Jan 19, 2013, 07:44 PM
United States, CA, El Cajon
Joined Mar 2012
Earlier today I started killing this battery with a headlamp setup. It's a 11.1v 2200mah btw. It basically took it down to 0v the first time but rebound to 3.33v. Didn't puff, only got slightly warm. I put it on the headlamp for a while longer and after it was 0v but it's still rebounding slowly. I've done a discharge with a 1s before no problem, soldered the leads afterwards (no spark). Is this 3s battery ready to do the same and dispose? Any advice? I'm not a fan of messing with lipos but want to safe it off.
Also I have another one that's 1000mah that's puffed pretty bad, and I seem to get unreliable readings from the balance plug. Should I try to discharge it? The discharge would be about 2c from the same setup as I used on the 2200mah batt, is this correct? Would that be safe?
