Old Jan 19, 2013, 03:40 PM
ArltTech is offline
Find More Posts by ArltTech
USA, WA
Joined Jan 2011
Simon K rapid drive compatibility
Has anyone tried out Simon K rapid drive firmware on esc's (like e rc) with a HoverFly Sport board? It has been awhile since on the discussion group so haven't searched all over. I have flashed the Sport board successfully several times in X mode with the AP firmware version, however when I try to get into the Setup utility I get an error message that the setup does not accept the firmware version? Have tried several times. I have reloaded the setup and update clients on the computer. I don't see any usb or dip switches on the sport board like on the Pro that I have (the good old green from the early days).
I may be missing something simple, any input appreciated.
ArltTech is offline Find More Posts by ArltTech
Old Jan 24, 2013, 11:41 PM
ArltTech is offline
USA, WA
Joined Jan 2011
George, HoverFly, anyone!
Old Jan 25, 2013, 05:29 AM
ross_badger is offline
Find More Posts by ross_badger
SuperX Hex and X8 Flyer
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
You may want to try the Multirotor Forums....
www.multirotorforums.com
If you are referring to issues with SimonK flashed ESCs used with HoverFly boards, I've experienced problems with them as well. Evidently, the output signal from the board to the receiver may be too low for the flashed ESCs to use, so they don't respond well. I've solved the issue using a signal booster line from the board to each ESC that I purchased here: http://www.dpcav.com/xcart/Servo-Sig...oster-Amp.html
Thanks, Ross
ross_badger is offline Find More Posts by ross_badger
Old Jan 25, 2013, 10:48 PM
ArltTech is offline
USA, WA
Joined Jan 2011
Thanks Ross for the input, I will check on the other forums as suggested.
Old Feb 26, 2013, 11:14 AM
hoverben is offline
Find More Posts by hoverben
Hoverfly Technologies
hoverben's Avatar
United States, FL, Winter Springs
Joined Nov 2011
To answer your concern regarding the HoverflySPORT Setup Client, please see this article on our website.
We don't have an official recommendation on the SimonK ESCs since we don't use them ourselves, but Ross's information is correct. If SimonK is your ESC of choice, you will need a signal booster between each ESC and the Hoverfly flight controller.
hoverben is offline Find More Posts by hoverben
Sold HK Blue 30A Simon K Flashed ESC x 4 dasrustler Aircraft - Electric - Multirotor (FS/W) 3 Jan 16, 2013 10:15 AM
For Sale simon k firmware flashed 20a esc's $60 obo TheOne420 Aircraft - Electric - Multirotor (FS/W) 9 Jul 24, 2012 01:57 PM
For Sale Spider quad / FlyingRobot-550 folding frame plus extras/ lot of esc's even simon k TheOne420 Aircraft - Electric - Multirotor (FS/W) 3 Jul 13, 2012 11:45 AM
Sold 4x 12 amp esc's with simon K firmware. updated!!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jun 17, 2012 11:01 AM
For Sale 4 pcs hobbyking F-20 with Simon k firmware rukie Aircraft - Electric - Multirotor (FS/W) 1 Mar 30, 2012 08:13 PM
