Old Jan 20, 2013, 06:25 AM
ercapoccia is offline
Find More Posts by ercapoccia
Italy, Lazio, Rome
Joined Jun 2012
Blade mCPX compatible parts list
There are many spare parts from other helicopter and quadcopter that can be used as cheaper/upgraded spare parts for the mCPX. Feel free to add and I'll try to make this post updated)
Main Gear
FBL100/V922 Main gear
V929/V949/mQX Motor gear (Almost any quad of the same size)
Main Frame
FBL100/V922 Main frame (needs some mods because tail boom is squared)
You can use FBL100/V922 kit (Main frame + tail boom + tail fin + tail case + tail motor)
Canopy
Paper Canopy
Landing Skid
FBL100/V922 Landing Skid
Swashplate Linkage
FBL100/V922 Swashplate Linkage
Tail Rotor Blade
FBL100/V922 tail rotor blade
Main motor
FBL100/V922 Main motor
Linear servo
FBL100/V922 linear servo (need some some mods)
Swashplate Leveler
V911 Main Gear - More info here
ercapoccia is offline Find More Posts by ercapoccia
Old Jan 20, 2013, 06:26 AM
Italy, Lazio, Rome
Joined Jun 2012
Reserved
Old Mar 03, 2013, 12:10 PM
lonepilot is offline
Find More Posts by lonepilot
Singapore
Joined Dec 2012
Main Gear
Main Frame
Canopy
Paper Canopy
Landing Skid
Swashplate Linkage
Tail Rotor Blade
FBL100/V929 tail rotor blade
Main motor
>>>>>>>>>> Linear servo
Swashplate Leveler
Balance charging cable
Balance Charging Cable WWG-JH-MMM for V202 V939 Ladybird X100 Mini CP
Hi, may I know what and how is the modification for V922 linear servo to work in a MCPX V2 ??
Thank you very much in advance.
lonepilot is offline Find More Posts by lonepilot
Old Mar 17, 2013, 09:18 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Main Frame
Swashplate Linkage
I bought a FBL-100 frame to try. Found it was NOT compatible with the mCPX's RHS servo mount and so could not be used...
Ditto with links between the swash and blade grips...
PLMS is offline Find More Posts by PLMS
Old Mar 17, 2013, 11:14 AM
Italy, Lazio, Rome
Joined Jun 2012
I don't own a v922 servo and i didn't try myself. But it is reported working from the HK site.
Originally Posted by donaldsnephew
Hi, easy to do - take a mCP x servo and put wires according to those. Eflite red = FBL100 red; Eflite brown = FBL100 black, Eflite orange = FBL 100 white. No soldering or crimping necessary; take a needle (or tiny screwdriver or...) and push on the metal part/lift the plastic part of the plug cap, pull the white and black plug out and press it in again on the other colours former position. You do not have to change the red wire plug, only change black (Eflite brown) and white (Eflite orange).
http://www.hobbyking.com/hobbyking/s...ear_Servo.html[/QUOTE]
For Sale Armattan Quads Price List and FAQ (Part 3) bobepine Aircraft - Electric - Multirotor (FS/W) 952 Mar 01, 2013 03:44 PM
Sold Blade mcpx v2 for trade, needs a few parts bergguy Aircraft - Electric - Helis (FS/W) 4 Jan 13, 2013 09:04 PM
Wanted Blade mcpx batteries and parts xdbrix Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 04, 2013 12:47 PM
A list of Compatible T-rex parts for X400? Blaze_au Mini Helis 75 Jan 16, 2006 02:38 PM
Question Anyone out there have a list of x400 to T-Rex parts compatibility? thewz Mini Helis 17 May 12, 2005 01:55 PM
