Old Jan 20, 2013, 08:31 AM
Chophop is offline
Find More Posts by Chophop
Turn that thing around...naaaa
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Parallel Servos
I am looking at the 27% GP Edge 540 and they parallel the rudder servo. Might this cause as fight between servos if they are not performing exactly ?
The two servos are linked together by two control rods, one on each horn arm, then to the rudder. No photo available but is in the assembly manual.
http://manuals.hobbico.com/gpm/gpma1414-manual.pdf
Chophop is offline Find More Posts by Chophop
Old Jan 20, 2013, 08:38 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Yes it sure can cause them to fight.
What are you using for a radio. Many radios now have a built in function to allow you to equalize their travel and even do it with a curve so it is equal all the way through the travel.
davidmc36 is offline Find More Posts by davidmc36
Old Jan 20, 2013, 10:49 AM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I can mix and limt the travel. Looks like a minute difference to trim. I thought it may be a bad idea if the servos were mismatched. If I get the plane I'll look for a single servo to do the job, but I suppose two standard servos would be a lot cheaper, the whole idea.
Old Jan 20, 2013, 11:58 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Just mixing and limiting travel may not be quite enough if there are differences throughout the travel of the rudder. May be just fine if you are very careful installing the horns so the travels on both sides of the rudder are equal.
If they are not exactly the same servo one may want to travel faster than the other. If you have a radio with the ability, that problem can be equalized out with the servo matching function.
Old Jan 20, 2013, 01:18 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
Hey chop, if needed you can always put each servo on it's own channle and run two pushrods, one to each ele half. Once again, just make sure travle is equal on each side or you will induce a roll.
62pilot is offline Find More Posts by 62pilot
Old Jan 20, 2013, 02:59 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I don't have servo match. No problem, I'll get around it.
62, it's for the rudder. I guess the rudder on a 27% Edge (78 inch) is about as big as wing on some small planes. I want to find out the need for two rudder servos. I do hear some are using a single high torque no problems, but now maybe next summer it will be "my rudder servo failed, pece of junk".
Old Jan 20, 2013, 03:47 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I found the photo. I can't see why a single high torque servo couldn't do the job. Maybe high stress knife edges ?
Old Jan 20, 2013, 05:06 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I don't see why one strong servo would not be fine for that setup. I saw recently a bit different setup that used two servos but it was set up with a lost motion device so you would have partial control if one servo failed. It was set up so that the failed servo would not have to be driven by the servo that was still working. Personally I don't see the point of the set up in that photo. Maybe somebody can enlighten us but I would go with one high torque servo and you have the pull-pull cable there so you don't have the problem of a push-pull rod bending under load.
Old Jan 20, 2013, 10:01 PM
Alien_Tech is online now
Find More Posts by Alien_Tech
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
You can always use one of these: http://www.swbmfg.com/categories/2X-...g-Servo-Trays/
Minute or even large differences in travel make no difference. Heck, you could even use two totally different types of servos.
Alien_Tech is online now Find More Posts by Alien_Tech
Old Jan 20, 2013, 10:25 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
Since so many people are running this setup there must be a reason. Two standard size servos won't break me. I can run 'em in the excersizer and see what happens.
I can think of one good reason for it. Wanna see my dual servo rrrrrruder setup honey ? Check this out ! See how well they move ? Waaaaannnna give it try ?
Old Jan 30, 2013, 07:19 AM
Magne is offline
Find More Posts by Magne
Moss, Norway
Joined Jul 2003
I would not have put one of these things into a 27% model.
It weighs 10 os (280 gram) and cost $140. Two cheap servos and this thing costs more than a high torque servo, which weighs 2.3 oz.
I use one servo for the rudder (Futaba BLS 157 HV) in models up to 2600mm/102" wingspan) and one Hitec 7990 servo in a 3,2 meter (126") wingspan IMAC model.
That works fine for me, flying IMAC Advanced.
(Maybe not as cool, but functional.)
Magne
Magne is offline Find More Posts by Magne
Old Jan 30, 2013, 01:02 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I appreciate your honesty Magne. $140 IS too steep for a servo tray. Those, like the $50 hamburger won't go far. I'll look those servos up, i am Hitec confident and will need to try some Futaba's.
Old Jan 30, 2013, 01:41 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
I don't see how it would really matter if you run a pull pull cable with one cable on each servo... there's a little give in the system, probably enough that it will equalize out as long as they're pretty much equal, which two servos of the same model with the arms in the same place probably can do (provided they're on separate channels).
That said, I have a hitec 805BB servo for about $40 however... it puts out over 300oz-in of torque @6v. It's a little heavy but man does it pull.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jan 30, 2013, 01:53 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by ChillPhatCat View Post
I don't see how it would really matter if you run a pull pull cable with one cable on each servo....
Interesting idea, never thought of that one before. Different than the picture linked above with the two servos hard-linked together. But I guess it would only be the same as using one servo, since only one at a time would be doing the work depending on which way you were pulling the rudder.
Old Jan 30, 2013, 02:13 PM
Vince Herman is online now
Find More Posts by Vince Herman
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
I understand that the reasoning behind ganging multiple servos is to increase the torque while keeping the speed.
Vince Herman is online now Find More Posts by Vince Herman
For Sale deans no wire parallel adapter $1.99 each goldsworthy Aircraft - Electric - Batteries & Chargers (FS/W) 7 Oct 19, 2014 11:42 AM
Sold deans no wire parallel adapter $7 shipped 3drcparts Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 17, 2013 04:35 PM
Discussion wiring a bec and esc in parallel nicosoh Power Systems 3 Jan 06, 2013 02:15 PM
Help! Diy parallel Li poly and charging Azuritko Batteries and Chargers 2 Jan 05, 2013 06:24 PM
Discussion Parallel hookup question. nforbesrc99 Batteries and Chargers 5 Jan 04, 2013 09:50 PM
