Old Jul 17, 2006, 06:01 PM
Younjin Soul is offline
Find More Posts by Younjin Soul
Joined Jul 2006
thanks
Originally Posted by whanderson
Do you do SMT parts, 2 layers, plated through holes, and solder plate? I f so you will get my next order.
wqwqq
Younjin Soul is offline Find More Posts by Younjin Soul
Old Feb 11, 2008, 05:40 AM
panteraivan
A moderator felt this post violated the following rule: Offensive content (Flatulence). It is temporarily hidden while panteraivan edits it.
Old Feb 11, 2008, 05:41 AM
panteraivan
Old Feb 11, 2008, 05:57 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Reported the three posts above to the authorities.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Apr 28, 2008, 04:17 PM
epkoncept is offline
Find More Posts by epkoncept
San Diego Lindberg, California, United States
Joined Jan 2002
best prices for FET's ?
DIY's:
What the less expensive place to order the FET's in the USA ?
For example I am looking for some Vishay/ Siliconix 4368, may be a tube of 50 pieces ? Or even a similar IRF part, any and all suggestions greatly appreciated.
thanks in advance
EP
epkoncept is offline Find More Posts by epkoncept
Old Nov 16, 2011, 06:42 AM
hadihf is offline
Find More Posts by hadihf
Joined Dec 2003
1n1p software
Hi,
I made a 1n1p regler from Svens Bastelstube design. I programmed the controller with 1n1p.hex...but when I power it with rx connected, it gives just a single beep and hothing happens when throttle is advanced. Can anybody help? Also is there any more versitile software available for this controller?
Well figured it out myself..Also found Fabian Fessler's soft here..
http://wladislaw-sl.narod.ru/blmc-sl/blmc-sl.html
Regards
hadihf
hadihf is offline Find More Posts by hadihf
Old Jul 13, 2012, 10:37 PM
anam_funny is offline
Find More Posts by anam_funny
India, Delhi, New Delhi
Joined Jan 2010
Originally Posted by hadihf View Post
Hi,
Regards
hadihf
A late reply. But I want to know that did you get it to work with an RC Controller? I cannot understand a small part which is given in the PCB design. What exactly is it? How did you program the chip?
anam_funny is offline Find More Posts by anam_funny
Old Oct 16, 2012, 06:39 AM
snakescb is offline
Find More Posts by snakescb
Joined Oct 2012
Just another scilab firmware
Dear all,
I am very new to this forum. I am an elecrical engineer and rc heli enthusiast from Switzerland. I also started developing my own firmware for the plush esc's using the scilab controllers. I did it basically just for fun. I used the blheli code as a startup for having an idea how things could be done, and then wrote my own firmware from scratch. Most things are quite different than in the blheli approach, however, whitout it I think I would have been lost completely.
My approach is much simpler than the blheli code, since it is supposed to work with multirotors only from a standard receiver signal up to 400Hz. Actually I am flying with my own code in a small quadrotor, and the performance increased significantly compared to the standard plush 12 esc. I am flying with 1450kv motors that draw about 15 amps at full throttle. After heavy acrobatic flights, motor and esc are not really warm. This tells me, that in normal run mode, the motor is controlled correctly as it should. This was the main goal of my project.
My firmware has just included the most important things needed by a quadrotor:
- Ajustable throttle off and full throttle rc signal
- Ajustable timing, 0 deg, 7.5 deg, 15 deg and 22.5 deg
- Direction of rotation reverse
These are the functions which are most important for me for multirotors. All options are stick programmed. No battery voltage measurement or over temperature protection are included yet.
As i mentioned, I am already flying with my own implementation, absolutely no problems there. The only problem I have is (as many others) the motor startup. Currently the motors start spinning quite reliable using a long settle time and then an accelerating open loop speed ramp at full pwm. Of course this is not so good, and the motor gets warm when I do this several times, but it is working. However, I want to smooth the startup process now.
I went through all possible application notes and forums, but I did not really have an idea what to do in my case, with a propped motor and a small simple esc without current measurement, to start smoothly and reliable. What I know is that the standard plush firmware spins up the propeller as it was nothing, very smoothly. Also I know that in the latest blheli release, they implemented some sort of direct startup, but I don't really understand how it is working. Could someone of you give me some ideas how it is done, or where I can find more informations on how I can achieve the same smooth startup as the original plush firmware.
If you are interested, I could post the current code here.
Cheers
Christian
snakescb is offline Find More Posts by snakescb
Old Oct 16, 2012, 06:51 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
I'm interested!
ysolomon is offline Find More Posts by ysolomon
Old Oct 16, 2012, 07:32 AM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
designed brushless esc is now much simpler, go to google search with keywords brushless esc mystery 20a.full circuit diagram.
programs load up a file b_nfet in multicopter
This is my circuit, max current 35 a
fantasy1988 is offline Find More Posts by fantasy1988
Old Oct 16, 2012, 07:45 AM
Joined Oct 2012
hello guy
Who designed brushless esc for car car?
can fast forward, fast reverser and brake
i know it is difficult but I think it's very interesting
Old Oct 16, 2012, 10:25 AM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
Cheers
Christian
I'm always interested in new BL-ESC solutions. I have a Silabs development tool with flash loader and have also some ESC with Silabs-CPU on my desk.
Would be fine to investigate an additional Silabs ESC-software.
quax is offline Find More Posts by quax
Old Oct 16, 2012, 11:03 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Does anyone know which power FETs to use for 8S-12S, up to 150A ESCs?
Old Oct 16, 2012, 02:31 PM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
This is not only a question of FETs. There is a need of rich know-how to make the PCB.
Those currents and voltages are very difficult to handle. I don't have the skills to do that.
Old Oct 16, 2012, 04:49 PM
snakescb is offline
Joined Oct 2012
Hi again,
Ok, attached you can find my simple implementation for scilabs controllers. Not perfect yet, still working on, but I already made a lot of flights using this FW with some turnigy plush 12 esc's. I am developing the code in Ride7 and it is compiled using the RKit-51 on a hobbyist license.
Some ideas how to make motor startup smoother?
looking forward to receive some feedback
Brushless speed control problem TomL Sport Planes 8 Jun 08, 2003 01:23 AM
TMM-18-3ph Brushless Speed Control nelsonjo1 Power Systems 5 Apr 04, 2003 12:33 AM
FS: Model Motors 40 amp Brushless Speed Control. Jim McPherson Aircraft - Electric - Airplanes (FS/W) 3 Dec 10, 2002 05:02 PM
Dragon 35 brushless speed control Steve H. Aircraft - Electric - Airplanes (FS/W) 0 Aug 17, 2002 12:29 AM
Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! Rob R Power Systems 3 Jan 10, 2002 06:37 PM
