Old Jan 18, 2013, 11:08 AM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
Question
UMX P51 motor and gearbox thrust
does anyone knows whats the thrust(in grams) for the UMX P51 8.5mm motor and gearbox?...thanks
karfrik is offline Find More Posts by karfrik
Old Jan 18, 2013, 12:23 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
This is very Prop and Battery dependent, but figure somewhere between 45g and 30g.
Good batteries, 5043 are towards the igher end, Cheap batteries 3 blade prop on the lower end.
15 seconds into any battery is going to have more thrust than 5 minutes in, too.
UNGN is offline Find More Posts by UNGN
Old Jan 18, 2013, 01:25 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
thanks!!!!......
Old Jan 18, 2013, 01:50 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Hi again,i have another question;I have a dual motor airframe that weighs at 60.4g with nothing on it.Im guessing about 20-25g more weight of components to power it.Do you think I can get away with 2 P51 motors and gearboxes would be enough to lift about 85grams?.....I think I should go over but im not expert ......lmk if I can consult this build with you.Thanks,....Al
Old Jan 18, 2013, 03:50 PM
alset is offline
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
I'm guessing that there would be no problem if the wing area was 85 sq-in or more.
alset is offline Find More Posts by alset
Old Jan 19, 2013, 12:06 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Is there a formula for calculating thrust needed by measuring wing area?
Old Jan 19, 2013, 02:42 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
No, its more weight to wing area that is important.
Old Jan 21, 2013, 12:33 PM
JT2 is offline
JT2
Find More Posts by JT2
JT2
Joined Jan 2013
I have a UMX P51 8.5mm motor and gearbox that I would like to put into a UM scratchbuilt indoor slow flyer. Anyone have recommendations on a design that uses this motor?
JT2 is offline Find More Posts by JT2
Old Jan 21, 2013, 07:41 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Ok,..measured the wings.Its a Wright Bros Flyer so its considered a canard.Does I need to also take in consideration both the main wings or just one?.Im guessing both right?
If so each main wing have a 79sq. inch area take or leave some,so 2x that is 158sq.in.
Both elevators have around 36sq.inch each so 2x that is 72sq.in take or leave some.
As I mentioned above just the airframe is 60.4oz.So guys please lmk if im on the right path.....thanks again
Old Jan 21, 2013, 07:48 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Here`s some actual model pictures,but this one is heavily modified....
For Sale 2 brushed ESCs and multiple motor/gearbox combo Kyle G. Aircraft - Electric - Power Systems (FS/W) 1 Jan 21, 2013 09:40 PM
Wanted couple of PZ UMX P51/Corsair 8.5mm motors with gearbox karfrik Aircraft - General - Miscellaneous (FS/W) 0 Jan 08, 2013 08:12 PM
Sold UMX Extra 300 6 Ch Brick (6410L), Motor & Gearbox, $35 shipped Premium2000 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Sep 10, 2012 06:53 PM
Question Mounting GWS 5x4.3 to E-Flite UMX Extra 300 motor/gearbox BladeScraper Scratchbuilt Indoor and Micro Models 12 Feb 29, 2012 03:35 PM
Discussion Thrust 50 motor on the P51 attack duck Electric Warbirds 2 Feb 22, 2010 03:23 PM
