Thanks guys.
Its been suggested (on another forum) that I install a prop guard if I'm to use this as a rescue boat. I'm pretty sure most folks don't want me
chewing up their plane with my prop. I may add a guard although I'm actually thinking I'll use a floating frame rig (PVC piping with foam insulation) to do my rescuing. Something like this...
The idea being this is used only when needed, the rest of the time she's a regular airboat. The rig is made from PVC pipe & foam pipe insulation...
I'm thinking with that setup, I can probably get away without needing a prop guard, maybe *shrug*.
Back to the build
I'm learning, working with foam-board, its all about beveling...
Rough shape for the side...
Glued on, trimmed & yeap, more beveling...
These two blocks will be used to mount the motor pylon...
I chose a bolt-on system so that I can remove the motor pylon if it gets damaged or if I want to try something different on there...
A little plywood crash protection up front...
The deck...
Added some weight while the glue dries, the pillow helps evenly distribute the weight...
She's looking kinda boat-like...
7.5 oz (212 g) not sure if that's good or bad for a vessel this size. Feels pretty light to me but there's lots more to add before we're done...
That'll do for today, more tomorrow.
