Old Jan 19, 2013, 10:27 PM
dankx is offline
Find More Posts by dankx
Joined Jan 2013
Dynamite Passport Ultralite HELP!
After plugging my balancing board (right underneath the light button), then i plug in my battery....well i can go check my voltage and it will show my voltage but will NOT start the charge process or anything really except showing voltage.....After holding down enter for 3 seconds (the first step), it says problem with main server port..... So why?(everything is snug) Afterwards, i tried the adapter i got from my LHS that has every adapter imaginable, it has the big black connector type that is on my battery just the same as where i plug it into the car itself..... I used the banana plugs to plug into my charger, and then used that adapter and plugged my battery into it like i would if i plugged it in my car, that worked and allowed me to start a charge but wouldnt show voltage (my voltage led wont work just on the screen in a certain menu when it does....), also after started it a 5.0 amp speed, it started dropping fast and stayed at 2.0 then went down to 0.3 then stopped after like 40 mins -_-, why would it just drop from 5.0...then it acted like it was done when it was only at 2000 mAh (buzzer didnt go off) but it said end (was blinking..)
PLEASE HELP i wanna drive my slash !!!!!!! Im SOOO frustrated.
dankx is offline Find More Posts by dankx
Old Jan 26, 2013, 12:44 PM
Silentrun is offline
Find More Posts by Silentrun
Silentrun's Avatar
United States, TX, Plano
Joined Sep 2011
Don't believe you can charge and have the balancing board plugged in at once...so do one or the other independently.
Silentrun is offline Find More Posts by Silentrun
Discussion Dynamite Passport Ultra Hidden Menu fried onion Batteries and Chargers 12 Nov 18, 2015 01:37 PM
Discussion Passport LiPo 6S Charger by Dynamite flyer2004 Electric Plane Talk 5 May 29, 2010 07:30 AM
Mini-Review Dynamite Passport Ultra Review bladecpfreek Batteries and Chargers 1 May 21, 2010 09:57 AM
Discussion Dynamite RC Passport Ultra AC/DC Charger chickenwing Batteries and Chargers 3 Feb 24, 2010 09:55 PM
