Old Jan 20, 2013, 01:44 PM
Blind Bay's Avatar
Joined Mar 2008
wires on brushless ESC
I have been told that lengthening the 3 wires out of the ESC to the motor will cause problems. What are the problems? what about shortening the wires?
Blind Bay is offline Find More Posts by Blind Bay
Old Jan 20, 2013, 02:29 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
No. Lengthening the motor wires is Ok. You must be careful about lengthening the wires from the battery to the ESC. A few inches is Ok, but very long battery wires result in voltage spikes than can damage the ESC. Adding extra filter capacitance to the ESC is the remedy if you can't extend the motor wires to position the ESC.
whitecrest is offline Find More Posts by whitecrest
Staffs, UK
Joined Nov 2003
I don't know who told you that but they were wrong. Any length between ESC and motor is fine though it's a good idea for all 3 to be the same length.
Lengthening wires from ESC to BATTERY can cause problems as has been discussed here dozens of times.
Steve
slipstick is offline Find More Posts by slipstick
Old Jan 20, 2013, 03:10 PM
Blind Bay's Avatar
Joined Mar 2008
wires on Brushless ESC
thanks for the quick reply guys. I only need to extend the wires from the ESC
about 2" I am using a HobbyKing 120A watercooled Esc. Being that it didn't come with bullet connectors soldered, I will extend the wires before soldering the bullet conns. I have some 12 ga. wet noodle wire which should work good.
Question Where to extend the wires - the final word on where to mount the ESC's? Pelagic Multirotor Electronics 13 Jan 16, 2013 10:17 AM
Question What wires on a Fiego motor correspond to ABC on a brushless ESC? zanek Racing Boats - Electric 22 Aug 12, 2011 06:38 PM
Discussion What wires do I connect my brushless esc to on my brushless motor? niquebeats Electric Plane Talk 9 Sep 14, 2006 02:19 PM
Question on extending wires on E-Flite brushless esc. 1987tc Power Systems 3 May 10, 2005 09:31 AM
What's the third wire on brushless ESCs? Allan_A Power Systems 2 Mar 03, 2004 12:29 AM
