Old Feb 05, 2013, 02:22 PM
dwayne loveday is offline
Find More Posts by dwayne loveday
United States, TN, Decatur
Joined Dec 2005
Maybe in a couple months they will come out with a (nano cpx bl) and have an even smaller brushless tail motor on it. Heh heh. 6mm?
dwayne loveday is offline Find More Posts by dwayne loveday
Old Feb 05, 2013, 11:04 PM
minimicrorc is online now
Find More Posts by minimicrorc
Joined Apr 2012
hope so
minimicrorc is online now Find More Posts by minimicrorc
Old Feb 08, 2013, 12:58 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
there was once a 6mm brushless motor, it was an amp hog from what i recall, maybe if done by Blade it could be higher quality.
derk is offline Find More Posts by derk
Old Mar 16, 2013, 12:41 AM
Dr Komet is online now
Find More Posts by Dr Komet
Dr Komet's Avatar
Joined Mar 2005
Hey Nitro, any progress on this neat little motor fan combo you are brewing up!
Dr Komet is online now Find More Posts by Dr Komet
Old Mar 16, 2013, 03:13 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I did try the UM gearbox setup for props along with Valiant at one stage.
I am back focusing on using it in a fan and have decided to try something I have wanted to try for a long time with micro EDF's... here's a little taste...
NitroCharged is offline Find More Posts by NitroCharged
Old Mar 16, 2013, 06:57 AM
forsakenrider is offline
Find More Posts by forsakenrider
Canada, BC, Grand Forks
Joined Aug 2008
belt drive?
forsakenrider is offline Find More Posts by forsakenrider
Old Mar 16, 2013, 07:57 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
That's the plan.
Old Mar 18, 2013, 09:27 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Originally Posted by NitroCharged View Post
That's the plan.
pretty.
would it need to be a toothed belt (if at all possible at that size) to minimise slippage at high RPM?
jim350 is offline Find More Posts by jim350
Old Mar 18, 2013, 11:21 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
The toothed belt would add to much resisstence and slow it down more then it would slip and trying to find one this size would be almost impossable. Thats my guess
I had this idea a year ago i have a picture of it in my attachments but i never di anything with it. This will help out alot with those 24mm and under fans
chester2240 is offline Find More Posts by chester2240
Old Mar 19, 2013, 04:47 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I think smooth will be fine for testing Jim.
Chester - I've had this idea for some years too. I also have delayed following it up until now .
So the concept is this(ready for print): We free up an extra 8.66mm˛ of fan area inside the case allowing for that little bit more thrust the motor and mount would otherwise block. I have several sized motor pulleys to find out what load the inrunner can take.
Old Mar 19, 2013, 06:14 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Um, NC? Not original research, so don't shoot the messenger, but my texts all recommend more using a hub less then 30% of the fan diameter, even for low pressure fans...
My concern would be the roots of the blades would be stalled (and potentially even in reverse flow) rather than adding anything.
But hey - if it works, you'll certainly have a unique jet!
Odysis is offline Find More Posts by Odysis
Old Mar 19, 2013, 03:51 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Ody, it's at 26.31% at the moment. If I increase the hub diameter by 0.7mm it will be at 30%. Worth doing you think?
Old Mar 19, 2013, 05:53 PM
Odysis is offline
Joined May 2007
Don't really know. I can't find any explanation apart from root stalling for why 30% is the "magic number". The trend of higher pressure - bigger hub is pretty rigid, and it sorta lends itself to the same idea of stalling.
Are you planning on this thing running to the ragged edge, or more of a cruiser? It might do really well until the roots stall, so a good indoor one, but no good at high power?
Old Mar 20, 2013, 01:23 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Cool design NC! Maybe you could use those tiny rubber bands from the orthodontist office to act as your pulley?
pdawg is online now Find More Posts by pdawg
Old Mar 20, 2013, 08:02 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Ody - I went for it and adjusted the parts so it's done and uploaded now.
Thanks pdawg. I plan to use o-ring's as they make for good belts on small projects.
If anyone else wants to join in on the experimenting - the parts are here: http://www.shapeways.com/model/98546...ductBox-search
You'll need:
1.5x4.0mm bearings, a 1.5mm shaft for the rotor and a brass end stop(scrounge a 5g HK outrunner for all the parts) and some o-rings.
New Product Blade mCPX BL.....yes that's Brushless! ChuckTseeker Micro Helis 5819 Jun 22, 2016 10:15 AM
For Sale BL Mcpx twin tail rotor Madbob9 Aircraft - Electric - Helis (FS/W) 0 Sep 07, 2012 08:48 AM
For Sale BL Mcpx twin tail rotor Madbob9 Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2012 04:26 PM
Sold mcpx tail rotor, boom, holder, blade RcHeli_Newb Aircraft - Electric - Helis (FS/W) 1 Dec 23, 2011 04:07 PM
For Sale WTT: Blade CP main rotor blades and tail rotor blades tb63 Aircraft - Electric - Helis (FS/W) 0 Sep 03, 2008 09:26 AM
