Old Jan 18, 2013, 11:05 AM
heinz57zuk is offline
Find More Posts by heinz57zuk
United States, AZ, Gilbert
Joined Jan 2011
Major issues due to possible brown out?
Not sure what happened yesterday, but I put a voodoo mustang (stock) up for its maiden. Was flying beautifully and then I lost control for about 4 seconds. I gained control back just in time before it would have hit a block wall. It slowly spiraled down while there was no control. Then, I was making a practice approach to land and was too hot. So, I made a go around. Picked up some good altitude and started to circle for the landing. NO SIGNAL AGAIN! It made a slow spiral again and no power. This time it was for over 6 seconds. I count it as my lucky day as it was free flying for a long time and didn't hit anything. It landed on its own with only a broken prop and the cowling broken, but easy fix. I finally got power back after it landed. The AR500 Full range receiver was solid. I turned off my radio and back on. The reciever took 2-3 seconds to reboot, but came back on solid. Shouldn't it flash due to loss of signal? A brown out, I could almost understand, but this was a blatant loss of siganl for a very extended period of time.
heinz57zuk is offline Find More Posts by heinz57zuk
Old Jan 18, 2013, 01:18 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There used to be a problem with the AR500, try a Google search on - Spektrum AR500 problems.
Not sure the problem still exists, but worth checking with Spektrum.
eflightray is online now Find More Posts by eflightray
Old Jan 20, 2013, 10:40 AM
AA5BY is offline
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
What battery on Rx?
AA5BY is offline Find More Posts by AA5BY
Old Feb 03, 2013, 02:13 AM
TheWhistler is offline
Find More Posts by TheWhistler
Joined Feb 2013
The AR500 gave me nothing but problems, and it is not worth the risk to run them.
I had one in my Extra 300 and it browned out causing the plane to go in a dive on final, and it recovered only inches above the grass. I flew again for another week with no problems, then all of a sudden it went into a dive at about 50ft and would not pull out and none of the controls would respond.
It hit the ground at full power.
So after that I sent the recieve to Spektrum to get it tested and they replaced it with a new AR600 instead.
I did some research and found the AR500 had alot of problems. There was even a guy at one of the float flys going around taking names of people who had AR500 malfunctions to prove that there was a problem.
Either way I suggest sending it to spektrum to get looked at, because they will likely just replace it with an AR600 like they did for me. I find they are a very good company for stuff like that.
Even better, have your local hobby shop do it for you, and they will be even more likely to replace it. Also don't run that RX in any planes, because that is likely one of the ones from the batch where they had problems.
TheWhistler is offline Find More Posts by TheWhistler
For Sale closed whytlotus Aircraft - Electric - Helis (FS/W) 1 Jan 09, 2013 09:30 PM
Discussion HBZ Champ brown out issues Deltaforce1 Micro Ready-to-Fly 28 Oct 27, 2011 08:51 PM
Discussion Possible tx/rx issue (motor cuts out but other channels seem fine) mbreslin Radios 3 Apr 22, 2011 09:48 PM
Discussion DX7 issues? Brown out? chriscat Radios 16 Jun 20, 2010 08:28 AM
Blade glitching possibly due to cell phone? docprego Micro Helis 37 Sep 25, 2005 08:53 PM
