jun 2011
Walbro WT645 carb rebuild problem
Hey guys -- scratching my head trying to figure out what is up with this Walbro carb that I have rebuilt. It had been used probably 3 years on my G26 Zenoah with electronic ignition. Then this season it just wouldn't start my G26. seemed like it wasn't putting gas into the cylinder and couldn't see any gas coming through the input line to the carb (no drawal or suction)...put a new carb kit in it figuring that it was just gummed up with old gas....got it back together and go to prop the plane over and it is just flooding out the plane after only 4 to 5 props..gas dripping out of carb etc. removal of spark plug and an ounce of gas comes out....I even replaced the metering valves and jet and the adjustment looks right on.. I'm pretty sure that all diaphrams are positioned correctly. I used carb cleaner with the straw to "jet" out all ports so I think it is all clean. Replaced both screens, welch plugs etc...I just have no other ideas what could be wrong. Got tired of foolin with it and ordered a brand new carb and put it on plane and the plane fires right up....The old carb is not metering properly for some unknown reason. I hate to throw the thing away and really scratching my head on this one...Any ideas???
kd8x is offline Find More Posts by kd8x
Old Jan 20, 2013, 08:57 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have had a problem like that. In my case the pivot lever was bent down slightly causing it to not let the fuel inlet valve close off the fuel. The regulator diaphragm had also been a problem on another carb. The diaphragm had sort of stretched out over time and wouldn't put pressure on the pivot arm anymore.
earlwb is online now Find More Posts by earlwb
Old Jan 21, 2013, 08:20 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
http://wem.walbro.com/distributors/s...s/WTseries.pdf
GeoffinIN is offline Find More Posts by GeoffinIN
Old Jan 21, 2013, 09:25 PM
miltac is offline
Find More Posts by miltac
miltac's Avatar
United States, NC, New Bern
Joined Dec 2011
sounds like the regulator needle isn't closing all the way. may have some gunk stuck on the seat.
also on the regulator side the thick gasket goes on first then the regulator diaphragm. if you have it the other way around it may be opening up the regulator to much to early.
miltac is offline Find More Posts by miltac
Old Jan 26, 2013, 09:46 PM
kd8x is offline
Joined Jun 2011
yep I am aware of that and do have the diaphram and gasket in proper order but yes you are right about the reverse order and what that would do as far as lever movement being off....thanks for the reply guys...the gunked jet seat could be something that I may need to think about more and do a more thourgh cleaning...maybe check the lever for being bent or out of spec.
Old Jan 27, 2013, 07:26 AM
Two left thumbs
Muncie, IN
Joined Sep 2006
It is not rare to have a stuck check valve in the high speed discharge nozzle. Take the time to read the Walbro service manual posted above so you can understand the flow of fuel in your carb. Note the little disc inside the nozzle #19 on the diagram on page 2.
Old Jan 28, 2013, 11:47 AM
kenh3497 is offline
Find More Posts by kenh3497
Comfortably Numb
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Also, on these carbs do not used compressed air to blow then out. And, do not use carb and choke cleaner. It is too aggressive. I do use brake parts cleaner though.
The brake parts cleaner and no compressed air is a recommendation from our Stihl service trainer. I'm thinking he has seen many more issues than all of us put together and should know what he is talking about.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Jan 28, 2013, 02:44 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Ken
You talking about Eddie in Virginia Beach?
I've had good luck soaking carbs overnight in Sea Foam. Saved one that way today on an old FS 80. Better yet, an ultrasonic cleaner is the ticket. Sea Foam in an ultrasonic will unstick whatever's stuck if it can be unstuck!
Old Jan 28, 2013, 09:01 PM
kenh3497 is offline
Comfortably Numb
kenh3497's Avatar
Joined Jul 2011
Nope, Rick at Mississippi Valley. Never thought about Seam Foam as a cleaner and you are right about the Ultrasonic cleaner. They are the ticket for any cleaning job!!!
Ken
For Sale Throttle and Choke arms for Gas Engine Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 13, 2013 06:56 PM
Mini-HowTo Rebuilding Walbro Carb ognolman Engines 3 Dec 31, 2012 07:16 PM
Wanted WTB A rebuild kit for walbro carb ATCH Aircraft - Fuel - Engines and Accessories (FS/W) 4 Nov 28, 2011 10:55 PM
Help! WALBRO carb problems....ideas welcome. RCBOB Engines 8 Jul 01, 2010 08:13 PM
