Old Jan 20, 2013, 08:34 AM
teknos is offline
Find More Posts by teknos
España, Comunidad de Madrid, Madrid
Joined Feb 2006
Structure of a spar
Hi all,
I'm thinking about an easier way of making a carbon spar. Mi idea is to use an aluminium profile shaped in "U" as a jig, 12mm wide —inside—. Wax it, use PVA if neccesary, and lay inside the wetted carbon tow. Just over the carbon, in the 2/3 parts of the spar —from the root—, the balsa vertical engrain —12mm wide—, and in the tips, Styrofoam Hi-load 60. Let it cure, take out, and make the upper caps in the same jig. Let it cure and take them out. Trim the core of the spar —balsa and foam—, and glue all with epoxy and micro balloons.
Description: Spar structure. Balsa endgrain for the first 2/3 and Hi-load foam for the tips.
Description: Aluminium profile shaped in "U"
The problem is that usually spars are wider in the root, regarding to stiffness, than in the tips, wich should be lighter. My spar has the same wide in the roots and in the tips but, because the core, it should be stiffer in the roots and lighter in the tips, and much easier to build. The compress load on the foam shouldn't be critical in the tips , but I'm not sure about that. I don't know if it could be neccesary to wrap with glass sock, and my idea is to avoid it. Do you think this could be neccesary?
A.
teknos is offline Find More Posts by teknos
Old Jan 20, 2013, 09:58 AM
Upvector is offline
Find More Posts by Upvector
Upvector's Avatar
Hamilton, CANADA
Joined Sep 2009
@A
If you have not seen this information,
http://www.charlesriverrc.org/articles/supra/supra.htm
you should look into it thoroughly.
The spar has been engineered to really good specifications and
needs, but you must understand the details of the information
to get all of the benefits.
Wish you luck,
my build partner and I hope to have our Supra planes
in the air this season,.. a lot of time, (3 years) and energy have gone into
the construction, but the knowledge of materials and techniques will change how
you build anything in the future. We used an aluminum "L" shape to build our spars
.. it allowed us to taper the spar and save some weight at the tips, where you want
to save weight. It makes the plane respond much better to control input, and also
will show lift and air movement much better.
Hope you can post your efforts.
Ray
Upvector is offline Find More Posts by Upvector
Old Jan 20, 2013, 01:57 PM
teknos is offline
Joined Feb 2006
Hi Ray,
I know Drela's technique, but as he sais, «It's prudent to use endgrain balsa in the spar center over the wing saddle». As the wings of my plane —a prototype, not a Supra— will be made in one piece, and with the same wide in root as in the tips, ¿why dont use both types of cores to avoid the excess of weight in the tips?
Old Jan 20, 2013, 05:51 PM
Upvector is offline
Upvector's Avatar
Hamilton, CANADA
Joined Sep 2009
...absolutely... the choice of material is definitely yours to make, and if it fits your design
I'm sure it will work.
For foam in the tip spar, where the size of the spar is smaller, it is critical to make sure the spar caps are held in place firmly, so a lot of care is to be taken to bond the spar caps to the foam. We also wrapped the tip spars, (like the center spar) in fibreglass cloth. We are happy with the combination of foam, vertical grain hard balsa and carbon fibre tow, that produced a very strong spar, with a little bit of ability to flex
during launch.
For us, we had to learn how to take out the epoxy that only added weight, but maintained the strength. That was (with us) a very important part of staying within
the weight limits. We will know this season how well we did,...or didn't do.
Ray
Old Jan 22, 2013, 11:59 AM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
Start here if you want to skip all the aero design and go straight to the spar.
http://www.rcgroups.com/forums/showt...1256550&page=6
I've done two planes this way and it works very well.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Jan 22, 2013, 04:51 PM
Neil Stainton is online now
Find More Posts by Neil Stainton
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Sorry, but just linking to page 6 doesn't work for me, I have my page length set to 100 posts, and there aren't 600 posts in the thread. Can you please give a post number?
TIA,
Neil.
Neil Stainton is online now Find More Posts by Neil Stainton
Old Jan 23, 2013, 12:11 AM
Bernd Brunner is online now
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
#76 - #90
Bernd
Bernd Brunner is online now Find More Posts by Bernd Brunner
Old Jan 23, 2013, 05:16 AM
Joined Feb 2001
Thank you Bernd and G Norsworthy.
Very simple and effective spar construction.
Neil.
Old Jan 23, 2013, 07:39 PM
teknos is offline
Joined Feb 2006
Is exactly what I was thinking. I'll try this in my next plane —really soon—, but with a straight spar of 15 mm wide —the same in the root as in the tip.
Question Spar Structural Design chickenblender Modeling Science 27 Sep 15, 2014 09:28 PM
Discussion Thermal structure rockdoctor Hand Launch 9 Mar 16, 2013 09:05 AM
Discussion Composite skinned wing structure acesimmer Composites Fabrication 34 Feb 21, 2013 08:05 PM
Question Spar question for the structural engineers DICKEYBIRD Modeling Science 8 Nov 04, 2003 12:25 PM
