Old Jan 18, 2013, 09:56 PM
neilbooth is offline
Find More Posts by neilbooth
neilbooth's Avatar
United Kingdom, England, Kirkby in Ashfield
Joined Aug 2008
Help!
parkzone stryker f27q upgrade
Hi all, help needed.
I know this may have been covered in other threads but I got lost in the masses of pages and the others seem to be quite old and can't find the motors they're talking about.
I'm after upgrading my stryker f27q, I'm running it stock at the moment on 3s lipo and want to upgrade it to 4s. I'm going to buy some turnigy nanotech 4s lipos and a 60 or 80 amp turnigy plush esc, I want some decent speed out of this thing so wanted to know what motor you guys think I should buy and what prop size I should go with, I'm pretty much a noob with electric stuff as iv always flown nitro war birds and nitro fan jets. Thank-you in advance to you all for your help on this.
neilbooth is offline Find More Posts by neilbooth
Old Jan 24, 2013, 09:23 PM
Var. is offline
Find More Posts by Var.
United States, CA, Burlingame
Joined Jul 2012
4S + 80A ESC with APC 7x5E is popular. I think some people report ~115mph or more in a dive
Var. is offline Find More Posts by Var.
Old Jan 27, 2013, 01:26 PM
neilbooth's Avatar
Joined Aug 2008
Thanks var, is that on the stock motor or an upgraded one
Old Jan 27, 2013, 04:49 PM
Var. is offline
Joined Jul 2012
Stock motor.
Old Jan 27, 2013, 09:46 PM
neilbooth's Avatar
Joined Aug 2008
Ok m8 nice1, il give it a try.
Old Feb 15, 2013, 09:15 AM
neilbooth's Avatar
Joined Aug 2008
Hi guys. I tested the 4s 80amp turnigy plush and a 7x5e prop on the stock motor and its pulling over 95 amps and the motor and esc are getting real hot real fast lol. Any ideas whats wrong here? Thanks guys.
Old Feb 15, 2013, 01:49 PM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
Static motor tests always show more amps then they will see in the air. The motor will unload in flight and see ~10% drop in amps. Additionally, you will have gobs more airflow over the equipment to help keep it cool.
Throw it up, keep the WOT burst short and check the temps after a few passes. Adjust your flying/gear as needed.
nofreee is offline Find More Posts by nofreee
Old Feb 18, 2013, 10:57 AM
neilbooth's Avatar
Joined Aug 2008
Took it up at the weekend and after a few passes it fried the motor :'( aww well. Its a good excuse to get a better one lol.
Old Feb 22, 2013, 06:31 PM
Var. is offline
Joined Jul 2012
Sorry to hear man. Lot of people were using that setup over in the Stryker main thread.
How long did you go full throttle? Usually it's supposed to be limited to 5-10 second bursts
What did you think of the speed before it gave out?
Old Feb 22, 2013, 06:39 PM
postalflyer72 is offline
Find More Posts by postalflyer72
Everything is Upgradeable.
USA, FL, Gainesville
Joined Aug 2010
He must have left it floored. I run a 7x6 with a 60a esc on stock motor. Still flying strong. Word of advice, use cf arrow under wing to reinforce. Already folded a wing but good as new. I think you don't want to read at all and get easy answers. There is one thread that covers it all. Motors are listed and updated all the time. Here you go. http://www.rcgroups.com/forums/showthread.php?t=1416165
postalflyer72 is offline Find More Posts by postalflyer72
Old Feb 23, 2013, 08:41 AM
neilbooth's Avatar
Joined Aug 2008
Hi all. I flew it on half throttle for a few passes and a wot pass for about 5 seconds before it gave out. The speed did seem quite a bit faster and pull better. Iv read many many threads but get confused when ppl start contradicting each other. Anyway I had a spare stock motor that I ran after with the stock 6x6 prop. See what u think
4s stryker f27q (2 min 24 sec)
Iv got a new motor to try now it a scorpion s2 3014-1220kv and going to run an apc 8x9. Will post a vid after the weekend.
Old Feb 24, 2013, 02:02 PM
Joined Aug 2010
A few things to consider. First of all reinforcing the wing with cf above plastic from underside. Make sure it hits corner of servo for longest possible. Also 8X9 on a what? 2s pack? That prop sounds a bit too large and too much pitch. Even an 8x8 might be a bit much. Hard to tell without having info on how many cells. Anyways here is the picture of the bottom of the Stryker during surgery. The front line with foam is another design flaw. It's fiberglass that has not been scuffed. Eventually will give and separate at middle.
Old Feb 25, 2013, 02:49 AM
neilbooth's Avatar
Joined Aug 2008
Hey thanks for the pic, I was going to do it but was unsure where to put it so that helped alot. Im running on 4s 2700mah 65-130c turnugy nano tech packs. I too was a little suspicious about the prop being too big but theres a lad on YouTube running this setup but with a 9x9 apc sport prop and getting 138mph so I just thought I would try it before forking out for a Mega inrunner.
Old Mar 08, 2013, 04:50 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Ther's some info on the Scorpion motors on the MPX Dogfighter thread, mainly the 1400kv, 1600kv and the 1900kv. Most of these motors have been pushed upto about 90-100a and seem to be holding out ok. I run the 1600kv on 4s with a 7x7 APC sport, nothing blistering fast but it's a good solid setup at around 65a static. Another user is running the same prop on 5s and he seems happy with it.
Not sure why you think big props will cause a problem? Ok you'll get some torque roll at launch which is a bit un-nerving the 1st couple of times but otherwise they're fine. They shouldn't cause a prob at landing either, use the brake function on the esc, try and get the prop horizontal for landing, but if not it simply gets nudged out of the way. I've never broke a sport prop on a pusher when landing yet.
Vid of a guy on the FJU thread who goes with the flow when it torque rolls at launch, very cool IMO.
FJ Ultra MEGA 16 35 2 6s2650 5 5x5 5 (2 min 51 sec)
feefo is offline Find More Posts by feefo
Old Mar 08, 2013, 05:56 AM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
BTW, Mega's are sweet motors, and I much prefer my Mega in my FJU over the Scorpion in the DF.
For Sale Parkzone F27Q Stryker Colorado LPU Prydespride Aircraft - Electric - Airplanes (FS/W) 3 Jun 29, 2016 07:25 PM
Sold Parkzone Stryker F27Q PNP In great condition LPU $130.00 or trade with Parkzone P-47 btpalc Aircraft - Electric - Airplanes (FS/W) 2 Jul 08, 2012 10:02 PM
Sold Parkzone Stryker F27Q PNP yesdog Aircraft - Electric - Airplanes (FS/W) 2 Jul 18, 2011 10:06 PM
Sold Parkzone F27Q Stryker PNP Brand New noobiznessflying Aircraft - Electric - Airplanes (FS/W) 3 Jul 07, 2011 03:10 PM
Sold NIB Parkzone Stryker F27Q rcwarrior Aircraft - Electric - Airplanes (FS/W) 4 Jul 03, 2011 01:36 PM
