Old Jan 19, 2013, 02:00 PM
kadil is offline
Find More Posts by kadil
unconventional :-)
kadil's Avatar
Brisbane north, Australia
Joined Feb 2009
Question
coaxial propellers
I have an idea for a model and could easily arrange a couple of coaxial propellers. I was thinking a 5x3 in front of a 5x5 on a single shaft, or 2 motor counter rotating. Would this multi stage approach give good thrust characteristics for a smallish prop length?
kadil is offline Find More Posts by kadil
Old Jan 20, 2013, 05:01 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Do you mean something like these -
Contra Rotating BL System 375W
and -
CR23L Contra Rotating BL System 1100kv
I have never tried it, but could imagine the two props would need to be carefully selected and flight tested to get the best out of such a system.
eflightray is offline Find More Posts by eflightray
Old Jan 20, 2013, 05:16 AM
kadil is offline
unconventional :-)
kadil's Avatar
Joined Feb 2009
Looks interesting, I was going to point one motor forwards and one back. I was told that using too high a pitch too fast just has a mixing effect on the air instead of thrust. So I thought that having a lower pitch prop in front could speed up the air a bit before it hits the high pitch prop.
Old Jan 20, 2013, 08:22 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You mean more like the Cessna Skymaster, or Dornier Do 335, with an engine at the front and one at the rear ?
There is also the Dornier Do 18, and the more up to date Dornier Seamaster with a push-pull twin engine arrangement in a single nacelle.
Whatever type you decide on, from a model point of view I would recommend searching for what other modelers have used in a similar cofiguration, and how successful it may have been. The eventual proof will most likely be how the model eventually flies.
Sorry I can't recommend which way to go regarding props and pitches, but I'm fairly sure someone will have already done what you are thinking of. Always easier to pick someone else's brain, (design), that has had success.
Old Jan 20, 2013, 11:53 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Some twin experiments....
5motor-2CameraFlights (11 min 51 sec)
And...
These done to test rudder authority. The rudder ran out of authority at about 40% power on the running motor.
The inline push-pull thingy only resulted in amusing videos of the props running. The airplane was a miserable failure.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 21, 2013, 03:19 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
In such a case, the rear propeller needs a little less diameter and a little more pitch. See attached image for clarification.
Julez is offline Find More Posts by Julez
Old Jan 21, 2013, 05:52 PM
kadil is offline
unconventional :-)
kadil's Avatar
Joined Feb 2009
Exactly what I was thinking.
Old Jan 22, 2013, 03:03 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
http://www.luft46.com/db/dbjager.html
One of these is being built somewhere on here.E warplanes maybe.
Stuart A is offline Find More Posts by Stuart A
Question laminated vintage propeller kits CurtissP40 Scale Kit/Scratch Built 25 Jan 26, 2013 12:24 PM
Discussion I'd like to go ahead and join the club .. Propel Sky Spy / Syma S107C danpass Coaxial Helicopters 0 Jan 17, 2013 04:06 PM
Sold 5 APC 14" composite 3D propellers modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 17, 2013 11:43 AM
propellers,propellers and more propellers zicmu Modeling Science 5 Jan 16, 2004 08:12 PM
