Old Jan 19, 2013, 09:48 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
On-board Starter for DLE 30
Setting up a Midwest Texan with DLE 30. Since it is going to need a bit of weight up front anyway I would like add an on-board starter. I poke around an don't see any kits.
The gears should be not much of an issue as I have lots of different ones lying around an access to lathe and milling machine to adapt and make mounting plates etc.
The question is how am I going to accomplish the one-way drive? Does somebody sell just the one-way bearings I have seen described? Is there an easy way to throw the gear in with a solenoid? Dose anybody sell just a small starter motor with bendix, I could make the rest of it.
davidmc36 is offline Find More Posts by davidmc36
Old Jan 19, 2013, 02:39 PM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
there is a guy in the UK i believe that sells a kit for the dle55, might fit or be adaptable.
anyways, he just uses a one way torrington bearing. any good bearing shop should have a decent selection. boca bearing should as well.
ZAGNUT is offline Find More Posts by ZAGNUT
Discussion comercial source for onboard starter to fit DLE/DA/MD engines Big Nuts 181 Giant Scale Airplanes 4 Jan 20, 2013 11:48 PM
Found Need a DLE 30 stock muffler miller6196 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 16, 2013 11:54 PM
Question DLE 30 what for this fuel Tank for on DLE 30 Johnsmith122 Engines 5 Jan 09, 2013 02:18 PM
Sold New dle 30 john howard Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 02, 2013 09:52 PM
Question Elec hand starter for DLE 30? JBAZ4 Engines 5 Apr 19, 2011 09:15 AM
