Norfolk, England
Joined Sep 2001
I think I have it more or less sorted out now. Currently the plan shows an AEO 7 mm geared unit, but if the weight looks good, I may yet be tempted to go with the 2 gram brushless which will allow more flexibility with battery position.
Here's what I have drawn up and if it looks as if I might be able to get it down to 30 grams (highly unlikely knowing me) the brushless option might work out quite well, despite that the gear will be a little heavier. The small prop isn't really too much of an issue because there's only clearance for a 4" prop anyway. IIRC the 2 gram brushless uses a 3" prop which won't be too far off. I'm figuring that a thrust of half the model weight should be ample for the way it's supposed to fly. Anyway, have a look, see what you think and make any comments you think may help. Feel free to avail yourself of the plan if you like. Pete |
Canada
Joined Nov 2000
Why the assumption that a wee brushless needs 2s?
The Hobby King 2 grammer at 7700 kv is a 1S wind. Although a bit of wire / fiddling and most any outrunner can be diy rewound to suit precise needs Albeit a 2gm outrunner seems a bit miniscule for anything beyond oddity value imo. 4/5 gram motor is too heavy? In the very least an outrunner would be quite silent.. not a small bonus 1s brushless esc's are both tiny and inexpensive, being basically a single chip gizmo and these connect signal wires to any Rx, in the usual esc fashion, brushless or brushed. immediate example: http://www.hobbyking.com/hobbyking/s..._ESC_3_5A.html |
Norfolk, England
Joined Sep 2001
Bare,
Yes, I know the 2 gram brushless is wound for 1S and no, a 5 gram motor isn't too heavy. As regards re-winding motors, I have less than no interest in that sort of thing. My main reason for trying to avoid going brushless was simply that it would require separate receiver, ESC and servos, rather than the compact neatness of the Vapor brick. As you can see, space is at something of a premium. The PZ brushless brick would help but I don't have a transmitter that will do the mixing to make the rudder servo operate on the 'aileron' stick - primary steering function on the right stick. All things taken into account, I'm happy enough with the way it looks. Yes, an in-line geared or direct drive motor would have been neater, but I can live with it as is. Just need to sort out some parts sheets, print a plan and get building. Pete |
| Thread Tools | |
| Question What is the best way to reel in winch line? | rdwoebke | Sailplane Talk | 48 | Feb 25, 2013 01:33 PM |
| Off Site Model Motors AXI 2814/12 GOLD LINE Brushless Motor | PittSpecial | Aircraft - Electric - Power Systems (FS/W) | 1 | Jan 22, 2013 05:54 PM |
| Off Site Model Motors AXI 2814/12 GOLD LINE Brushless Motor | PittSpecial | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 16, 2013 07:19 PM |
| Off Site Model Motors AXI 2814/12 GOLD LINE Brushless Motor | PittSpecial | Aircraft - Electric - Power Systems (FS/W) | 1 | Jan 16, 2013 06:00 PM |
| Off Site Model Motors AXI2814/12 GOLD LINE Brushless Motor | PittSpecial | Aircraft - Electric - Power Systems (FS/W) | 4 | Jan 16, 2013 05:58 PM |
