Old Jan 29, 2004, 06:07 AM
dicker is offline
Find More Posts by dicker
foamforce pilot
dicker's Avatar
Deutschland, Schleswig-Holstein, Braak
Joined Jan 2004
"Calculating the phase offset won't be much of a pain"
hmm, thats the point i got stuck the last time... I dont know wether it was my inability or a real problem... I didnt get it working...
Bye Julian
dicker is offline Find More Posts by dicker
Old Jan 29, 2004, 07:45 AM
hadihf is offline
Find More Posts by hadihf
Joined Dec 2003
Hi Julian,
When are you going to update bldc site??
hadihf is offline Find More Posts by hadihf
Old Jan 29, 2004, 08:28 AM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
Instead of calculating the phase shift based on timing and stuff, it should be easily calculated based on the commutation frequency.
If one knows the characteristics of the filter, the phase shift is easily calculated in advance and thus, one can use a rough table lookup with the time between commutation-pulses as parameter to find a pre-calculated delay for when to commutate.
This would be very fast too.
A even simpler solution is to go to my original idea of using 1 order of magnitude between the max commutation frequency and the PWM frequency. This would allow me to use for example a 2-pole active filter set to allow a max of maby 1 degree phase-shift at 6 kHz (my max comm rate that = 10,000 rpm on a 12 magnet cdrom motor) and a attenuation of nearly -28dB of the PWM signal. The phase shift would be minimal and allow for the simple t/2 commutation for 0-deg lead-in.
Waddya think ppl ? I like the last idea best. Less computations to perform.
KreAture is offline Find More Posts by KreAture
Old Jan 29, 2004, 09:57 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Lol, Now if I could only get same performance of my filter using a real opamp instead of an ideal one
Old Jan 30, 2004, 06:32 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
After investigating the matter, I think a filter with linear and minimal phase response is what I need. Then I can compensate for it in steps to keep phase error below 1, anyone have ideas ?
Old Jan 30, 2004, 06:45 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
To be honest KreAture, you have lost me somewhere along the way. Cant help think that you are prehaps over-complicating things here? Or is it just me? Would love to hear more feedback from others here too. Those others being people that have got a controller working as well.
Are you talking 'timing' as in advance/retard ... or just getting the phasing/feedback right for zero timing ... if that makes any sense?
Mr DIY is offline Find More Posts by Mr DIY
Old Jan 30, 2004, 07:47 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
KreAture is searching for a solution to get a clean bemf signal, and about to build a hw to do it. The opamp active filter most probably do the job - the question is that all this hw is really necessary.
It is question of preference. I personally prefer simplest hw possible and do the job in sw. I prefer to omit even the hw comparator, using a/d instead. The sampling is in synch with the pwm, additional filtering in sw if necessary.
mmormota is offline Find More Posts by mmormota
Old Jan 30, 2004, 08:26 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
I have not noticed this thread.
Here is the sensing signal wave form of my simple latest schematic comparator input which can handle full power and easy starts.
I have a problem by ringing on the sensing signal for power duty control.
I used no-modified CD-ROM motor for making program. But, the modified powerfull CD-ROM motor does not make ringing?!
I made some filter circuits and software to erase this ringing. Still can not find the final answer.
May be, I will write timing adjust program after my cold sick will go away from my body.
Anyway, the software can have a rest time after finding 1/2 Vcc point. That is why I use slow clock.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Jan 30, 2004, 09:00 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
mmormota
Yes, I am trying to filter the commutation signal to such a degree that the possible error caused by PWM noise will be limited to maby a degree or less error. The system will use a HW timer to handle the sensoring and another HW timer to handle the actual delay neded before commutating. First timer will be used to measure time between up/down flanks (each change would equal a commutation) and then if I caon't get rid of the phase error (wich it seems I can't) I'll simply use a phase-correction table to make sure I know where the commutation actually need to occur. Then calculate the delay needed and update the delay-timer. The rest of the system will be interrupt driven as well, making for little work to be done outside the interrupt-system.
Your AD solution is a good one as well, but the problem is closer to 100% power, as the non-pwm part would be so small. I can do a 10 bit AD conversion in 40 cycles or so, running at 8 MHz/2MIPS. This would mean 50,000 samples pr second, or a sample time of 20us. If the pwm-rate is too low, it would be ineffichient compared to the commutation rate. But if it's too high, I would not have time to do a sample during the off cycle to get readings where they are needed, that is close to the half-way point.
I have though about a simpler solution than the filter. I could simply generate a inverted PWM signal to add to the EMF. This would cancel out all the PWM noise and only leave the EMF signal and the motor switching noise. This noise will be very high frequency and should be easily removed with a very high fc, low-pass-filter. The high fc on filter would not do much to the phase of the low freqency EMF signal. Something as simple as a passive R/C network could then be used.
I really like the idea of being able to sense the emf for each commutation. It would allow for very fast response to load changes.
Old Jan 30, 2004, 06:49 PM
Tokyo, Japan
Joined Nov 2002
This schematic is under construction.
Old Jan 30, 2004, 06:53 PM
Tokyo, Japan
Joined Nov 2002
This software is under construction.
Just testing full power and start only, no power control by Rx interface.
Old Jan 30, 2004, 07:47 PM
Blackhawk3D is offline
Find More Posts by Blackhawk3D
Dreamin' in 3D
Blackhawk3D's Avatar
Lodi/San Luis Obispo
Joined Oct 2003
I have just finished reading this thread, and I must say, it is very interesting, but I am lost when you talk about etching the circuit board. How does this work? I have seen the sharpie method but I don't know how it works. Could someone explain it to me?
Thanks.
Blackhawk3D is offline Find More Posts by Blackhawk3D
Old Jan 30, 2004, 09:47 PM
whanderson is offline
Find More Posts by whanderson
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
Thanks.
First a copper plated fiberglass board has a pattern transfered to it by one of several methods. The desired components and interconnections to them make up the pattern on the PCB. This pattern can be drawn on with a pen "sharpie", tapes of various sizes, or a photo resist processed much like photography film. The desire is to have something protect the copper areas that are to be left intact from a chemical etchant. This is usually ferric chloride. The PCB is placed in the etchant and unprotected copper is chemically removed from the fiberglass. When this process is complete,the board is cleaned of resist and is ready for use. This is a highly simplified explaination and there are a number of different kinds of processes that can be used in PCB fabrication
whanderson is offline Find More Posts by whanderson
Old Jan 31, 2004, 05:22 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Takao Shimizu
I will be using a balancing system to make sure the 1/2 EMF trigger-point is always at 1/2 v+ even when battery voltage is dropped due to high load or end of cycle.
Good news:
I have found a way to filter the EMF without causing phase-error to any important extent while at the same time having a good dampening on the PWM noise. I will be rigging up the filter when I get home to do some experiments. If it works well, my EMF will be a nice clean 0-2 deg phase delayed sinus that will easily ramp up to a square wave for direct TTL commutation sensing.
The filter I will be testing is a second order Berka-Herpy Lowpass Notch and I should have approx -24dB attenuation of the PWM signal. I just hope this is enough for low rpms, as I expect it shoud be fine at high rpms where the EMF grows stronger.
Old Jan 31, 2004, 07:36 AM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
KreAture,
Let's assume that the pwm ferquency is filtered out.
The signal is still not pure back_emf, but the mixture of the forced driver voltage and the back_emf.
During startup the forced part most probably much biger then the emf.
The job is not only remove the pwm noise, but separate the forced voltage and emf too.
Brushless speed control problem TomL Sport Planes 8 Jun 08, 2003 01:23 AM
TMM-18-3ph Brushless Speed Control nelsonjo1 Power Systems 5 Apr 04, 2003 12:33 AM
FS: Model Motors 40 amp Brushless Speed Control. Jim McPherson Aircraft - Electric - Airplanes (FS/W) 3 Dec 10, 2002 05:02 PM
Dragon 35 brushless speed control Steve H. Aircraft - Electric - Airplanes (FS/W) 0 Aug 17, 2002 12:29 AM
Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! Rob R Power Systems 3 Jan 10, 2002 06:37 PM
