Old Jan 20, 2013, 05:05 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Question
Do good Hitec HS-82mg servos sound like this?
Hi! I put these Hitec HS-82mg servos on my E-flite Pitts Model 12 and the video shows what they sound like? Is this normal? Thanks for all advice!
Servo Chatter - R/C aircraft servos (0 min 16 sec)
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 21, 2013, 02:17 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Difficult to tell because I can make them more noisy by turning up the volume on the video
Seriously, mine sometimes sound a bit like that, but the buzzing indicates that they're encountering some resistance. How stiff is that control surface with the servo linkage disconnected from it?
abenn is offline Find More Posts by abenn
Old Jan 21, 2013, 04:42 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
It's pretty stiff. I'll disconnect and see if they are still that noisy.
Old Jan 21, 2013, 04:57 AM
abenn is offline
Joined Jul 2004
You need to get it as free as you can before you reattach the servo. It may be a case of simply flexing it back and forth a few times to free up the hinges, otherwise you'll have to look for where it's fouling.
Old Jan 21, 2013, 05:01 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Thanks. I had worked the ailerons a lot to make it loose as possible. I will try out the servos alone to see if that's doing the noise, though.
Old Jan 21, 2013, 06:10 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
The 82's are lousy servos. For good performancs get 85's. And as mentioned check surface movement, good luck.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Jan 21, 2013, 12:36 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Not bought any Hitech servos in over 12 years (too pricey for what is delivered )
But it does sound like that servo is being overdriven
ie: running out of linkage travel before the servo does.
Bare is offline Find More Posts by Bare
Old Jan 21, 2013, 03:20 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Linkage is good, plenty of travel. They should have ratings on these servos for noise potential. So the 85s work better? Bare-- What servos do you use?
Old Jan 21, 2013, 06:48 PM
sgomes is offline
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
With the linkage disconnected the ailerons should hang to almost full deflection. Sure sounds stiff to me.
Steve
sgomes is offline Find More Posts by sgomes
Old Jan 21, 2013, 07:05 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
They don't. They have to be pushed to to full deflection. I used the CA hinges and am regretting it. Know any way I can loosen them up?
Old Jan 21, 2013, 07:33 PM
sgomes is offline
Alameda, CA
Joined Dec 2006
If done correctly, CA hinges work fine.
Old Jan 22, 2013, 01:59 AM
abenn is offline
Joined Jul 2004
Originally Posted by Saxguy1000 View Post
They don't. They have to be pushed to to full deflection. I used the CA hinges and am regretting it. Know anyway I can loosen them up?
You just have to flex the control surface back and forth by hand for a while.
Old Jan 22, 2013, 05:24 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
These hinges have been really tough for some reason. I spent a while flexing them and it didn't make too much difference.
Old Jan 22, 2013, 07:42 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Your chatter starts from the first movement. Usually the chatter doesn't start until the servo meets some strong resistance.
If it was CA binding I would have expected extreme flexing to bust it loose. Are the ailerons too close to the wing and you have actual physical interference in the movement?
What was the result of the servo noise without the ailerons hooked up?
You are flexing the ailerons without the servos hooked up, right? (Had to ask)
Cut and replace if all else fails.
hoppy is offline Find More Posts by hoppy
Old Jan 22, 2013, 08:20 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Here's a video of the same servos (this is right aileron) not connected to the ailerons:
HS-82 servos without load but noisy (0 min 27 sec)
The servos are on separate channels. You'll hear that they are about 50% as noisy as when hooked up in the video above (post #1).
For Sale 2 Hitec HS-7985MG Servos bluelevel Aircraft - General - Radio Equipment (FS/W) 2 Jan 18, 2013 11:48 AM
Sold NIB - HiTec HS-325HB Standard Ball Bearing Servo w/ karbonite gears modestmagi Aircraft - General - Radio Equipment (FS/W) 0 Jan 15, 2013 05:18 PM
Sold New in box Hitec HS-82MG servo sdstick Aircraft - General - Radio Equipment (FS/W) 2 Jan 14, 2013 12:34 PM
Sold Hitec servos , HS-55 . HS-56 & HS-5245 Dennis Everett Aircraft - General - Radio Equipment (FS/W) 2 Jan 11, 2013 10:44 PM
Sold 3 Hitec HS-5625MG Servos with Blue Servo Arms Like new $85 Shipped Mahu Aircraft - General - Radio Equipment (FS/W) 4 Jan 05, 2013 11:33 PM
