Old Feb 16, 2004, 09:29 AM
mmormota is online now
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
Hi, Mr DIY,
Yeah, just talking about it is easier... :-)
I am thinking about developing such a beast. But there are some parallel developments - not sure if the results of them will be free.
If there will be a free design available soon, it is a waste of time to develop another one. (Takao's hw design is effective and simple, if he publishes the final code too, hard to make anything better...)
And here is your and KreAture's work too.
If your and the other designs are not planned to be free, it is more interesting for me to develop a publicly available free one.
mmormota is online now Find More Posts by mmormota
Old Feb 16, 2004, 11:46 AM
rodhower is offline
Find More Posts by rodhower
Akron, OH
Joined Feb 2004
BLDC free design
I have an open design posted here;
http://groups.yahoo.com/group/osmc/f...LDC%20control/
or go to
http://groups.yahoo.com/group/osmc/files
and look for Rods BLDC control.
It's for a 100A plus control, but the power
and control board could be modified to make a smaller
control.
I have one version of this design on a 2.5" round board by
7/8" tall.
The files require expresspcb,
www.expresspcb.com
which is also free and goes up to 4 layers.
Rod
www.qsl.net/w8rnh
rodhower is offline Find More Posts by rodhower
Old Feb 17, 2004, 01:30 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
Rodhower
I did know about the open source project, but never really had a look at it. My initial thoughts at that time was that this developmental project was aimed a robotics and probably Robot Wars. The supplied links above pretty much confirmed my initial thoughts and to be really honest, there is nothing there that caught my attention. The controller board is way to big, but as you already said, it could be made smaller. But if one is to go to the trouble of reducing it (I suspect you will still not get it small enough) you might as well do your own thing if you have the ability.
Never the less, there are people out there that do not have all the required skills, and will find this project helpful, as no doubt, many have. Well done to the Yahoo group people for doing what you have done. Great to see you guys pull this one off.
Mmormota
You should go with you idea, as you never know what might happen to possible competition to your idea. You may be able to do it better and simpler and therefore have the advantage. At present, I do not know what I want to do with mine when I have it 100% finished… which should be in a months time. I suspect mine is a little too difficult for the average home constructor due to 0603 caps/resistors and fine-pitched devices. My new PCB is reasonably tightly packed in order to keep size as small as possible. I was considering supplying the local market at home with built units, as standard commercial ones are very expensive. Time will tell.
Mr DIY is offline Find More Posts by Mr DIY
Old Feb 17, 2004, 08:50 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Mr DIY,
>Takao .. What is your ADC conversion speed in uS?
8MHz/2=4MHz, 250nS
ADC needs 13 clocks.
250nS x 13=3.25uS
Basically, the AD is 10bit type.
But, As the manual says high speed clock reduces the resolution.
That is why I measured it with 4MHz.
If I could use ATMega8 with 16MHz clock, Then .... I am not sure.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Feb 17, 2004, 09:16 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
Hmm ... Takao .. I see what you are doing..
BUT ... the data sheet says that a suitable clock frequency must be chosen between 50 - 200 KHz to drive ADC module. So at 200KHz, that results in 5uS x 13 clocks = 65uS. I suspect now that this 'conservative' figure is for low power consumption and what works best for 10 bit resolution.
Maybe I should try some radical over clocking tonight and see.... Thanx for the feedback Takao.
Brian
Old Feb 17, 2004, 09:24 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Discussion continued overhere, a new BLDC thread in the "DIY Electronics' subforum:
http://www.rcgroups.com/forums/showt...hreadid=200567
Groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 01, 2004, 06:49 AM
Tokyo, Japan
Joined Nov 2002
New chip
I had found one interesting chip.
http://www.silabs.com/products/micro...sig_matrix.asp
The development tool is $99!
Old Mar 01, 2004, 07:46 AM
Joined Feb 2001
Takao, the discussion is continued overhere, in the "DIY electronics" subforum:
Groeten Ron
Old Sep 21, 2004, 04:16 AM
fsxhqsg_sg is offline
Find More Posts by fsxhqsg_sg
Joined Sep 2004
New chips for BLDC
Dear Mr.Takao Shimizu ,
I am very interested in your product of BLDC http://www.rcgroups.com/forums/show...8&postcount=148 Control. I would like DIY the BLDC, but cannot find MLH 6643, what IC can repla it. Your promptly answer will be very appreciated.
fsxhqsg_sg@yahoo.com
Thanks.
Best regards.
fsxhqsg_sg is offline Find More Posts by fsxhqsg_sg
Old Sep 23, 2004, 06:23 AM
Tokyo, Japan
Joined Nov 2002
fsxhqsg_sg,
>MLH 6643
O, oo...
I made a mistake written.
It is "LMH6643", rail to rail full swing OP amp.
This device has 100mA drive capability with 130MHz responce.
Good enough for any high input capacitance FET drive as high current motor drive.
http://www.national.com/pf/LM/LMH6643.html
The schematic is up-dated(also, I had written the GND mark on power line).
Sorry about that,
Takao
Thanks.
Best regards.
Old Sep 23, 2004, 09:21 AM
Joined Sep 2004
New chips for BLDC
Takao Shimizu
Thanks.
Best regards.
Old Feb 14, 2005, 12:59 PM
Barry Martin is offline
Find More Posts by Barry Martin
Bolton barry
Bolton, lancashire UK
Joined Feb 2005
Brushlees controllers
Since I am new to all this, this may not get through ! I logged on beacause I felt sure there may be some way of making a cheap DIY Brushless controller -- but looking at all the messages about this it seems to be beyond me! I am building a 42" span electric Lancaster with 4 KP02 motors off 8 cells. the motors are only marginal, and having experience of other brushless models, wondered if 4 small brushless (CD-Rom? )motors would do -- but 4 speed controllers? is it possible to run more than one brushlees from one controller, if the motors sere "fired up" one by one, and "caught" before each one had stopped spinning? I suppose we all want something cheap! Bolton Barry
Barry Martin is offline Find More Posts by Barry Martin
Old Feb 14, 2005, 01:45 PM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
Identical motors with identical load can run in paralell on a single controller. They start together and stop together.
However, a big plane may display different load to a prop inside the turn compared to one on the outside. Result may be loss of synch and power...
I am setting up just such a bird to test how well it works in real life.
http://www.kreature.rchomepage.com/p...at_twin_04.jpg
Both motors are capable of 150w or so and are run by a single 45 amp ESC from 3s LiPo.
The bird is made to be a floater so any loss of power will not cause a crash.
Will know soon how it performs
KreAture is offline Find More Posts by KreAture
Old Dec 24, 2005, 06:25 PM
rodhower is offline
Akron, OH
Joined Feb 2004
Messages end in Feb?
I was looking through the messages and realized there is nothing past Feb 2005.
I haven't monitored this list since last year and was wondering where the new messages are located.
Rod
Old Dec 25, 2005, 05:22 AM
Tokyo, Japan
Joined Nov 2002
I am trying the brushless controller.
http://www.rcgroups.com/forums/showthread.php?t=200567
See near the last page.
You may get many info. to design.
Takao
Rod
Brushless speed control problem TomL Sport Planes 8 Jun 08, 2003 02:23 AM
TMM-18-3ph Brushless Speed Control nelsonjo1 Power Systems 5 Apr 04, 2003 01:33 AM
FS: Model Motors 40 amp Brushless Speed Control. Jim McPherson Aircraft - Electric - Airplanes (FS/W) 3 Dec 10, 2002 06:02 PM
Dragon 35 brushless speed control Steve H. Aircraft - Electric - Airplanes (FS/W) 0 Aug 17, 2002 01:29 AM
Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! Rob R Power Systems 3 Jan 10, 2002 07:37 PM
