Old Jan 22, 2013, 03:08 PM
WOS is offline
WOS
Find More Posts by WOS
WOS
United States, IN, Michigan City
Joined Nov 2003
Not sure what you mean with the stick at top. if that is the throttle I thought when binding you have everything hooked up, put in bind plug turn receiver on, throttle all the way down then turn tx on in bind mode
WOS is offline Find More Posts by WOS
Old Jan 22, 2013, 03:51 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
I am programming the throttle stick range between the Tx and the ESC from 100% to 0%. In short, you turn on the Tx with the stick all the way up, you plug in the heli, you get a couple of beeps, push the stick all the way down, get some more beeps and you are done. Everything binds just fine it's just that the motor starts at 20% which I think is too high considering all my other helis start at around 7%.
arrowshooter is offline Find More Posts by arrowshooter
Old Jan 22, 2013, 04:04 PM
War Horse is offline
Find More Posts by War Horse
War Horse's Avatar
United States, FL, Hernando
Joined Sep 2012
That would be setting end points in the ESC, the rest would have to be done in the TX throttle curve setting.
War Horse is offline Find More Posts by War Horse
Old Jan 22, 2013, 04:23 PM
Joined Aug 2012
I don't think I can do that with this:
Old Jan 22, 2013, 04:28 PM
War Horse's Avatar
Joined Sep 2012
Oops, sorry , I didnt know that you were still using the stock Tx. I knew it would get confusing in here due to the many different combinations going on.
Old Jan 22, 2013, 04:39 PM
Joined Aug 2012
Oh, no worries. This is just the Walkera setup I bought because it fit my needs for the conversion.
Old Jan 22, 2013, 05:20 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
I'm not familiar with that TX. Can you set subtrims and travel adjust.
If so try setting travel adjust on throttle to -10 to +10 and see what happens..
BThirsk is offline Find More Posts by BThirsk
Old Jan 22, 2013, 09:52 PM
Joined Aug 2012
I can only adjust trims and reverse servos with this one.
Old Jan 22, 2013, 10:22 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Then your pretty much at the mercy of the TX as we were with the stock MJX unit. Turnigy 9x would be a good addition or you might consider a Devo 10 which you can flash with deviation and will run the RXs you have as we'll as Devo and spectrum.
Old Jan 22, 2013, 11:43 PM
Evercopter4 is offline
Find More Posts by Evercopter4
Closed Account
Joined Dec 2012
Originally Posted by asanovrus View Post
if they can't write manual in English do you really think they read this? They must have similar forum in Chinese I guess.
LMAO!! Priceless, thanks for that one!
Evercopter4 is offline Find More Posts by Evercopter4
Old Jan 23, 2013, 12:31 PM
Joined Aug 2012
Went out today before the rain starts and I gotta get some more batteries for these things. I want to try 3S but not sure if 2200 mAh is appropriate.
My 90 degree Align swashplates should show up today so I need to decide when to pull the trigger on the full 450 flybarless fixed pitch head conversion. I am thinking I should just cut the metal rods off the F45 flybar first, leaving the mount and linkage, to at least see how it will handle. Decisions.....Decisions......
Old Jan 23, 2013, 01:36 PM
War Horse's Avatar
Joined Sep 2012
I would think theres to much slop in the stock rotorhead to make it a stable FBL platform, 3 axis gyros arent the fastest thing in the world. Note when tilting the heli how slow it is to return to level swash. It would seem to me that youll be on the cyclic control having a epileptic seizure.
Then again, if you do give it a try, do take some video of the maiden.
Old Jan 23, 2013, 03:54 PM
R.C. Man is offline
Find More Posts by R.C. Man
Frank
Germany, BW, Heubach
Joined Dec 2012
OHHH speakin of maiden flights,
I got my stuff from china today
Stuff looked good, they sent me an extra rear rotor with the kit, an alu 1.
The rest was in a gold color, After removing the anodizing, I polished it,
Disassembled the rear rotor, and polished it, for the
450 from HELLi
What yall think, the whole HELLi will be like this.
a coupla pics from today.
Frank
R.C. Man is offline Find More Posts by R.C. Man
Old Jan 23, 2013, 05:15 PM
Joined Aug 2012
I would think theres to much slop in the stock rotorhead to make it a stable FBL platform, 3 axis gyros aren't the fastest thing in the world. Note when tilting the heli how slow it is to return to level swash. It would seem to me that youll be on the cyclic control having a epileptic seizure.
You are correct sir! I just pretzled the flyber (and broke another set of Xtreme blades), so I cut the rods off at the holder. After quite a bit of fiddling with the gyro settings I was able manage some sort of hover for about 10 seconds, but no way stable at all. Next option would be to hook the bones direct the the blade holder. After I mess with that for a bit, I'll by the good stuff.
Old Jan 23, 2013, 05:16 PM
Joined Aug 2012
450 from HELLi
Frank
Boy that is purdy. Can't wait to see the finished product.
Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review FyreSG Micro Helis 9048 May 23, 2016 10:01 PM
Help! MSR Fixed Pitch Question Dubbin1 Micro Helis 3 Jan 11, 2013 08:46 AM
Discussion outdoor four channel fixed pitch heli hereathome Electric Heli Talk 24 Jan 05, 2013 11:15 PM
Discussion BlitzRCWorks Ghost FP RC Fixed Pitch thintz Micro Helis 1 Jan 05, 2013 02:32 PM
Sold 450 Heli tool Lot Align pitch, Swash level, link pliers, more -S- Aircraft - Electric - Helis (FS/W) 1 May 16, 2010 08:07 PM
