Espritmodel.com Heli Air
Old Jan 19, 2013, 01:38 PM
United Kingdom, England, Cambridge
Joined Aug 2012
Graupner Propellor Stuck! Help
Test fitted my Graupner 10" on 2216 Tiger Motor, which came with a Graupner adapter to fit properly.
I have pushed the prop onto the shaft with adapter which was tight, and figured I need to trim down about 1-2mm of the adapter because it is taller than the prop.
I now cannot remove the prop from the shaft! It was very hard to to get on, and seems impossible to remove. I have soaked in wd-40, with no avail.
Advise please!
Jmm_jammy is offline Find More Posts by Jmm_jammy
Old Jan 19, 2013, 01:42 PM
Russian Federation, MO, Podolsk
Joined Dec 2010
Spin your prop and it will come out!
rinatka7 is offline Find More Posts by rinatka7
Old Jan 19, 2013, 06:59 PM
Mortimer's Avatar
Joined Apr 2010
Is this a genuine Graupner adapter ?
They're made in aluminium, they're white.
Their lenght is correct, there is no need to trim them.
Did you use Loctite ?
Mortimer is offline Find More Posts by Mortimer
Old Jan 20, 2013, 01:00 AM
Perth Australia
Joined Feb 2010
block of wood with hole to suit adapter . press it out in a vice .
swervo is offline Find More Posts by swervo
Old Jan 20, 2013, 01:10 AM
Joined Dec 2010
I have exactly the same adapter, i bought it from http://www.electricwingman.com/ so..i think it is genuine adapter.
Old Jan 20, 2013, 09:14 AM
Mortimer's Avatar
Joined Apr 2010
It rather seems to be a Czech substitute for Graupner adapter with apparently approximative dimensions.
http://www.electricwingman.com/graup...r/8mm/6mm.aspx :
These bore size reducers are designed for Graupner CAM propellers, allowing them to be fitted to various shaft sizes whilst maintaining accurate centering. They are also suitable for Graupner Elektro propellers and many other propellers with 8mm bore.
Made in Czech Republic.
Discussion Maximum thrust possible propellor gathem Power Systems 28 Feb 13, 2013 07:20 AM
Discussion really stuck please help flight Controller? taffy047 Multirotor Electronics 3 Jan 07, 2013 11:16 AM
Discussion Champ controller stuck? OhNoMrBill Parkflyers 1 Jan 03, 2013 10:41 AM
Discussion Graupner Propellors suck (amps)! Connexxion Multirotor Talk 9 Nov 09, 2011 11:05 AM
Discussion Graupner spinner stuck on mumblety-peg High Performance 11 Dec 23, 2009 10:28 PM
