Old Feb 05, 2013, 07:44 PM
eazyp2 is offline
Find More Posts by eazyp2
United States, OH, Columbus
Joined Oct 2007
if you can mount servo,s in the rear of this one your the man,the stock location works great and then the fan mount behind them,it gets tight real fast,in the begining it looks like theres a ton of room and then things just become so tight,lol.
eazyp2 is offline Find More Posts by eazyp2
Old Feb 28, 2013, 09:58 PM
goforit is online now
Find More Posts by goforit
United States, WI, De Pere
Joined Aug 2010
Managed to mount the servos in the vertical fin and stabs. It is really tight but it will work. Hitec servo in the vertical fin and jr servos in the stab.
goforit is online now Find More Posts by goforit
Old Mar 11, 2013, 05:35 PM
Rpotter90 is offline
Find More Posts by Rpotter90
USA, FL, Gulf Breeze-Harold
Joined Aug 2008
I have just picked an interceptor up also. I will be using electric retracts and robart struts. I have an old dynamax electric fan that I plan to convert but I'm not finding many adapters in stock. Any suggestions? Would like to keep it cheap if possible.
Rpotter90 is offline Find More Posts by Rpotter90
Old Mar 11, 2013, 06:01 PM
Joined Aug 2010
Hi,
I am using Tam Jets conversion parts for my fan. I went with Dyna Rotor hub assembly and Dynamax motor housing conversion. I will be ordering motor from him also.
Good luck on your build. Looking forward to see your build.
Dennis
Old Apr 05, 2015, 11:11 AM
Joined Aug 2010
I pulled her out of the rafters this weekend and decided to finish the project. I sold off all my larger fans for a turbine fund. My turbine fund went down the drain,
sewer line broke and had to replace 90 feet .
PIcked up a lightly used Stumax fan 110 for 12s. Plan to run a bell mouth intake and fully enclosed intake for comparison testing.
The outside diameter of the bell intake is same as inside diameter of the stock intake.
Old Apr 05, 2015, 11:36 AM
Joined Aug 2008
Well here we are two years later and mine is in the box too. However I did get a BVM 12s fan for it... So it should scream. I look forward to your build progress.
Old Jun 06, 2015, 06:58 PM
Joined Aug 2010
Found some time for building and the wings are coming along okay. Need to figure out servo placement for aileron and flaps and cut the servo bays.
I plan on lining the wheel wells Sunday. It is suppose to rain all day so I should be able to finish up the wings!
Help! ITC Bladerunner Interceptor Gopher Coaxial Helicopters 2 Jan 09, 2013 08:23 PM
Discussion New TG-3/TG-3A at 2.1 meters mmartin55 Scale Sailplanes 1 Oct 16, 2006 11:07 PM
FS: Who want's an X-Wing interceptor? harryo Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2004 07:57 AM
Interceptor For Sale mirageman2005 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 07, 2003 01:40 AM
