Old Jan 17, 2013, 01:44 PM
freddy s is offline
Find More Posts by freddy s
USA, NV, Las Vegas
Joined May 2006
Vertigo II
Would anyone have the CG and control throws for a Vertigo II....Thanks
freddy s is offline Find More Posts by freddy s
Old Jan 17, 2013, 04:18 PM
edh13 is offline
Find More Posts by edh13
edh13's Avatar
United States, AZ, Mesa
Joined May 2003
Carnac the Magnificent says you will soon be visited by a man named Robert who flies this plane...
edh13 is offline Find More Posts by edh13
Old Jan 17, 2013, 04:29 PM
freddy s is offline
USA, NV, Las Vegas
Joined May 2006
I await his benificence and knowledge
Old Jan 17, 2013, 05:44 PM
Fatherof4 is offline
Find More Posts by Fatherof4
Raised on 80's Pattern
Fatherof4's Avatar
Rancho Santa Margarita, CA
Joined May 2006
I just sent Carnac an email.
You will be graced with his presence sooner than later.....
Doug
Fatherof4 is offline Find More Posts by Fatherof4
Old Jan 17, 2013, 06:06 PM
freddy s is offline
USA, NV, Las Vegas
Joined May 2006
Most gracious of you
Old Jan 17, 2013, 06:17 PM
Vertigo II is offline
Find More Posts by Vertigo II
West Coast Director, CPA
Vertigo II's Avatar
Simi Valley, California
Joined Jan 2010
Carnac is here......
Freddy,
I am happy to help you out. I'll dig up my set-up sheet tonight and pass the info to you.
Please post a pic of your Vertigo.
-Robert Fish
Vertigo II is offline Find More Posts by Vertigo II
Old Jan 17, 2013, 06:36 PM
edh13 is offline
edh13's Avatar
Joined May 2003
Carnac the Magnificent says you will soon be delivered the knowledge you desire. And useth this knowledge faithfully for the Vertigo of Robert is the badd-ass-ed vertigo of all...
Old Jan 17, 2013, 07:00 PM
freddy s is offline
USA, NV, Las Vegas
Joined May 2006
I am truly humbled in your presence
Old Jan 17, 2013, 08:41 PM
Vertigo II's Avatar
Joined Jan 2010
Most people are.
Here's your info. Let me know if I may be of further assistance.
-Robert
Old Jan 18, 2013, 05:30 PM
freddy s is offline
USA, NV, Las Vegas
Joined May 2006
I received your spec sheet,am very appreciative but a bit confused on the measurements shown.Are they in degrees because the rudder spec shows 100.thats where i am confused(not hard to do).I may have posted a picture of the plane awhile back.Found it in a garage in SoCal.Its set up for fixed gear and looks pretty good structually.Thinking of just cleaning it up and seeing how it works out before doing anything extensive to it(if it survives).Thanks very much for your help,,,,Freddy
Old Jan 18, 2013, 06:04 PM
patternpilot1 is offline
Find More Posts by patternpilot1
Fly CPA
patternpilot1's Avatar
USA, TN, Knoxville
Freedy,
Don't feel bad.. I'm confused by the CG numbers?
I have a New fuse and Robert hooked me up with cores.
cpa#2
patternpilot1 is offline Find More Posts by patternpilot1
Old Jan 18, 2013, 08:03 PM
Kevin2035 is offline
Find More Posts by Kevin2035
Kevin S. Gribben
Kevin2035's Avatar
Joined Mar 2011
When i grow up im gunna have me one of them Vertigo planes.
Kevin2035 is offline Find More Posts by Kevin2035
Old Jan 19, 2013, 12:21 AM
Vertigo II's Avatar
Joined Jan 2010
Freddy,
Glad to be of help. Sorry for the confusion, I just kind of threw the sheet together, it needs some clean-up. The throws (Aileron/Elevator) are in degrees. I put the rudder info in the wrong column. Just set the rudder for all you can get on high rate and use the for stall turns, etc. Set the low rate to 60-70% initially, then tweak it so 90% stick movement will sustain a knife edge. This will give you a selection to keep your point rolls, knife edge, and rudder corrections smooth.
I use Futaba equipment, so the expo will be "+" if your fly JR/Spektrum. Just make sure it works the right way to avoid any unpleasant surprises. Overall, be prepared for the best flying airplane that you will ever have the privilege of piloting!
If you are interested, shoot me a PM with your E-Mail, and I will send you a PDF of the original plans.
-Robert
Old Jan 19, 2013, 12:30 AM
Vertigo II's Avatar
Joined Jan 2010
Check the wing incidence!!!
Before you fly, grab a Robart incidence meter or equivalent and check the wing/stab incidence! There is a big error in the wing saddle,and if the stab is aligned to the correct incidence (there were alignment marks molded into the fuse), you will have about 2 degrees negative incidence (wing). Not cool, requires about 3/8" up elevator to hold level flight! I found that out the hard way on my first Vertigo. If necessary, shim down the trailing edge of the wing. Better to find out on the bench than in the air.
-Robert
Old Jan 19, 2013, 11:51 AM
freddy s is offline
USA, NV, Las Vegas
Joined May 2006
Robert,thanks for the help it will go a long way to getting this in the air.Its my first pattern plane,not looking to compete just want to fly a sweet plane like this.Thanks,,,Freddy
Discussion Hyperion Sniper X II Owners Thread wolfewinde 3D Foamies 2 Jan 17, 2013 05:47 PM
Sold NIB Spirit E II needs a good home Patchitagain Aircraft - Sailplanes (FS/W) 2 Jan 15, 2013 06:59 PM
Discussion New engine for the Vertigo II Vertigo II Classic Pattern Flying 12 Feb 13, 2012 09:06 PM
Cool Vertigo II Graphics Vertigo II Classic Pattern Flying 21 Aug 09, 2011 02:00 PM
Discussion Vertigo II in MA magazine 1320fastback Classic Pattern Flying 1 Jun 23, 2011 09:25 PM
