Old Jan 19, 2013, 04:15 AM
Lenny7118 is offline
Find More Posts by Lenny7118
Joined Mar 2011
Question
DJI F450 Build Questions ( T motors, Lipo's , Props )
I need to know what size the bullet connects are on my Tiger T MT-2212-13 980kv motors and what gauge are the wires ? ( it doesn't have it listed on the box or wire )
Will 3S 5000mah lipo's be ok to use on the DJI F450 ?
Also I bought 10" GRAUPNER E-Props , should I also get 8" props ?
Lenny7118 is offline Find More Posts by Lenny7118
Old Jan 19, 2013, 04:35 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
The bullets are most likely 3.5mm bullets, you'll find this size on most motors. Wire gauge... Probably 16awg or so, a very common size.
It'll fly with that battery, but it will be very sluggish. If you're going to use a very large battery, then it's better to pick a slightly smaller 4S lipo instead. It's OK to use 10" props on 4S as long as you stick to Graupner props. I personally think that 9" props is a great compromise if you want to use 4S. The motors won't run hot and you'll get a bit more lift than what you'd get from 8" props.
WiseDuck is offline Find More Posts by WiseDuck
Old Jan 19, 2013, 04:46 AM
Joined Mar 2011
So I should get a 3S in what mah and 4S in what mah ?
Also 9" props is a good compromise when using either a 3 or 4 cell lipo ?
I'm new to this so I won't be doing any crazy flying but do want quality in my parts.
Old Jan 19, 2013, 04:56 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
That's up to you. Stick to 10" props when you use 3S.
Now, I've only used a 4000mah battery with the stock F450 DJI motors and it hovered for 18 minutes with the stock 10" props. But it felt sluggish. It flew, but I don't think it's usable with a big payload such as a gimbal + camera. GoPro? Not a problem. Do you really need 5000mah though? Depends on what you want to carry I suppose.
4S is more efficient, you'll most likely get longer runtimes and you can carry a LOT more. You'd probably be fine with say... a 3300 to 4000mah 4S lipo. Now, I have limited experience with such large batteries, so you'll have to wait for better replies or experiment a little. I would use 9" on 4S, but that's just me. 10" is usable too, the motors might run warm but I doubt they'll get hot.
EDIT: If this is your first multi you could just get a couple of cheapo 2200mah 3S Turnigy lipos to learn on. Also, don't learn on Graupner props, they can not take a direct hit well, they'll simply break apart when you hit something. Stick to ABS/nylon props until you're comfortable with your multi.
Old Jan 19, 2013, 05:05 AM
Joined Mar 2011
Thanks for your imput. I have 2 brand new 3S 5000mah lipo's never used from when I had my RC cars that's why I was asking about the use of them.
I'll only be using a GoPro camera no gimbal for awhile.
Thanks again.
Old Jan 19, 2013, 05:21 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
In that case, just use those. They should work.
Old Jan 19, 2013, 08:03 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
I have this exact setup, stock DJI with 9" Graupners e-props, its quite agile, stable, and with a 4S-2800mAh I get from 11 minutes (payload GoPro + some light FPV gear, tot. weight 1500g) to 14 minutes. (quad alone, no payload, 1100g).
It's also working fine with 8" Graupners. with these the motors are dead cold, and barely warm with 9", so I'd guess the 10" graupners are ok too, these props are pulling noticably less than the DJI 10".
You can see how it flies here with 9".
Olivier_C is online now Find More Posts by Olivier_C
Old Jan 19, 2013, 08:40 AM
JGrn is offline
Find More Posts by JGrn
Joined Feb 2012
Im using 900kv t-motors, 4s 3300 hyperson batteries, and 9" graupner props. It's a beast
JGrn is offline Find More Posts by JGrn
Build Log DJI F450 build questions Lenny7118 Multirotor Talk 3 Jan 13, 2013 12:20 AM
Sold DJI F450 w/Frame, Motors, ESC, and Props Kahuna717 Aircraft - Electric - Multirotor (FS/W) 0 Nov 13, 2012 10:44 PM
Discussion DJI Naza + F450 won't fly with stock 10 props... ale.pac Multirotor Talk 16 Aug 20, 2012 04:19 AM
Discussion DJI F450 & F550 Motor Extension Plates - larger props Photoship One Multirotor Talk 6 Jun 23, 2012 12:58 PM
Sold DJI F450 Frame with Motors and Esc's ROCKY2 Aircraft - Electric - Multirotor (FS/W) 1 Feb 26, 2012 11:20 PM
