This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Jan 18, 2013, 05:19 PM
unclegeorge is offline
Find More Posts by unclegeorge
Trader Rating: 251
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 251
For Sale
Throttle and Choke arms for Gas Engine Carbs.
If you have ever struggled with trying to make a new arm for your throttle or choke on your gas engine carborator out of nose gear steering arms---Here finally is a solution!
Hundreds of these have been ordered and everyone tells me there is nothing on the market like them, better order yours soon!
Note that there is a difference in the height of each are so they can pass each other without any interferrence.
They are CNC machine of 6061-T6 Aluminum so they can be taped for a 4-40 ball or you can use a nylon clevis if you like for hook up.
These arms are build to slide on to the brass shafts on your carborator and are held in place with 2 set screws. I recommend that you file a flat on the shaft after determning what angle is best for hook up and then use thread lock on the set screws.
Specs:
1. CNC machined 6061-T6 aluminum in a brilliant red anodized finish.
2. Perfect for all carbs using standard 3/16" (0.1875") throttle and choke shafts.
3. May be drilled out for larger carbs using 7/32" (0.2187") throttle or choke shafts.
4. Offset heights provide enough linkage clearance for your servo mounting preferences.
5. The multiple 1/16" arm holes located at 1/2", 3/4" and 1" provide mounting flexibility and changes in mechanical advantage.
Sold in pairs only. One tall and one short. Includes 4mm set screws
I sell them for $14.50 a pair plus $2.00 S&H by first class. Priority mail is now $6.00. Buy two for $13.00 Each plus shipping!!!
Please give me your mailing address and please refer to the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase. My account in Pay Pal is under uncgeorge@comcast.net
unclegeorge is offline Find More Posts by unclegeorge
Old Jan 22, 2013, 10:10 AM
advance is offline
Find More Posts by advance
Trader Rating: 8
United States, NC, Winnabow
Joined Oct 2009
Trader Rating: 8
I need 4 pairs of the CNC machined 6061-T6 aluminum in a brilliant red anodized finish carb arms. Please send PayPal invoice to rebelrods@aol.com
My address will be on the PayPal payment. I'm in North Carolina 28479
Thanks Advance
advance is offline Find More Posts by advance
Old Jan 22, 2013, 08:10 PM
Trader Rating: 251
Joined Feb 2005
Trader Rating: 251
Got your order. I will ship out on Thursday. Thanks for the business. Uncle George
For Sale Throttle and Choke arms for Gas Engine Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 13, 2013 05:56 PM
For Sale Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 11, 2013 01:50 PM
For Sale Close out on short arms for Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 02, 2012 03:48 PM
Sold Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 26, 2012 12:47 PM
Sold Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 15, 2012 09:57 PM
