Old Jan 19, 2013, 07:19 AM
pspring is offline
Find More Posts by pspring
United States, MN, Andover
Joined Sep 2012
Question
Berkeley 1/2A Piper Super Cub
I found this old kit at a surplus shop for $7 with a plan date of 1955. (I can't pass up a cheap kit! lol) It shows .049 for power and control line flying or rubber power free flight. I couldn't find any info at RC Groups (but I could have missed it). Anyone have any leads or experience converting this plane to R/C or have advice? Thanks!
pspring is offline Find More Posts by pspring
Old Jan 19, 2013, 10:12 AM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
I've not had that particular Berkeley kit, but based on the several I have had, I'd guess that you'll have no problem converting it. However, the wood is probably junk. They didn't use good wood in the first place, and it's certainly not gotten any better with age! Scan the die cut sheets on a color (yes, color!) copier. The color copy will give very crisp results. Use the scans as patterns to cut parts from new balsa. You can get 1/20" thickness wood, which Berkeley kits used a lot, from such places as Lone Star Balsa http://lonestar-balsa.com/ and Specialized Balsa http://www.specializedbalsa.com/
Berkeley kits are designed robustly, so don't expect a light finished model. Be sensible on wood selection, and it'll have reasonable weight and fly well.
Check the scale electric forum and you'll find some Berkeley r/c conversions.
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Jan 19, 2013, 10:35 AM
pspring is offline
Joined Sep 2012
I never thought of wood getting old. Something worth researching. Thanks for the tip. I thought the kit wood was kinda "rustic" looking. I like your idea of scanning the die cut sheets. Balsa sheets are cheap compared to buying a whole kit. The box says the palen weighs 4 1/5 Oz. That seems pretty light. I suppose once a 3 Oz engine and R/C is added it will be a bit more. My only concern is that since it's designed for free flight or C/L that adding R/C equipment may be too heavy for the design. I fly pretty mild so maybe it will be OK since the design is "robust:. Thanks.
Old Jan 19, 2013, 05:49 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Use the tiny Spektrum Rx and servos, and trade wood for carbon fiber wherever it makes sense, and you can make it light. IIRC, it has a 36" span, and much smaller models have been converted and flown well. Here's a Berkeley Aeronca Sedan, from the same kit series, done with electric power: http://www.rcgroups.com/forums/showt...sedan+berkeley
Old Feb 10, 2013, 10:36 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Hey Geoff, That's my Aeronca Sedan, still flyable. Build it as light as you can, reduce wing incidence for RC vs free-flight.Incorporate wing tip washout. Model Aeroncas have tip stalling tendecies. Don't fly tail heavy. Use light covering like Microlite, etc. for best flyability. Beef up landing gear mounting, keep rear fuselage as light as possible to avoid need for excess nose ballast. I used a 3S 800mah battery pack with Esskay 400XT outrunner and 7x4 GWS DD prop. You could use a lighter motor with a light weight model.
E-Challenged is offline Find More Posts by E-Challenged
Old Feb 10, 2013, 10:39 AM
Joined Oct 2000
Hey Geoff, That's my Aeronca Sedan, still flyable. Build Cub as light as you can, reduce wing incidence for RC vs free-flight.Incorporate wing tip washout.. Don't fly tail heavy. Use light covering like Microlite, etc. for best flyability. Beef up landing gear mounting, keep rear fuselage as light as possible to avoid need for excess nose ballast.Should fly on Tee Dee .020 power, you may need to locate battery pack and RC gear forward if using lighter 1/4A glow power. Use PET G clear plastic for windshield and side windows, does not craze and crack. Keep raw 1/2A fuel off of windshield,etc., will turn milky.
I used a 3S 800mah battery pack with Esskay 400XT outrunner and 7x4 GWS DD prop for my Aeronca, overkill!
Old Feb 10, 2013, 10:46 AM
Joined Oct 2000
Oops, duplicate reply!
Old Feb 14, 2013, 04:29 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Yeah, E-C, I guess you wanted to make sure we got it!
Any progress, pspring?
Old Feb 27, 2013, 10:18 AM
Joined Oct 2000
Like a lot of us, the spirit is willing but.....starting and finishing ........
Old Mar 03, 2013, 08:54 AM
pspring is offline
Joined Sep 2012
Sorry for late reply. I was not subscribed. E-C you are right! My spirit says "Lets build!". But alas, no progress... Too busy keeping 4 cars running and spinning the plates of life that come with a family and a job. The other detriment is being spoiled by being brought up on a farm where I could walk to my flying sites. Which were an alfalfa field, used for landing gliders and test flying, a tar road with no traffic for my Kadet Jr, and a cow pasture for flying control line (cows kept the grass mowed near the dirt). Didn't know about AMA rules till just lately after getting back into the hobby so now I need to join a club since I live in suburbia and can damage others property.
I don't know about you guys, but what helps me get fired up is this website. Seeing builds and chatting with hobby type people, which are not very common in the general public. I will definitely post a build log to share once I get going. Maybe this summer.
Old Mar 03, 2013, 10:43 AM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
I have no problem with the starting part, it's just the finishing part! At least 5 or 6 started and 3 or 4 in some need of repair with plans of starting another one.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Mar 03, 2013, 04:35 PM
pspring is offline
Joined Sep 2012
John
LOL Same problem here. Maybe finishing projects doesn't matter as long as we're having fun flitting from project to project and dreaming about the next!?
Old Mar 04, 2013, 07:04 PM
pulserudder is offline
Find More Posts by pulserudder
I like thermals
United States, SC, Charleston
Joined Feb 2013
I've been following this thread and could not resist a reply: count me in as another member of the "I start more than I finish" model building club.
I eventually get around to finishing a lot of them....eventually......
pulserudder is offline Find More Posts by pulserudder
Old Mar 11, 2013, 01:54 PM
Joined Oct 2000
pspring,
Yeah, join AMA and a club, on balance, it's worth it. You'll find few actual builders in clubs nowadays but lots of foamie-of-the-month buyer/fliers. Hey, there's a marketing idea for Hobby King.
Old Mar 12, 2013, 12:51 PM
pspring is offline
Joined Sep 2012
Yep I gotta get off my but and join a club, and get AMAinized too. But in reverse order.
Help! Hangar 9 1/4 Scale Piper Cub Tampatexan Scale Fuel Planes 3 Jan 26, 2013 09:47 AM
Sold 1/4 Scale Hanger 9 Piper Cub $400 FIRM mudman1959 Aircraft - Fuel - Airplanes (FS/W) 10 Jan 09, 2013 10:56 AM
Herr 1/2A Piper J-3 Cub (My love for the Cub) genovia Parkflyers 30 Jun 10, 2002 09:18 AM
Herr 1/2A Piper Cub in need of assistance genovia Electric Plane Talk 21 Jun 08, 2002 03:34 AM
Article The Herr Piper J3 Cub and the Hobby Hangar 1/2A Super Cub Robert Buonfiglio Electric Plane Talk 0 Mar 09, 2000 12:00 AM
