Old Jan 17, 2013, 10:53 PM
hutchinstuff is offline
Find More Posts by hutchinstuff
Hutch
hutchinstuff's Avatar
United States, Mt, Bozeman
Joined Jan 2012
Coro Float Plane?!
Hello all! a few of us in MT are trying to pass the winter by building some coro projects.... We are gonna try to design/build a single hull coro 40-60 size water ship. The thought is to make a box(ish) fuse, then epoxy/glue a foam hull to the bottom, as it would be damn tricky to get the coro to get in that shape, and make it waterproof to boot!
I'm thinking a trick to get it to balance well is to melt some wheel weights to shape and put em in the bottom of the foam, to get the sailboat keel effect....
Then a bolt on a wing with pod mounted engine above like your standard "Lake" airplane.
Any thoughts/tips/tricks/advice/warnings?
cheers from MT
hutchinstuff is offline Find More Posts by hutchinstuff
Old Jan 18, 2013, 01:00 PM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
Benjamin did a seamaster type plane, he called it the snowmaster, I will look for a link to the plans
draftman1 is offline Find More Posts by draftman1
Old Jan 19, 2013, 10:09 AM
draftman1's Avatar
central CA
Joined Aug 2002
http://spadfest.rcspads.com/displayi..._display_media
there it is
Old Jan 19, 2013, 09:42 PM
Hutch
Joined Jan 2012
thanks draftman.
Discussion Central Kentucky Float Flyers float fly 2013 Iflyj3 Waterplanes 4 Jan 17, 2013 05:22 AM
Help! Avispad CORO plane for a noob!!!! vineet_p Foamies (Scratchbuilt) 3 May 07, 2012 10:14 AM
Discussion Spitfire 90 Coro Plane TARIQ40 SPAD - Simple Plastic Airplane Designs 4 Jun 15, 2009 04:03 AM
Discussion Indoor Coro Plane Design Need ? TARIQ40 Electric Plane Talk 2 Jun 01, 2009 12:29 PM
Discussion Highly aerobatic 2 mm coro plane ashtasky SPAD - Simple Plastic Airplane Designs 3 Nov 11, 2008 11:56 PM
