Old Jan 24, 2013, 12:26 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Micro F-14
chester2240 is offline Find More Posts by chester2240
Old Jan 24, 2013, 09:16 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
I want this babby in my little Spit !!!
brushless55 is offline Find More Posts by brushless55
Old Jan 25, 2013, 11:29 AM
forsakenrider is offline
Find More Posts by forsakenrider
Canada, BC, Grand Forks
Joined Aug 2008
this is so great!!! I cant wait to see where these little fans will go now!!!!
forsakenrider is offline Find More Posts by forsakenrider
Old Jan 26, 2013, 10:40 AM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
How about on the ASK-21...
Mendo
Mendo is offline Find More Posts by Mendo
Old Jan 26, 2013, 02:01 PM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Originally Posted by mendo View Post
how about on the ask-21...
Mendo
yesssssssss!!!!!!!!!!!!!!
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Jan 26, 2013, 02:43 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
when i first saw that heli, this is exactly what i wondered about. it would be interesting to see if these would work in the um gear drives.
oh man, now i am thinking about an even smaller pylon plane! thanks Nitro!
derk is offline Find More Posts by derk
Old Jan 26, 2013, 06:04 PM
Joined Jul 2011
So do you plan on using 2cell or 3cell since the kv is low?
Old Jan 26, 2013, 06:41 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
This is the grey area Chester... we'll have to find out what sort of load it can handle. If going 3S I would start thinking about installing bearings - much like back in the day with the 2g outrunner that ran on bushings.
I guess it's down to application in the end. A 2S with plenty of grunt(for it's size) so heavy paddles and more of them for slower flight or 3S, 3 blades, with high efflux for zipping around.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 26, 2013, 08:50 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I was about to say---This motor would be DA BOMB in 1S micro warbirds such as the Spitty....I have a TON of ESC's rated for 1-2S!!!..Do a mix on the RX an VIOLA---TONS of power on 1S!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jan 26, 2013, 09:08 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Kevin,
I lost track of where the AS3X mixing is explained - can you point me there, please?
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jan 26, 2013, 09:16 PM
Joined Mar 2007
Originally Posted by speedy01 View Post
Kevin,
Gene K
There is an Aux channel on the AS3X RX's---Channel 5...This port also allows you to program the AS3X RX for the plane you choose---Sbach, Beast---Whatever...Use the manual to go back and forth between programming and using this aux channel for an extra channel...Mix the aux channel to the throttle and you can run an external ESC for up to 4S power!!!...I have used the aux channel to run external ESC's for 3S power in my Beasts...The same can be done here...This is an abreviated explanation...Just go to the RX manual and it will explain how to program the RX using a special cable and mixing the 5th channel for whatever you desire...
Kevin
Old Jan 26, 2013, 09:37 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Thanks!
Gene K
Old Jan 27, 2013, 12:38 AM
big ignore list
Joined Nov 2011
Kevin
Hook it up bro!!
I'm about to sell my Spit then I saw this thread
Old Jan 30, 2013, 06:48 AM
valiantGLX is online now
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
New BLH3904 BL UM gearbox conversion thread
valiantGLX is online now Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 31, 2013, 03:52 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
That's great news and all. But lets not get too side tracked. What will this do on 1s with say a GWS 30mm or a sanded down to 25mm rotor in a B.I.M. case. Nitro you posted this on one s right, and it seems to make good thrust in the standard UM gear box, what do the numbers look like in one of our fans? I know you don't have any thing else to do, like family, job or life right? Just kidding thanks for all your hard work.
MUTCAKE is offline Find More Posts by MUTCAKE
New Product Blade mCPX BL.....yes that's Brushless! ChuckTseeker Micro Helis 5654 Dec 31, 2015 05:06 PM
For Sale BL Mcpx twin tail rotor Madbob9 Aircraft - Electric - Helis (FS/W) 0 Sep 07, 2012 09:48 AM
For Sale BL Mcpx twin tail rotor Madbob9 Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2012 05:26 PM
Sold mcpx tail rotor, boom, holder, blade RcHeli_Newb Aircraft - Electric - Helis (FS/W) 1 Dec 23, 2011 05:07 PM
For Sale WTT: Blade CP main rotor blades and tail rotor blades tb63 Aircraft - Electric - Helis (FS/W) 0 Sep 03, 2008 10:26 AM
