Old Jan 20, 2013, 03:49 AM
Cannafish is offline
Find More Posts by Cannafish
last of the sixties kids..
Cannafish's Avatar
New Zealand, Northland, Whangarei
Joined Jan 2013
how the hell do you solder that back on???
Having an absolute ball with my v911. Have made heaps of repairs, tried flying it without a flybar, fixed flybar, lost one weight , removed other weight and it was much better. Although my 'dodgy as you like' flybar repairs have left my v911 a vibrating, tbe thing of frustration. I have been overjoyed at the ability of the little bugger to just keep flying. However, we have now hit a stumbling block. The blue wire from main motor has become disconnected from pcb. I can barely see the bare wire I stripped with fingernails to find which miniscule blob of solder it connects to on PCB to make it work again.
How the hell do you guys solder these tiny wires????
Hopefully my 2nd hand Solo Pro will arrive tomorrow and I can fly that instead. I was really looking forward to comparing the two but alas.. Especially as the SP comes with a bunch of spares, inc flybars.
Cannafish is offline Find More Posts by Cannafish
Old Jan 20, 2013, 04:37 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
A small enough tip on the soldering iron, a microscope or magnifying glass (10x magnification should be enough) and a steady hand.
jkettu is offline Find More Posts by jkettu
Old Jan 20, 2013, 05:39 AM
R.sok is offline
Find More Posts by R.sok
Joined Dec 2012
A steady hand. I'm horrible at soldering But in the past 3 weeks I've soldered the tail motor & the blue motor wire. I just lay the heli on it's side, take a lighter to the tip of the tiny wire to expose a little wire, add some solder to the wire, then push the wire onto the board & push the solder iron on for a couple seconds
R.sok is offline Find More Posts by R.sok
Old Jan 20, 2013, 06:09 AM
Cannafish's Avatar
Joined Jan 2013
Cheers guys. I reckon I can come up with something along those lines.. More or less.
Old Jan 20, 2013, 11:28 AM
Arr0wHead is offline
Find More Posts by Arr0wHead
United States, MA, Plymouth
Joined Jan 2013
How does one make a connection with a pad?
I'm used to soldering wires to pots and switches that have lugs with little holes in them. I've always made sure to create a mechanical connection by hooking the wire through the hole and bending it before soldering, to help prevent cold joints.
What would be the equivalent of this when soldering to a solid pad?
Sorry to sound like a noob. Guess I am one in this case.
Arr0wHead is offline Find More Posts by Arr0wHead
Old Jan 20, 2013, 12:46 PM
jazzjohn is offline
Find More Posts by jazzjohn
Madison WI
Joined Jan 2009
Get a good strip on the wire that doesn't lose any of the strands. Groom the strands by twisting. Tin the wire by melting solder on it until it flows into the strands. While still molten, flick the excess solder off with the tip (flick down and not up into yourself!)
Apply a little solder on the pad. If you have flux, put some on the pad and optionally on the wire. (I assume this is a surface mount pad -one without a hole.)
Hold the wire in one hand, iron in the other and melt the pad and wire solder together. Remove the iron and hold the wire extremely still until the solder sets up. Don't press into the pad and be a quick as possible to avoid lift-off.
If it's not the "no-clean" flux variety, clean the flux off with a brush and alcohol.
jazzjohn is offline Find More Posts by jazzjohn
Old Jan 20, 2013, 01:53 PM
Joined Jan 2013
Thanks! Good tips.
Old Jan 20, 2013, 10:57 PM
Cannafish's Avatar
Joined Jan 2013
I am unable to solder this wire back on but a friend of mine assures me he can. So hopefully all is not lost :-)
Great tips - thanks. I think I am going to get a dedicated soldering iron for exactly these scenarios. Any recommendations?
Poll how many battery chargers do you own???? azflyingguy Electric Plane Talk 40 Feb 22, 2013 03:52 PM
Discussion Do you keep you Mixes on permanently ?? Witterings 3D Flying 22 Jan 22, 2013 05:37 AM
Discussion how do you tighten the slipper on the VMX 450? dropabomb Motorcycles 12 Jan 13, 2013 01:28 PM
Question How do you do a flat Spin? Great_Goose 3D Flying 10 Jan 13, 2013 11:25 AM
How Do You Solder on a Sermos Connector? AndrewK Beginner Training Area (Aircraft-Electric) 7 Nov 15, 2001 02:29 PM
