Old Jan 17, 2013, 08:02 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
Question
Can I make my motor wires 30"-40" Long?
Can I make the brushless motor wire 30-40" long?
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Jan 17, 2013, 09:02 PM
Joined Dec 2005
Thanks in advance
Old Jan 17, 2013, 09:43 PM
bob93447 is online now
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
I've run with motor wires in excess of 30" long with no problems except for some power loss. If you try to run battery wires that long you'll blow the esc unless you add lots of capacitance.
bob93447 is online now Find More Posts by bob93447
Old Jan 17, 2013, 10:40 PM
Joined Dec 2005
thanks bob
Old Jan 17, 2013, 10:43 PM
Joined Dec 2005
If I am reading right.... If I keep the same quality wire and make the gauge heavier (ex. if 14g then make it 10g) It will help with power loss and keep it to a minimum.
Old Jan 17, 2013, 11:54 PM
Joined Sep 2006
check the blog http://circuitcalculator.com/wordpre...rs-calculation
Larger wires are an issue of weight vs. performance gain. The calculator in the blog lets you make some of those tradeoffs.
Bob
Old Jan 18, 2013, 04:36 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I use copper household stiff wire as my extenders for motor wires. I trade weight for minimum voltage drop and also the wires can be bent permanently to suit installation.
I remove the white outer insulation and separate the individual leads still with their own insulation intact. A single turn of insulation tape at intervals is all needed to tidy them up ... a small blob of Hot glue to tack in place.
Depending on the model - I either solder the ESC wires to the extensions or use bullets ... and bullets at motor end.
So far no problems with this ... one EDF is running 5S to a 3200kv 70mm unit at over 25" extension ... with no discernible difference to when tested without extension.
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 18, 2013, 12:31 PM
Joined Dec 2005
I am not worried about weight. Its a 100" span plane that specs at 20lbs and I all ready built it ready to fly at 14-15Lbs... Dont think Ill be adding 5lbs of wire.
SOoooo. What is the best wire for least amount of either voltage / performance drop?
Old Jan 18, 2013, 06:15 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
What amp draw do you expect? I kinda like Nigel's solution. Simple.
I'd use 12awg in general.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jan 18, 2013, 07:04 PM
solentlife's Avatar
Joined Jan 2010
My usual solid copper is 1.5mm for low power stuff and 2mm for higher draw ..
Basically it all started because my house is being rebuilt and electrics redone ... loads of cable left over. For my high demand 70mm EDF - I use the cable that is supplying main feed to a ring main ... so that is capable of carrying serious load .. probably 2.5mm
For my other - I use cable that is from wiring rooms and is 1.5mm - 2mm ...
I have tested with and without the extensions and i see no discernible drop in power - volts or amps with or without. As I say - I always make sure the extension wire is greater diameter than the ESC leads ... as long as I see that - i don't worry about gauge of wire.
Nigel
Old Jan 27, 2013, 12:00 PM
Joined Dec 2005
Nigel
Still only on the motor side.. the 3 wires... the AC side... not the DC,battery side.. right?
I did the AC side, motor side at 35" on 10 gauge. Did not notice any power loss or performance loss.. works fine. I used high strand count flexible silicon wire. Pulling about 60amps max and 30-40 Continuous.
When I first did it I did the battery side... + & -.... @ 35" even on 10 gauge at 60 amps the wire got warm and motor had problems with timing. The motor side worked fine.
Now what the best way for the motor side wiring I dont know but it worked so.
I would still like to do the best way even if it works because I want it to be as efficient as possible.
Old Jan 29, 2013, 04:25 AM
solentlife's Avatar
Joined Jan 2010
Yes AC side is correct ... I try to leave ESC to Battery side as is to prevent issues.
Nigel
Question How much leeway do I have when choosing a common prop/fuel for a range of engines? murcielago Engines 6 Jan 22, 2013 02:55 AM
Question What do the numbers on the motor mean??? bencookrc Power Systems 6 Jan 20, 2013 12:34 AM
Idea what do winglet/spoiler/fin do for 3D profile. modelerchina 3D Foamies 1 Jan 19, 2013 06:42 PM
Discussion Have any of you guys ordered your EDF's from this vendor? GBLynden Foamy EDFs 1 Jan 16, 2013 03:55 PM
Discussion What batteries do manufacturers (and modders) use in 1:64 cars? fearless_fool Micro Cars 2 Jan 10, 2013 04:47 PM
