Old Jan 19, 2013, 05:40 PM
californiakid is offline
Find More Posts by californiakid
mahoganyfan
californiakid's Avatar
United States, NJ, Atlantic City
Joined Nov 2010
Fast Mahogany Boat
r/c boat (1 min 50 sec)
Legend Model Boat
californiakid is offline Find More Posts by californiakid
Old Jan 19, 2013, 11:22 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Sounds and looks like your driving with a straight shaft submerged prop? Are you using a surface prop; the way it rides can be tweaked with the right prop so you can run full throttle without fear of flipping.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Jan 20, 2013, 02:59 PM
mahoganyfan
Joined Nov 2010
Amp abuser
Yes it is a submerged prop ,straight shaft with a 637 x Octura prop.
Old Jan 20, 2013, 06:29 PM
Amp Abuser's Avatar
Joined Dec 2007
Here is the Octura prop chart, there are some dedicated submerged running props that may improve the ride at full throttle. The X series props are all shaped to perform on the surface; they do lift quite a bit when you have plenty motah.
Old Jan 21, 2013, 07:04 PM
mahoganyfan
Joined Nov 2010
Octura Chart
Thanks Amp Abuser,I might try a different prop now.
Old Jan 22, 2013, 02:26 PM
zozer is offline
Find More Posts by zozer
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
The boat runs very well for what it is - a scale model. Overpowered like it is, it will hop and skip regardless of the prop used. The Octura X props are about the lowest lift props Octura makes. When running fully submerged, a prop's lifting characteristics don't matter anyway since the thrust cone is surrounded by water. Only when run in surfacing conditions will a prop lift - because the top of the thrust cone is not contributing to forward movement.
Slowing the boat down a bit will keep it on the water unless you want to completely re-do the drive system to a parallel surfacing drive. Racers running Crackerbox boats - similar in hull form - have done this to reduce any hopping. But that just doesn't seem right on a nice scale boat like this one.....
zozer is offline Find More Posts by zozer
Old Jan 23, 2013, 01:39 AM
Amp Abuser's Avatar
Joined Dec 2007
Octura submerged prop vs X series prop.
Old Jan 23, 2013, 06:11 PM
mahoganyfan
Joined Nov 2010
x series prop
Thanks again Amp Abuser,maybe I should try a different prop or maybe blueprinting the bottom of hull to get any waves or gullies out of it.I was told by a friend the boat might run better then.
Old Jan 23, 2013, 09:18 PM
zozer is offline
Steps? What steps?
zozer's Avatar
Joined Jan 2010
Sadly, those props will cavitate badly at the rpm the OP will be using, they are low pitch/low rpm props. As stated above, prop 'lift' means nothing with a fully submerged prop anyway.
Hey, what do I know, I've just been designing and racing (and winning) FE boats for thirty years. BTW the information I posted came from my friend Tom, the owner and designer of Octura props.
Old Feb 05, 2013, 05:54 PM
mahoganyfan
Joined Nov 2010
Advice
Thanks Zozer for advice.
Old Feb 07, 2013, 09:35 PM
hoffy1980 is offline
Find More Posts by hoffy1980
Hoffy1980
United States, IL, Maroa
Joined Jan 2013
zozer, what would a good drive and motor for a 20 in. deep vee be? you are saying underwater prop is bad? if so would I need a shaft going out the back at the bottom? Thanks for any help. I wouldnt mind playing around and finding what I though was best for me but its a little costly. I was wanting to run 2s batterys. just need some idea on motor prop and size of running gear. I will buy most of my stuff from china on first boat . If it goes well will buy better stuff for a bigger one.
hoffy1980 is offline Find More Posts by hoffy1980
Sold All Mahogany scratch built race boat hampboats Boats (FS/W) 3 May 30, 2012 08:07 AM
Gallery Unfinished Classic Mahogany Boat Aydemir Scale Boats 14 Mar 02, 2012 02:00 PM
Question Mahogany Boat--Last Epoxy Coat/Finish Coat cicerokid Scale Boats 7 Feb 04, 2012 08:07 AM
For Sale Awesome hand made mahogany boats WAK Boats (FS/W) 0 Apr 27, 2009 02:31 PM
Fast billed Fast boat #2 installer5200 Foamies (Kits) 2 Sep 29, 2005 07:47 AM
