Old Jan 18, 2013, 08:45 PM
goforit is online now
Find More Posts by goforit
United States, WI, De Pere
Joined Aug 2010
Build Log
TG Interceptor
I picked the TG Interceptor as my winter project. Wood Sheeting is ordered and I hope to have it on the bench soon. I am undecided on what power system to use.
I have Jet Fan V2 90mm nib and I have a dynamax fan that I could convert to electric.
Jet Fan in the picture looks lost in the fuse. I plan on using an 11s 5000 pack.
Will the Jet Fan produce enough power or I am better off with a Dynamax set up ?
I build light.
goforit is online now Find More Posts by goforit
Old Jan 18, 2013, 08:49 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
I would think the dynamax would be better here. That is a huge airframe.
Chris True is offline Find More Posts by Chris True
Old Jan 18, 2013, 08:58 PM
stoneenforcer is online now
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
dyna for sure. the lil 90mm would need to fly wot all the time.
stoneenforcer is online now Find More Posts by stoneenforcer
Old Jan 18, 2013, 10:37 PM
jimm1962 is offline
Find More Posts by jimm1962
jimm1962's Avatar
United States, IL, Dixon
Joined Sep 2006
Nice kit, wish they still made it. Last I heard was that Dynamic Balsa picked up Top Gun Jets kits and were going to start bringing them out again. I believe they may have the F-15 out. Did the bring the interceptor out again?
jimm1962 is offline Find More Posts by jimm1962
Old Jan 18, 2013, 11:37 PM
eazyp2 is offline
Find More Posts by eazyp2
United States, OH, Columbus
Joined Oct 2007
thats funny goforit,I think the dynamax would be best. Paul
eazyp2 is offline Find More Posts by eazyp2
Old Jan 19, 2013, 12:49 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Rainer put a jetfan 90 into a F-86 the same size as a BVM F-86 . The setup he put in it produced about 11 pounds of thrust. Also Rainer has stated they are work on larger fans in the 110 to 130 range.
BadLemon is offline Find More Posts by BadLemon
Old Feb 02, 2013, 08:42 PM
Joined Aug 2010
Managed to find some building time and installed the fuse formers and nose gear bulkhead. Nose gear steering servo is installed. West Coast epoxy mixed with chopped fiberglass was used to glue in the formers.
Retracts I plan to use Spring Air with Robart Struts.
Tommorrow I plan on installing the intake duct work and dynamax fan.
Old Feb 03, 2013, 03:53 PM
Marty Snell is offline
Find More Posts by Marty Snell
Gillette,WY
Joined Jan 2005
I designed the interceptor. It was designed for the dynamax fan to begin with. It will drop right in. You should see about a 4lbs increase in thrust over the slimer version.
Good luck on the build
Take Care
Marty Snell.
Marty Snell is offline Find More Posts by Marty Snell
Old Feb 03, 2013, 06:38 PM
Joined Aug 2010
Managed to install duct work today. 2 hours of trimming and fitting, the end result was worth it. Turned out nice.
Converting one of my ICDF to electric. New fan shroud , and Tam's Motor housing converison kt is order. I am undecided on what motor to order for a 11s set up.
Old Feb 04, 2013, 11:42 AM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
Are you going to convert the Dynamax or use a different fan? I have converted a number of the Dynamax fans and the conversion works very well. I am getting about 15 lbs thrust on 12S with a 630KV outrunner @120 amps and 5+KW. These are wonderful flying planes. I am sure you will really like.
Progress looks great.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Feb 04, 2013, 02:04 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Just a heads up:
http://www.rcgroups.com/forums/showp...16&postcount=1
Michael Paxton is offline Find More Posts by Michael Paxton
Old Feb 04, 2013, 07:59 PM
Joined Aug 2010
Ed
Ed
Converting a Dynamax fan. Tam's Center housing conversion was delivered today.
New outer fan shroud is on its way and couple new fan blades.
Dennis
Old Feb 04, 2013, 11:41 PM
Joined Aug 2010
Fan is installed. I drilled oversize holes in the mounting plate. Made up shims from 1/32 plywood and nut plates. I will be able to move the fan around to get it centered up perfectly in the duct work.
Old Feb 05, 2013, 12:55 AM
eazyp2 is offline
Joined Oct 2007
Hey go4it keep your cg in mind, to get a good balance in my interceter I had to mount the fan back just in front of the rear former,you will need. To extend. The intake, just a heads up. Paul
Old Feb 05, 2013, 07:37 AM
Joined Aug 2010
Thanks Paul
I was considering mounting the servos in the tail to help move the cg aft. I will go with your advice and move the fan aft.
Thanks for your help !
Dennis
Help! ITC Bladerunner Interceptor Gopher Coaxial Helicopters 2 Jan 09, 2013 09:23 PM
Discussion New TG-3/TG-3A at 2.1 meters mmartin55 Scale Sailplanes 1 Oct 17, 2006 12:07 AM
FS: Who want's an X-Wing interceptor? harryo Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2004 08:57 AM
Interceptor For Sale mirageman2005 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 07, 2003 02:40 AM
