View Poll Results: how many battery chargers do you own????
1-2 48 43.64%
2-4 26 23.64%
4+ 36 32.73%
Voters: 110. You may not vote on this poll
Old Jan 18, 2013, 04:22 PM
azflyingguy is offline
Find More Posts by azflyingguy
Gilbert AZ
United States, AZ, Gilbert
Joined May 2012
Poll
How many battery chargers do you own????
azflyingguy is offline Find More Posts by azflyingguy
Old Jan 18, 2013, 04:23 PM
bulldog5046 is offline
Find More Posts by bulldog5046
United Kingdom, England, Bradley Stoke
Joined Mar 2001
1...
bulldog5046 is offline Find More Posts by bulldog5046
Old Jan 18, 2013, 04:36 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
8 or 12 if I count the various Celectras
metal shelf unit with a 1000W and 300W power supply, parallel charge board and
power distribution board
scirocco is online now Find More Posts by scirocco
Old Jan 18, 2013, 04:48 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
http://thunderpowerrc.com/html/TP610CACDC.html - thats it
cmdl is offline Find More Posts by cmdl
Old Jan 18, 2013, 04:56 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
I use a multi charger. There might be a pile of cheap ones in the garage that came free with various planes, if I haven't thrown them out yet.
aurorae is offline Find More Posts by aurorae
Old Jan 18, 2013, 05:00 PM
rrg is offline
rrg
Find More Posts by rrg
rrg
rrg's Avatar
United States, KY, Edgewood
Joined Dec 2007
Two, plus a couple of cheap ones also....
rrg is offline Find More Posts by rrg
Old Jan 18, 2013, 05:18 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
One FMA from the dim and distant past of NiMh cells. An early FMA that does 4S LiPo while inspiring great confidence. One cheap Chinese thing that does LiPo, but without inspiring much confidence.
I have another couple of chargers that came with babyBARFS, but they do cells, not batteries. Sorry
D
Dereck is offline Find More Posts by Dereck
Old Jan 18, 2013, 05:42 PM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Two. One iCharger 306B and one HobbyKing ECO6-10. Combine them with a 12v/24v 55A PS and a couple of paraboards, and I can charge up to 12 packs simultaneously.
Lardog is online now Find More Posts by Lardog
Old Jan 18, 2013, 06:59 PM
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
2 in my charge box I built. Has a 47amp PS inside and I run it with a Honda EU1000i genny. I have a pile of the ones that come with micros but the only one of those I use is the 4 port Celectra which I've adjusted the pots in.
tsymonds is offline Find More Posts by tsymonds
Old Jan 18, 2013, 07:07 PM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
Two
xrx1113 is offline Find More Posts by xrx1113
Old Jan 18, 2013, 07:08 PM
scirocco's Avatar
Joined Feb 2001
what does adjusting the pots do?
Old Jan 18, 2013, 07:46 PM
tsymonds is offline
tsymonds's Avatar
Joined Jun 2011
Changes the charge rate. There's one small pot for each of the four slots. If you take the screws out o the bottom and pop the two halves apart the pots can easily be adjusted with a small falt blade. You can get 2-3C charge rate depending on the size of the cells. Handy if you use good aftermarket cells for the micros like TP, Hyperion etc.
Old Jan 18, 2013, 09:31 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Three good ones,, about thirty or more of the "things" that come
with various planes, and helio's.
The only little ones we use are the one for the Heli-Max Nano, for
some reason the plug is reversed on this helio. The Ubers have
a built in charger that plugs in the transmitter. And one little helio
that has a built in battery and the charger plugs in the side. The Mini
series Flyzone have a special charger.
The rest we use our Thunder chargers. Two 80's and one 50w.
Kimber is offline Find More Posts by Kimber
Old Jan 18, 2013, 10:03 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
From 6 cell lipo to cheap 1, 2, 3 cell chargers, 22 in all.
Butch777 is offline Find More Posts by Butch777
Old Jan 18, 2013, 10:11 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I have been flying electric since the early 80's so not even including the various BNF ones I have quite a few by now
Three of them get the most use since they do balanced Lipo charging.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Discussion How many fields have you driven by, and said, "I could fly there"? Leather Helmet Life, The Universe, and Politics 30 Jan 17, 2013 03:32 PM
Question How do you do a flat Spin? Great_Goose 3D Flying 10 Jan 13, 2013 11:25 AM
Discussion how many big chargers(5s and up) do you own? rroback Batteries and Chargers 23 Mar 14, 2006 09:28 PM
How do you tell how many amps you can pull out of a li-poly battery? Kyle2baseball Batteries and Chargers 2 Feb 04, 2004 11:54 PM
How many battery packs do you own? freeflight Batteries and Chargers 10 Sep 02, 2003 07:56 PM
