Old Jan 17, 2013, 09:16 PM
Mavs424 is offline
Find More Posts by Mavs424
United States, TX, Frisco
Joined Dec 2012
Question
Need help determining motor shaft size/replacement
Hi,
I recently crashed my Flyzone Beaver and as a result the shaft is slightly bent. I found a motor adapter replacement part (which was also bent), but nowhere can I find just the shaft to order. The specs of the motor are below. Can someone please help me figure out where/how/what I can get for a shaft replacement for this specific motor? Thank you all in advance.
http://www3.towerhobbies.com/cgi-bin...&I=LNCPGJ#tech
Mavs424 is offline Find More Posts by Mavs424
Old Jan 18, 2013, 04:15 AM
stemo99 is offline
Find More Posts by stemo99
stemo99's Avatar
United States, NJ, Pennsville
Joined Feb 2008
I have never seen 4.1 mm shafts until now, but 4mm are readily available. The difference in diameter is .0025 in. which may not matter at all. For length, just cut to whatever size you need, should work. My go to guy for parts is:
http://www.headsuprc.com/servlet/the...fts/Categories
stemo99 is offline Find More Posts by stemo99
Old Jan 18, 2013, 05:00 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I too have not seen 4.1mm shafts listed before this ... plenty of excellent 4.0mm at RCTimer.com ... but no 4.1 - which for them is surprising as they cater for just about all ...
That 0.1mm is significant though ... try running a 3mm in a 3.17mm and yoú'll soon see ...
I would go back to Towerhobbies and quiz them for the replacement shaft ... If that fails - then try and find a Metalworks that maybe can run up a shaft for you ? Hardened steel of course.
There is another thought ... quite a few motors - the shaft IN the motor is different size to the EXTERNAL part of shaft ... i would be inclined to withdraw the old shaft ... get a micro and measure the INTERNAL diameter part ... it may be standard size ... then that's what you go for and ignore the external size by getting suitable adaptor for the new.
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 18, 2013, 09:08 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
It would appear to be, by the specs, "5/32", that the shaft is not metric at all. I would get some 5/32 drill rod, and make a new shaft out of that.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Jan 20, 2013, 05:55 AM
solentlife's Avatar
Joined Jan 2010
Or ... if me ... get a similar motor capable of flying this model with standard metric available anywhere shafts ... for what is likely $20 max ... you could solve the issue once and for all with a more easily serviced solution.
You could in fact improve your model by adding a litttle to the power capability if wanted ...
Nigel
Discussion need help to pick right size motor Charlie Bohlen Power Systems 4 Jan 10, 2013 06:14 PM
Discussion Needing help replacing my ESC DCDetector Power Systems 1 Jan 05, 2013 04:31 PM
Help! How much does the feathering shaft need to be bent to necessitate replacement? B450guy Electric Heli Talk 5 Jan 05, 2013 10:25 AM
Need help replacing shaft on E-Flite motor Troy Power Systems 5 Jul 01, 2005 10:47 PM
Need HELP with determining aileron size zbrubaker Parkflyers 0 Jul 09, 2003 08:59 AM
