Old Jan 17, 2013, 12:06 PM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
flight time and power
Hello,i have buid a new small airplane(aero-soarer design) around a 20mah lipo and 4mm motor with gearbox.The model fly very well for 12 minutes.I use a 60mm prop with 4:5:1 gear ratio.How i can calculate the Ampere that take my motor setup?Thanks
I thing around 90ma it is right?
Can i use a 10mah lipo?
Ivan2280 is offline Find More Posts by Ivan2280
Old Jan 17, 2013, 01:08 PM
XXXmags is offline
Find More Posts by XXXmags
Push
XXXmags's Avatar
20ma.h is your battery capacity. Covert that over to milliamps per minute and divide it by the flight time.
(20ma.h)*(60min/h) = 1200 ma.min
Since lipos don't get fully discharged, and say 80% of total capacity was used, this decreases the usable size of the battery to:
1200 ma.min*0.8 = 960 a.min
The flight time was 12 minutes so:
(960 a.min)/12min = 80 ma
And that's the average current consumption of your motor. An equation to find the current consumption of any motor based on battery capacity and flight time would be:
Note: 60*0.8 = 48
(C*48)/T = A
Where:
C = Battery capacity in ma.h
T = Flight time in minutes
A = Motor current in milliamps
Google search works as a good calculator. Stick in the Equation defining A and substitute the variables in the search menu and it will give you the result.
Hope that helped!
XXXmags is offline Find More Posts by XXXmags
Old Jan 17, 2013, 01:14 PM
Ivan2280 is offline
ITALY
Joined Sep 2004
Thanks!!!
Old Jan 17, 2013, 06:41 PM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i always use the mah as equal to 60 minutes, then divide by your flight time. multiply the mah by the result of your first number. 60/12=5 so you used your battery at 5C or 100ma current draw. however, your cell likely had some mah remaining when your LVC kicked in so its likely a small % less than 100 ma.
derk is online now Find More Posts by derk
Discussion 20 min flight time... setup fiduzen Multirotor Talk 33 Feb 10, 2015 01:28 PM
Discussion plane with the longest flight time barneys Electric Plane Talk 28 Jan 10, 2015 04:58 AM
Help! 3 cell to 4 cell flight time Mr Big Head Batteries and Chargers 1 Jan 14, 2013 04:50 AM
Discussion Syma S111G Lost Half Its Flight Time Spirittoo Beginner Training Area (Heli-Electric) 14 Jan 09, 2013 12:38 PM
Discussion First time pilot - Super Cub Maiden Flight EscherSketcher Beginner Training Area (Aircraft-Electric) 10 Jan 06, 2013 02:11 AM
