Old Jan 20, 2013, 06:13 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Question
Wing tips on a plank
Hi guys,I've been checking out tips shapes here and elsewhere and would appreciate some comments/advice.
The wing is a Pw51 ,1500mm span,200 mm root,150mm tip.Straight l/e,no twist.
I've come across all sorts of tip shapes,including a pic of Peter in rcsd with what appears to be a plank with square tips.
I quite like the idea of starting with a square tip and trying different plug in taped on shapes- including the undercut Hoerner type.
Any comments,advice,hoots of derision would be welcome.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jan 20, 2013, 10:13 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
DOOEET!.
I doubt you will notice much difference in performance but it's an idea many of us have considered and few have attempted.
The new molded JW has a blunt taper.
DS foamie record holding Gulp.
The beautiful Windburner.
1000MPH is offline Find More Posts by 1000MPH
Old Jan 20, 2013, 10:45 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks for the input.Some nice wheels!Wings also.Can't help noticing that you don't take the surfaces out to the tip,which was going to be another query.I always think they're a bit vulnerable out at the wing tips.So the plan is start with a square and then introduce some curves and angles,see if I notice any difference.
Stuart
Old Feb 16, 2013, 12:10 PM
A6INTRUDER is offline
Find More Posts by A6INTRUDER
Portland Intl, Oregon, United States
Joined Jul 2003
Looking forward to hearing what you find out.
I have thought about this often and wonder what the difference really is.
Is there a BEST tip shape and does it work on all plan forms or does each plan form
work better with different tips.
On planes I have designed and made myself, I usually end up with something like the ones on theWwindburner, but not sure why, other than I just seem to like that look.
TIM
A6INTRUDER is offline Find More Posts by A6INTRUDER
Sold Top Flite Cessna 310 Wings and Wing tips NIB Fidelity101 Aircraft - Fuel - Airplanes (FS/W) 5 Feb 19, 2013 05:22 PM
Sold Xplorer w. 3.5 and 3.8m wing tips Frederick_r Aircraft - Sailplanes (FS/W) 3 Feb 01, 2013 08:26 AM
Discussion help redesigning my wing tips on my Grim Reaper MaydayMayday Flying Wings 4 Jan 18, 2013 12:42 AM
Discussion Not liking wing the joiners on my Custom Mirage build.....any tips hog2soar Thermal 7 Jan 07, 2013 10:35 AM
Discussion Straightening a warped balsa plank/wing? Piece The Builders Workshop 8 Jan 07, 2013 12:26 AM
