Old Feb 19, 2013, 03:53 PM
War Horse is offline
Find More Posts by War Horse
War Horse's Avatar
United States, FL, Hernando
Joined Sep 2012
For servos, give these a try, for the price they are top notch.
http://www.hobbyking.com/hobbyking/s...dProduct=14279
War Horse is offline Find More Posts by War Horse
Old Feb 19, 2013, 03:58 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Thanks. I'll see how much I like the metal gears then decide to spend the extra for good servos.
arrowshooter is offline Find More Posts by arrowshooter
Old Feb 19, 2013, 04:28 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Those HK922MG servos are very good. I have a set and one of my freinds has them on several helis and he has had no problems at all.
A real good option is the TGY306G, which he also has a set of. A little expensive, but tough and fast.
BThirsk is offline Find More Posts by BThirsk
Old Feb 19, 2013, 04:57 PM
Joined Aug 2012
Thanks too. My big worry with metal is "if" I crash, and the servos don't give, what will.
Old Feb 19, 2013, 05:29 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
That's not an issue. When you get rid of all the substandard stuff, you won't crash anymore, and if you do, you will find the next weak point.
Some people use a weaker servo arm or modify it so it will be the weakest point and break first.
Old Feb 19, 2013, 06:28 PM
kpinnc is offline
Find More Posts by kpinnc
Goooo!!!! Get to da choppa!!!!
United States, NC, Albemarle
Joined Jan 2013
My parts are beginning to arrive. I'm taking the easier route on the FP, but I'm a noob. I need to be able to follow a set of instructions. Follow-on parts might take a couple weeks, but I'm on a budget...LOL
Still on the fence over a 450 or a 500. Of course the 500 would be awesome, but it's size worries me a bit when coupled to the 4mm main shaft and my skill level. I may just get a Funcopter plastic frame and mod it with a clone 500 belt-drive tail. I think for starters, it would be more crash-worthy. I can move up from there later on.
kpinnc is offline Find More Posts by kpinnc
Old Feb 19, 2013, 06:49 PM
Joined Aug 2012
It's a start. Can't wait to see it finished.
Old Feb 19, 2013, 07:02 PM
kpinnc is offline
Joined Jan 2013
I'm sure you will have finished your next project before this one is done. I'm WAY behind the curve on RC gear. I don't even have a radio yet LOL.
The only RC stuff I have other than the picture above is my F45.
Old Feb 20, 2013, 03:37 PM
swedman is offline
Find More Posts by swedman
Sweden, Stockholm County, Stockholm
Joined Apr 2012
Hi Arrowshooter!
Im following your project with great interest :-) Yes, you can move the "ring thingy" any where on that wire. Its is used to cancel out high frequency signals on the wire to minimize interference with other equipment (or the Rx itself). Its usually just a precaution and could be removed totally.
Best regards
Swedman
swedman is offline Find More Posts by swedman
Old Feb 20, 2013, 04:02 PM
Joined Aug 2012
Originally Posted by swedman View Post
Hi Arrowshooter!
Best regards
Swedman
Thanks Swedman. Will make it a whole lot easier to run the wire if the "ring thingy" was in another spot.
Old Feb 21, 2013, 06:43 PM
Scarlet is offline
Find More Posts by Scarlet
Oh no!
Scarlet's Avatar
Wales(UK)
Joined Jul 2004
I've been watching this thread for a while now and I have an old 450 clone which I intend to convert.I was going to use the funcopter head and blades too..Trying to find Multiplex spares in the UK is difficult but I found a supplier and the prices are absurdly high.I| remember back in the old days I had a MFA Sport 500 fixed pitch nitro heli which had aluminium blade holders(I think,it's so long ago)which you had to bend to achieve the neccessary pitch and to track the blades etc.Would it be possible to somehow lock the blade holders in the stock head to give,say,5 deg or so of pitch and then just use throttle as in a normal FP heli?Do you think it could work?I might give it a go.
Scarlet is offline Find More Posts by Scarlet
Old Feb 21, 2013, 06:57 PM
Joined Aug 2012
I believe that you can do that just by the settings on the Tx so that they stay at 5 deg. There is a guy on youtube who did it. Before I decided to do flybarless I thought about putting a locking screw on the pins that go through follower.
Old Feb 22, 2013, 12:59 AM
OldOz is offline
Find More Posts by OldOz
John
Australia, QLD, Brisbane
Joined Aug 2012
Not quite sure what you mean by 'stock head' scarlet - if you mean (say) Align 450 CP set to 6-7 deg FP, problem is 1) the FB is at 90deg, and 2) the whole head assembly will suffer from the fragility of a standard FB head - hit anything but air, it'll break - and 3) IME, it handles crappier than either a CP or a 45 deg FP. I had high hopes, too!
But maybe I misunderstood your idea.
Edit - been a long day. Quote was meant to be Scarlet's original. My bad!
OldOz is offline Find More Posts by OldOz
Old Feb 22, 2013, 12:52 PM
Bnh105 is offline
Find More Posts by Bnh105
United States, IL, St Charles
Joined Jan 2013
What are you guys using for the tail? I'm considering doing this. Is it just a motor or dd tail on there?
Bnh105 is offline Find More Posts by Bnh105
Old Feb 22, 2013, 01:56 PM
Joined Aug 2012
I am using the belt driven tail, but started with a tail motor setup off of the MJX F45. There are also some playing with driect drive using a brushless motor.
Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review FyreSG Micro Helis 9062 Jun 25, 2016 02:10 AM
Help! MSR Fixed Pitch Question Dubbin1 Micro Helis 3 Jan 11, 2013 08:46 AM
Discussion outdoor four channel fixed pitch heli hereathome Electric Heli Talk 24 Jan 05, 2013 11:15 PM
Discussion BlitzRCWorks Ghost FP RC Fixed Pitch thintz Micro Helis 1 Jan 05, 2013 02:32 PM
Sold 450 Heli tool Lot Align pitch, Swash level, link pliers, more -S- Aircraft - Electric - Helis (FS/W) 1 May 16, 2010 08:07 PM
