Old Jan 20, 2013, 06:36 AM
-james- is offline
Find More Posts by -james-
-james-'s Avatar
UK
Joined Sep 2008
Hubsan x4- won't lift off even at full throttle?
Hey guys,
One of my friends received one of these quads for christmas and handed it to me to get it trimmed etc so he could learn to fly. However after a couple of quite severe crashes it no longer wants to take off? It sort of just bounces around in the ground effect, occasionally rising higher but then descending straight away.
I have tried the reset trick with putting the rudder into the bottom right and wiggling the aileron stick but that as to no avail. I thought it may have been a low voltage problem on the battery so I made a connector for my B606 charger and even when fully charged to 4.2v it still doesn't take off :s
I would post a video but we're currently waiting on a replacement prop set.
If anyone has any suggestions they would be greatly appreciated,
Thankyou,
James
-james- is offline Find More Posts by -james-
Old Jan 20, 2013, 07:24 AM
Davross is online now
Find More Posts by Davross
Foam's Law
Joined Nov 2004
Broken motors for sure - the crashes pop the motor can apart and damage the brushes. Had it twice on my and a friend's Hubsan.
Kev
Davross is online now Find More Posts by Davross
Old Jan 20, 2013, 07:40 AM
-james- is offline
-james-'s Avatar
UK
Joined Sep 2008
Ah ok, how difficult are the motors to replace, and is it worth getting different from stock ones whilst we're at it?
Old Jan 20, 2013, 10:49 AM
symon is offline
Find More Posts by symon
Joined Apr 2007
You can buy 4 from ebay...you have to solder them on to the board...fine tip soldering iron required!......make sure you get them in order,red/blue wires and white/black wires..and them make sure you put the rotors on the right motors (they are marked A and B)
symon is offline Find More Posts by symon
Old Jan 20, 2013, 01:10 PM
aka_TEKK is offline
Find More Posts by aka_TEKK
Canada, QC, Montreal
Joined Apr 2012
I have four different motors on my Hubsan X4 for months, seriously I don't see any different! like new!
one from my SYMA S107, another from a no brand 3ch copter, the third from UDI 816 spare and one native!
Don't need to solder on the board, you could simply solder the wires together.
Good luck
aka_TEKK is offline Find More Posts by aka_TEKK
Old Jan 20, 2013, 01:39 PM
gentle ben is offline
Find More Posts by gentle ben
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
Try Massive Overkills Capri Sun straw motor/prop savers. Don't buy your straws from him for $99 I will sell the straw for 49.99
Seriously... they offer excellent motor protection so that hitting the top of the motor no longer will push the bottom out of the motor. Also don't forget to protect the exposed wires on the bottom. Some people use foam ear plugs some use stick on rubber bumpers... I just used a bead of hot glue around the bottom of the legs. My X-4 had the exposed wires protruding past the legs where you would be landing on them instead of the frame. I tried the ear plugs but never got the hang of cutting them equally and ran out of plugs.
gentle ben is offline Find More Posts by gentle ben
Old Jan 20, 2013, 03:49 PM
craigiri is offline
Find More Posts by craigiri
Critic at Large
craigiri's Avatar
United States, RI, Portsmouth
Joined Nov 2012
The wires are so thin that it is best, if possible, to solder back at the board.
I am a relative newbie at soldering and did this with no problem at all with the regular iron I have sitting around (which I have not used in 10+ years).
I have also spliced on my other quads, but I worry because the leads to the motors are so thin and you sometimes lose a few strands when stripping them.
I have another Hubsan on the way (other I put into the ocean!) and will put the straw protectors on this time - it's a pain replacing anything when you don't have to.
craigiri is offline Find More Posts by craigiri
Old Feb 15, 2013, 02:16 PM
Marcus churchill is offline
Find More Posts by Marcus churchill
Joined Feb 2013
I had the same
Sort of problem after a crash.
I had replaced one of the blades.
The thing wouldn't take off , after a lot of head
Scratching I realised I had put the wrong spare
Blade on the hubsan thus trying to fly one
Corner of it through the floor.
Hope this may help someone in future.
Marcus churchill is offline Find More Posts by Marcus churchill
Old Feb 15, 2013, 02:21 PM
jason4207 is offline
Find More Posts by jason4207
Eye to the sky!
jason4207's Avatar
United States, NC, Concord
Joined Dec 2012
Yep, 1 bad motor will cause the FCB to compensate to keep the craft level resulting in very little overall power.
jason4207 is offline Find More Posts by jason4207
Old Jun 09, 2013, 09:22 AM
Wildgeezer is offline
Find More Posts by Wildgeezer
Joined Feb 2013
Apologies if this is repeat, but previous threads did not help.
Till yesterday the X4 flew well. Now,
1. Does not lift off ground more than six inches even on full throttle and new batteries.
2. Drifts backwards like mad
3. Did accelerometer recalibration procedure. No change.
4. Checked all motors. They seem to spin OK.
5. One rear left motor rotor has developed slight play, that as it fires, the rotor pulls up by about a mm.
5. Checked thrust of each motor by holding quad in hand and they all seem to respond equally well to TX commands or Gyro.
Thanks for your help.
Wildgeezer is offline Find More Posts by Wildgeezer
Old Aug 07, 2014, 07:03 PM
heli_shmeli is offline
Find More Posts by heli_shmeli
Joined Jun 2014
I am having same problem, won't take off but motors clearly display full power in my hand. Did you end up figuring out what's wrong?
heli_shmeli is offline Find More Posts by heli_shmeli
Old Aug 07, 2014, 08:20 PM
Jerm357 is offline
Find More Posts by Jerm357
Jerm357's Avatar
United States, MI
Joined May 2011
Check the blades real good and make sure that none of them are bent.
Jerm357 is offline Find More Posts by Jerm357
Old Jun 08, 2015, 10:34 AM
giantstrider is offline
Find More Posts by giantstrider
Joined Jun 2015
It may be the order of the blades
New Hubsan X4 V2 H107L Quad problem: it cannot take off? (0 min 32 sec)
there is an A and B marked on each arm of the Hubsan. Make sure they correspond to the A and B on the rotors blades.
giantstrider is offline Find More Posts by giantstrider
Old Jun 08, 2015, 10:47 AM
TonyTronicWSP is offline
Find More Posts by TonyTronicWSP
Control the Truth#1 goal inWAR
TonyTronicWSP's Avatar
United States, WA, Walla Walla
Joined Oct 2012
The motor might have pushed drive pin. Get some pliers and pull the motor pin out, I had them push through the bottom of motor, push the plastic part back in at the bottom and pull the pin. Also the prop's can get stripped so they look like they are turning, but they will spin rather freely on the shaft, so full motor power not going to the prop. I have used tissue between the prop and shaft for tighter grab, but need to replace stripped out prop.
Hope this helps you get them flying again.
TonyTronicWSP is offline Find More Posts by TonyTronicWSP
Old Oct 23, 2015, 11:59 AM
live2drone is offline
Find More Posts by live2drone
Joined Oct 2015
dont mean to hijack this thread but couldnt get any help on my post...
I have a motor that wont spin, and there is zero voltage going to it.
(i installed a new motor in case, but that didnt help).
(have also tried the calibration procedure)
live2drone is offline Find More Posts by live2drone
Discussion Hubsan X4 won't stay staionary will piro-ing - any suggestions MikeHRC Mini Multirotors 4 Oct 21, 2012 01:45 PM
Question Stupid Blade 450 Question-No lift off at full throttle rcwarrior Beginner Training Area (Heli-Electric) 6 Jan 07, 2012 01:08 AM
Discussion Help: mSR won't take off at full throttle. Chris_F Micro Helis 24 Oct 28, 2010 11:00 AM
FEDA Dragonfly won't get off the ground at full throttle zhr10 Micro Helis 4 Aug 08, 2005 10:03 AM
Corona won't throttle all the way up, won't lift off. jrobgray Electric Heli Talk 6 Nov 20, 2003 02:17 PM
