First, indoors, the heli will set up all sorts of rotating air currents going down, across the floor, up the walls, along the ceiling, and back down to the heli. It's like being in a constant downdraft which is also constantly varying slightly. Outdoors it's rare that you'll find pure windless weather and those air variations will come from different directions. As was mentioned heli flight is -constant- or at least frequent throttle adjustment especially hovering. Second, the '80% throttle' thing, most model aircraft are designed to operate 'normally' at about half throttle. With fixed wing this is true with proper CG and elevator position, and more throttle = ascend, less throttle = descend. The design of a rotary (weight, motor(s), prop(s)) aims for hover at neutral throttle. That's for -today-, at the low end of the learning curve. Look at those vids - this is not a Hummer, or a Yugo, this is a Ferrari! Those screaming climbs and straight line runs leaning at 45+ degrees are where it uses and in fact -needs- that 80-90% throttle. ![]() There are devices that can sense and maintain altitude automagically, but hot rods don't have them off the showroom floor. |
Nevermind... I got it working! It helps to double-check your cable markings. I've got them lined up correctly now and she flies!!!
So there it is... Devo 10 with deviation firmware, OrangeRX R615 DSM2 receiver, and Armattan CNC355 w/KK2. A few more tweaks of the model file and I think I've got a good base to work from. If anyone wants the model file I'll be happy to post it here once I tweak a few small details. |
Reason: She Flies
Hey!! congratulations thats great. I cant wait to see a video of this baby flying. Wow!
Latest blog entry: My Hunter V-Tail and Armattan Quad's
Life |
Progress
Feeling the pressure now that rexless has his CNC355 flying right away, so actually spent a bit of time working on mine.
I think I have *finally* solved how to do the power distribution. I'm fighting for height in the soap box, so don't want to stack things too high. Plus with the extra thickness of the box the bolts aren't quite long enough for the short nylon spacers to get a good bite. So I cut the corners out so it could sit flush to the bottom of the box, and then drawing from a power board I saw on whitespy (I think it was) that has notches instead of holes I modded mine. This allows the wires to come in from the side (rather than top/bottom) saving more height. Easier to see in the pic below than to describe. So all the ESC's are soldered in and the battery connection wires too. The KK2 board fits in fine, and I can squash the ESC servo leads OK (didn't feel like cutting them just now). Now just have to fit the RX, and buzzer in there an all is good. Solder on the bullet connections for the motors and starting to run out of reasons not to fly (at last). cheers, Andrew |
Yes - with third-party firmware developed by an RCGroups guru - www.deviationtx.com
Looking forward to sharing it! Thanks! |
Pdu
Here's what I copied.
![]() Looks like a good job. Not sure that the holes in the one I used were plated through like this one is. Seems a good deal for $3.http://witespyquad.gostorego.com/acc...ion-board.html cheers, Andrew |
Code:
this its it |
| Thread Tools | |
| FAQ Nine Eagles Solo Pro I/II/V1/V2/270/Bravo SX FAQ (FAQ part in the first 3 postings!) | SoloProFan | Micro Helis | 1997 | May 12, 2013 03:40 PM |
| For Sale Armattan Quads Price List and FAQ | bobepine | Aircraft - Electric - Multirotor (FS/W) | 1379 | Jan 16, 2013 01:51 PM |
| Sold Armattan 355mm quad | N3SHXX | Aircraft - Electric - Multirotor (FS/W) | 5 | Jan 15, 2013 03:48 PM |
| Found Trade a Armattan RXR quad for iPhone 3 | bobepine | Aircraft - Electric - Multirotor (FS/W) | 2 | Dec 01, 2012 11:47 AM |
| For Sale Armattan Quads Announcement: Upgrade Parts | bobepine | Aircraft - Electric - Multirotor (FS/W) | 16 | Oct 13, 2012 12:07 PM |
