Old Jan 17, 2013, 11:31 PM
hp88 is offline
Find More Posts by hp88
TRex 450,500,600, Dragonus II
hp88's Avatar
Australia, QLD, Brisbane
Joined Nov 2008
Flex shaft to motor Coupler Question
I am setting up my 1/4 inch flex shaft to my motor coupler and just like to know how much of the flex shaft do i need to have inserted into the motor coupler. The coupler is a vice type that clamps down on the flex to hold it secure.
Cheers
hp88 is offline Find More Posts by hp88
Old Jan 18, 2013, 05:00 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I try to fit my flex's so that it will end up with the desired clearance from prop dog to the stinger/strut and the other end of the cable inserted in the coupler until it's bottomed out against the motor shaft.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Jan 18, 2013, 03:11 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I second that Bill.
hp88
I notice that you are close to where I live.
We have a club at the Boondall Entertainment Center where we run every Saturday (today included) if you want to come along for a chat. Who knows, you might even join the club. Not only fast electric but Sail, Steam, Submarines, & Scale boats too.
http://www.triple-s.org.au/
All the best.
Paul.
785boats is offline Find More Posts by 785boats
Old Jan 18, 2013, 09:41 PM
hp88 is offline
hp88's Avatar
Joined Nov 2008
Thanks for the replys, I am at the stage of mounting the motor mounts to the hull so was curious as to how much flex to insert into the coupler. Just getting everything lined up and market out before epoxing it all down.
Cheers
Discussion Flex coupler to solid shaft ?!?! marcgyver77 Racing Boats - Internal Combustion 9 Jun 04, 2012 12:22 AM
Discussion Should I grind a flat spot on my motor shaft for the flex cable coupler? zanek Racing Boats - Electric 9 Aug 14, 2011 07:54 PM
Discussion Coupler for 2,4mm shaft to 0,98" flex? Pekka L Racing Boats - Electric 7 Feb 08, 2011 12:32 PM
Question V24 flex shaft coupler zen3 Racing Boats - Internal Combustion 3 Oct 25, 2010 10:04 AM
Discussion i ca glued the prop shaft and motor shaft to the coupler ? How to remove coupler ? mortonj69 Dock Talk 26 Feb 22, 2010 07:47 PM
