United States, NC, Albemarle
Joined Jan 2013
Thanks guys! I REALLY have high hopes for my FP450. As for my skills flying it? Well, I have best wishes at least. Hopefully, this beast will fly within the week.
I am the king of stupid mistakes like the run up in the house. Luckily, no one has ever been injured due to my poor planning, short of my own pride being bruised. It's all in fun, right? LOL |
United States, CA, Modesto
Joined Aug 2012
Hey Arrowshooter another question for you
Asked helihankster about using funcopter blades on a f45 rotor head as it looks like the blade grips might slide over the f45 grips and bolt in place, he said you were thinking of trying to mod them to fit on a 450, have you ever tried and what was the result? I'd hate to spend that much money on blades only to find out that the gap wasn't wide enough to slide over the f45 grips. What's your thoughts?
Anybody who has these blades, could you please measure the gap between the grips and post that dimension. Thanks Tom My other concern is with less pitch what kind of head speed would be needed, and whether it would be to much for a modified f45 grip to handle. |
Joined Aug 2012
http://www.helifreak.com/showthread....262663&page=53 |
Joined Jan 2013
They are also intended to rotate in opposite directions to one another:
Wrong direction for sure
It's hard to tell some things from pictures, didn't realize that the funcopter blades turned counter clockwise, that would be a huge problem. I just want a bigger heli that is easy to fly and I thought the larger blades would look better and grab more air than the f45 blades. I really don't want a heli with a hiller type configuration, as I like the ease of the 45* fly bar, but there's just not much to choose from when it comes to FP blades as you all well know. Thanks guys for the reply's.
Joined Aug 2012
But position of fly bar
I realize that the direction of rotation is easily corrected, but not the position of the fly bar in relation to the blade. Not sure it would react well with the fly bar on the wrong side of the blades rotation. I will be ordering the 450 kit from value hobby this weekend, and already have the motor and pinion coming from hobby king, guess I'll just use the stock f45 head like John did. I trust him that it works well, and can't wait to have a belt driven tail. The more I fly the f45 the more I hate the wishy washy tail performance. With the f45 head, because of the lowered head speed, did you guys use larger tail rotor blades for better authority? I've read where some went with bigger blades.
John, does your f45/450 turn ok with stock tail rotor blades? (on the belt driven tail?) |
Joined Aug 2012
I get what you were getting at now.
![]() I built two of the F45/450's, which is what I started this thread with, and they truly do fly great. I had one with the tail motor and one with the belt drive, and the belt drive is definitely the way to go for sure. |
Joined Jan 2013
Got a problem with the ESC I think. I can throttle up or down fully with the main rotor removed, and the motor responds accordingly. If I put the main rotor on, it will turn slowly and never speed up regardless of stick position. I can "spin" the motor manually from this point and it jumps to WOT, so it seems to have trouble going from soft start to any other setting. Is this a soft-start or timing issue? Remember I'm using the Funcopter motor...
ESC does not get hot. Maybe slightly warm to the touch, but never hot. It's a Red Brick 50A w/UBEC. I'm running 2200Mah 30C 11.1V LiPos as well. |
Joined Aug 2012
| Thread Tools | |
| Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review | FyreSG | Micro Helis | 1972 | Today 06:16 AM |
| Help! MSR Fixed Pitch Question | Dubbin1 | Micro Helis | 3 | Jan 11, 2013 08:46 AM |
| Discussion outdoor four channel fixed pitch heli | hereathome | Electric Heli Talk | 24 | Jan 05, 2013 11:15 PM |
| Discussion BlitzRCWorks Ghost FP RC Fixed Pitch | thintz | Micro Helis | 1 | Jan 05, 2013 02:32 PM |
| Sold 450 Heli tool Lot Align pitch, Swash level, link pliers, more | -S- | Aircraft - Electric - Helis (FS/W) | 1 | May 16, 2010 08:07 PM |
