Old Jan 17, 2013, 02:10 PM
richos is offline
Find More Posts by richos
richos's Avatar
Joined Mar 2008
New Product
BNF Spectrum/JR DSM2-DMSS compatible REDCON HiBiRD Mini 120mm Quadcopter
Note only sent by EMS so please choose EMS
REDCON HiBiRD Mini 120mm Quadcopter W/O Transmitter- DSM2 Compatible
JR DSM2 Version:
Special Feature: Now you can use your own JR DSM2 transmitters to control this Mini Quadcopter.
Compatible with Spectrum DSM2 Radios: DX6I, DX7, DX8,DSX7,DSX9 DSX11,DSX12
DMSS Version:
compatible with JR DMSS Radios: XG7,XG8,XG11,XG6
Specification:
Body Dimension W*L*H: 100*100*45MM
rotor to rotor: 120mm
Empty Quad Weight: 22g
LIPO Battery Weight : 10g 3.7V/350MA
Body and LIPO Weight : 32g
Input Voltage: 3.7V/350MA
Flight Time: about 10min
Package including:
Main body x 1
DSM2 Board or DMSS Board x1PC (pls choose version in Optional box)
Motors * forward and reverse motor 1 pair each
Propeller* forward and reverse propeller 1 pair each
USB Charging adaptor * 1 PC
LIPO *2 PC
REDCON HI-Bird Testing#1 (11 min 59 sec)
richos is offline Find More Posts by richos
Old Jan 17, 2013, 02:11 PM
richos is offline
richos's Avatar
Joined Mar 2008
Cool
Old Jan 17, 2013, 02:12 PM
richos is offline
richos's Avatar
Joined Mar 2008
Even more Cool
Old Jan 17, 2013, 02:23 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Where can u buy from?
ripmax is offline Find More Posts by ripmax
Old Jan 17, 2013, 02:45 PM
richos is offline
richos's Avatar
Joined Mar 2008
Banggood
http://www.banggood.com/Wholesale-Re...e-p-60967.html
OMGFLY
http://www.omgfly.com/index.php?main...roducts_id=915
Goodluckbuy
http://www.goodluckbuy.com/redcon-hi...ompatible.html
ripmax just Google.... REDCON HiBiRD Mini 120mm Quadcopter
Old Jan 17, 2013, 02:48 PM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Hey whats with the iPhone label on the side of the box? And the name "Recon"? Do tell...
Looks interesting anyway. The legs should protect the motors well.
Can anyone post details of the FC? Is it 6 Axis? Can you fly gyro only? Is tuning possible?
Any advantages over the other DSM2 ladybird FC?
Cheers...
Soma is offline Find More Posts by Soma
Old Jan 17, 2013, 02:51 PM
richos is offline
richos's Avatar
Joined Mar 2008
Thanks deltafly ch And Aliexpress
Old Jan 17, 2013, 04:08 PM
richos is offline
richos's Avatar
Joined Mar 2008
WOW!!!!
Look at this! Look at this!!
And check this pic out guys !
Looks like its got some sort of modular swappable RX board so you can change or swap what RX-TX you want to use.
Looks like the desinger has future proofed the main gyro and ESC-FET board with a 1 gram plug in modular RX board that plugs in to the top of the (gyro and ESC-FET board)
Hay he could even make a futaba 2.4 module to plug in on top of the gyro and ESC-FET board .
Old Jan 18, 2013, 12:43 AM
Soma is offline
Joined Sep 2012
Hey Richos, whats you're relationship to the product?
Do you have any info on my questions above? Mainly interested what tuning and options are possible with the flight controller.
Cheers mate.
Old Jan 18, 2013, 02:40 PM
richos is offline
richos's Avatar
Joined Mar 2008
Cheers mate.
I have no relationship whis this product Soma .
I have the Hudsan x4 and the SYMA X1 , i got them for the UK winter season so i could keep my Tx skills in check over the winter.
Im a DSM2 micro um-umx aircraft flyer and fly a few micro blade choppers indoor over the winter season.
I started to get interested in micro - mini brushed motor quads only 6 weeks ago when i started to look at the (Mini Multirotor RCgroup site) so i got the Hudsan x4 and the SYMA X1 to see what all the excitement was all about . I decided to get a direct drive, and a geared drive proped quad to try out .
And WOW! the Hudsan x4 and the SYMA X1 flew out of the box with no probs (i dont think the x4 and x1 are toys) i class them as hobby grade not toy grade
Now for the down side of the little micro-mini Hudsan x4 and the SYMA X1
The toy grade TX of the little micro-mini Hudsan x4 and the SYMA X1 TOTALLY LET DOWN the x1 and x4 . The resolution of the TX's are Cp.. and i need a separate TX for each quad
I want a micro quad i can bind with my DSM2 DX6i that i use with my micro um-umx aircraft and micro blade micro choppers with good resolution and model memory settings.
Ok ive seen video and heard of the Spektrum DSM2 mQX and the DSM2 ladybird , but heard issues conserning them
And i do like the look of the plug modular swappable RX board that plugs in to the top of the (gyro and ESC-FET board)
I think i might give the DSM2-DMSS REDCON HiBiRD Mini 120mm Quadcopter a go .....
And its cheap
Old Jan 18, 2013, 02:53 PM
Soma is offline
Joined Sep 2012
Thanks Richos! It sounded a bit like you were involved in the project.
I have had a similar search. My main trainer quad at the moment is a V929 with a mQX board. Works really well. I just oldered some (micro JST i think) leads to the mQX board so they plug into the V929 motors the other end.
The V929 is $32 now! I just buy another one now and then for spares. The mQX is better quality but they fly the same.
I did have the first ladybird DSM2 board but it died just when I got it flying properly I still need to send it back to 9iMod.
So this one does look interesting. Keep us posted mate
Old Jan 19, 2013, 10:02 AM
richos is offline
richos's Avatar
Joined Mar 2008
Can someone help open Chinese PDF please
Cheers...
Ive found some PDF manuals for the REDCON HiBiRD Mini 120mm Quadcopter on the net, but i cannot seem too open them .
The PDF manuals are on chinese web sites . so if anyone can open them and post them here i would be most appreciative if someone could help.
The PDF manual might shed a bit more light on the details of the REDCON HiBiRD Mini 120mm Quadcopter.
If anyone could help i would be most appreciative.
iPhone label on the side of the box? i have no idea Soma ????
Old Jan 20, 2013, 03:11 AM
vlad_vy is offline
Find More Posts by vlad_vy
Joined Dec 2011
http://www.himodel.com/manual/HIBIRD_Manual.pdf
vlad_vy is offline Find More Posts by vlad_vy
Old Jan 20, 2013, 10:53 AM
rcmtl is offline
Find More Posts by rcmtl
Joined Mar 2004
From the pic of the main PCB it looks like it has an Accelerometer chip.... then it is a 6 axis? not sure.
rcmtl is offline Find More Posts by rcmtl
For Sale 7 FOOT TRAINER BUDDY BOX CORD FOR SPECTRUM and JR $7 shipped 3drcparts Aircraft - General - Radio Equipment (FS/W) 4 Jan 17, 2013 10:35 AM
For Sale JR RG611B DMSS Receivers for Sale $50 Shipped rthorne Aircraft - General - Radio Equipment (FS/W) 0 Jan 14, 2013 09:06 PM
Sold NEW Clone Spectrum DSM2 AR6100E 2.4G Mini Receiver, V1.6 Winterdd Aircraft - General - Radio Equipment (FS/W) 1 Jan 02, 2013 04:21 PM
Discussion $10 Spectrum 6Ch 2.4ghz RedCon RX Crash_Clark Radios 81 Aug 01, 2011 10:03 AM
For Sale JR 2.4 SPECTRUM R921 9Channel DMS2 -Price Update Flazo Aircraft - General - Radio Equipment (FS/W) 6 Nov 11, 2008 02:53 PM
