Old Jan 20, 2013, 04:12 PM
Daniel.A design is offline
Find More Posts by Daniel.A design
Joined Jan 2013
New Product
Micro Integrated PCB w/ESCs Quadcopter Frame 235mm
This tiny yet brilliantly designed Mini-Quad features an integrated PCB frame with 4 x 8A ESCs pre-installed. Simply bolt on the motors of your choice, then solder wire leads directly to the frame.
The integrated power distribution system with ESCs makes for one of the neatest electronics installs around. This cute little quad even features integrated LEDs on both the top and bottom of the motor mounts. The LEDs are switchable between both "X" and "+" configuration via an on board slide switch.
All mounting hardware and frame components are included in the kit. All you will require to have this quadcopter in the air is 4 x brushless motors, a set of propellers (2 clock wise and 2 counter clockwise) a 500~1000mah 2~3s lithium polymer battery, a HobbyKing Multi-rotor control board and your own transmitter & receiver (Tx/Rx).
Features:
Compact, lightweight design
Integrated PCB for tidy component installation
Integrated 8A ESC x 4
Includes a full set of frame and mounting hardware
Specs:
Width: 235mm
Height: 35mm
Weight: 82g (w/out electronics)
Motor mount holes: 13mm
Integrated ESC: 4 x 8A
Required:
4 x brushless outrunner motors
4 x 5~6 inch propeller (2CW & 2CCW rotation)
1 x HobbyKing Multi-Rotor Control Board
1 x 500~1000Mah 2~3s lithium polymer battery
Your own 4CH transmitter and receiver
This product has been in HobbyKing sales.
http://www.hobbyking.com/hobbyking/s...35mm_KIT_.html
$26.99
Best Regards
Daniel
Daniel.A design is offline Find More Posts by Daniel.A design
Old Jan 20, 2013, 04:41 PM
craigiri is online now
Find More Posts by craigiri
United States, FL, Sarasota
Joined Nov 2012
Is this your designs or are you just pointing it out?
Is there a manual for the building or more exact instructions? This may be a good first build for me......
craigiri is online now Find More Posts by craigiri
Old Jan 20, 2013, 04:43 PM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
I asked in the SimonK flashing thread here about flashing the ESCs but no responses yet.
If anyone knows about flashing these ESCs let us know!
Cheers!
Soma is offline Find More Posts by Soma
Old Jan 20, 2013, 10:48 PM
Joined Jan 2013
HI,You can take a look at this site, here are the more detailed instructions
http://www.a-design.hk/en/multirotor.htm
Best Regards
Daniel
Old Jan 20, 2013, 11:13 PM
Joined Jan 2013
Cheers!
My English is not very good, what's wrong with the flashing ESCs?
Best Regards
Daniel
Old Jan 21, 2013, 02:33 AM
Soma is offline
Joined Sep 2012
Hi Daniel and thanks for the responses.
So this is your design? Are you manufacturing them?
Its a nicely designed frame and the website is very well presented! Congratulations!
I have ordered one of these frames from Hobbyking. Are you supplying them? When will they be in stock?
This is what I meant by flashing the ESCs
From..http://wiki.openpilot.org/display/Doc/RapidESCs
"So, what exactly is RapidESC and why do I need it?
Standard ESCs are actually not designed for multirotor applications. They are programmed to increase and decrease the throttle command towards the motor in a gentle way. The reason for this is quite obvious. Imagine a motor accelerating and decelerating so abruptly in a helicopter or car... it would damage the gears and reductions in no time. In a multirotor application, we really want just the opposite. The goal is to change the motor speed, and thus the thrust, as fast as possible to achieve a perfectly stable platform.
While the current ESCs used in most multrotor applications work considerably well, there is a lot of room for improvement. Using the same ESC, but loading it with dedicated optimized software, will increase the handling and stability of your multirotor greatly.
We call this RapidESC: converting your regular lazy ESC into a high speed capable speed controller at no extra cost, ready for multirotor applications."
Are your ESCs programmed for rapid response like SimonK firmware?
Or can we flash SimonK to them?
Also it would be great if there was provision to mount a 35mm square control board. They mount on 30mmx30mm holes.
Like the 'Flip' http://www.rcgroups.com/forums/showthread.php?t=1764146
Or 'Nanowii' http://www.rcgroups.com/forums/showt...hlight=nanowii
They are lighter.
Old Jan 21, 2013, 01:13 PM
Joined Jan 2013
They are lighter.
Hello, thank you for your blessings. I'm glad you like me to design the product!
I read English is sweaty, so use software to help translation of English, may not too accurate, hope you can understand.
Hope I can correctly understand what you mean, need to explain, ESC use different hardware scheme, the corresponding different software configuration, we produce different ESC will also corresponding to different software to record, we use the MEGA8L chip, but not recommended to burn program, it is possible to bring unpredictable results.
We don't produce such control board, but it is a very good product!
Old Jan 22, 2013, 01:56 AM
Soma is offline
Joined Sep 2012
Thanks Daniel,
I will contact you directly regarding purchase.
I cancelled my Hobbyking order after their copying of the Nanowii & Microwii.
Cheers.
Old Jan 22, 2013, 08:10 AM
Joined Jan 2013
Thanks Daniel,
Cheers.
No thanks, I'll try my best to answer your question.
Cheers
Daniel
Old Jan 31, 2013, 07:26 PM
n3mo is offline
Find More Posts by n3mo
Joined Jul 2012
So, any recommendations for the motors? The only way to mount my favourite 18-11 is with zipties, I haven't found any motors that would fit directly.
n3mo is offline Find More Posts by n3mo
Old Feb 01, 2013, 04:44 AM
codextreme is offline
Find More Posts by codextreme
Joined Mar 2012
I own an identical frame, but this version is a clone of the ZMR one :
http://item.taobao.com/item.htm?spm=...id=15554965686
The motors are theses 2400Kv ZMR motors :
http://item.taobao.com/item.htm?spm=...id=16181509635
But It seems the cloner havent drilled the same holes on his frame.
codextreme is offline Find More Posts by codextreme
Old Feb 01, 2013, 02:45 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Do the zip ties hold the motors perfectly tight?
I'd think even with a tight cinch, there would still be some play...
TheCure is offline Find More Posts by TheCure
Old Feb 01, 2013, 04:21 PM
ohmgnohm is offline
Find More Posts by ohmgnohm
ohmgnohm's Avatar
Switzerland, ZH, Wiesendangen
Joined Jan 2012
Turnigys 1811 2900kv dosnt work proper.
i get some problem with timing. Motors dosnt work well.
Auso Turnigy 1826 dosnt work proper still get some timing problem at higher speed.
This Motor will fit exactly with the holes of the Board :
1510-15 2200kv Mini Brushless Outrunner Motor from Mystery.
U get them on good....luck....buy...
This one i will test tomorow...maybe this one will spinn proper...without timming problem.
ohmgnohm is offline Find More Posts by ohmgnohm
Old Feb 01, 2013, 11:31 PM
n3mo is offline
Joined Jul 2012
Any place to get these motors aside from Taobao? I'm not very good with chineese.
I found them some time ago and they look great (only small motor with integrated prop adapter that I know of), but the only shop where I could find them is a swedish one where they're expensive and they don't ship internationally.
If you do it right, there is no movement whatsoever. Many people use zipties on much bigger motors, like DT750 (because of their unusual mounting pattern). 18-11 aren't powerful enough to move under two zipties, and I have them mounted with four.
I had some free time today, so I put mine together and did some buzzing around inside. I used 18-11 2000kv version, with no problems at all. 2000kv aren't very efficient on 2S, but it managed ~10min of flight time with a 1000mAh lipo. AUW is ~220g.
All in all, I really like this frame. The ESCs seem to be SimonK-like. They're fast, and they don't seem to be configurable, nor do they seem to have a low voltage cutoff - I might be wrong, but I got one lipo to 3.15V/cell and it still flew (I haven't noticed battery alarm slipping off, silly me). After hovering for 10 minutes they're not even warm, so whoever designed this thing did a good job.
Old Feb 02, 2013, 07:20 PM
TheCure is offline
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Did the 1510 motors work???
New Product Turnigy Integrated PCB Micro-Quad CheckSum Multirotor Talk 865 Nov 04, 2015 09:35 PM
Discussion 1st design PCB micro sized quadcopter frame t101 Scratchbuilt Multirotors 9 Sep 26, 2014 09:49 PM
Sold New IDEAFLY IFLY-4 Quadcopter w/ Bonus Free Micro Frame Bryan's Flyin Aircraft - Electric - Multirotor (FS/W) 2 Jan 16, 2013 11:44 AM
Sold Quadcopter frame with ESCs and Motors constantmotion Aircraft - Electric - Multirotor (FS/W) 3 Jan 13, 2013 10:31 AM
