I used cheap servos on my 250 and 10 outings and they were done. I replaced them with more cheap servos and they are just about done as well. I went for 20.00 digital metal gear servos to replace when I convert it to flybarless. It did look very stable though when you first took off. Looking good. |
Joined Sep 2009
this video should fit this thread nicely.
United States, CA, Modesto
Joined Aug 2012
Joined Sep 2009
Yes it’s a 50T pulley. When Johnnycat was designing the 450 frame to incorporate the funcopter direct drive motor, we added the largest pulley we could found at the time. On my FP DD450, I measure the max headspeed on 3s at 2190rpm. The 50T pulley give a tail ratio of 4.55 to 1, so tail rpm was around 9965. This was still a little low for a 450, so to compensate for this we used larger tail blades. |
Joined Sep 2009
Using a standard 450 5mm shaft in this bird. Been luckily I guess… can’t recall bending many shafts. I think this is mainly due to the design of the funcopter blade grips, as they fold up most of the time during blade strikes. Check out the impact at 2:40 in this video. Believe it or not, the main shaft did not get bent. I still watch it and can’t believe it. lol!
Joined Aug 2012
I watched that in slow mo on the other site and saw that branch reaching out. Have to give it to the funcopter head, it's tough. How many of those blue servos did you go through? I have bought 8 and am down to 2. 1 went to the elevator and the rest to the aileron.
United States, NC, Albemarle
Joined Jan 2013
Thanks Hankster! Great to know stuff! |
Joined Sep 2009
Joined Aug 2012
Joined Aug 2012
Align DFC vs. Hobbymate
Just so you can get an idea of the major difference between the Hobbymate and the Align DFC Heads, which is the arm off the blade grip for the control linkage. The Hobbymate arm bends and I don't see that happening to the Align.
| Thread Tools | |
| Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review | FyreSG | Micro Helis | 1924 | Today 04:49 PM |
| Help! MSR Fixed Pitch Question | Dubbin1 | Micro Helis | 3 | Jan 11, 2013 08:46 AM |
| Discussion outdoor four channel fixed pitch heli | hereathome | Electric Heli Talk | 24 | Jan 05, 2013 11:15 PM |
| Discussion BlitzRCWorks Ghost FP RC Fixed Pitch | thintz | Micro Helis | 1 | Jan 05, 2013 02:32 PM |
| Sold 450 Heli tool Lot Align pitch, Swash level, link pliers, more | -S- | Aircraft - Electric - Helis (FS/W) | 1 | May 16, 2010 08:07 PM |
