Old Jan 17, 2013, 07:36 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Battery in 787 swollen from overheating, official says
Ugh: http://www.foxnews.com/world/2013/01...official-says/ .
http://www.cnbc.com/id/100385850
jrb is offline Find More Posts by jrb
Old Jan 17, 2013, 07:52 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
Possibly they were using HK equipment.
The Tug is offline Find More Posts by The Tug
Old Jan 17, 2013, 07:59 AM
WCB is offline
WCB
Find More Posts by WCB
WCB
NC
Joined Aug 2005
I hear Boeing has been attempting to contact HK ''customer service.''
WCB is offline Find More Posts by WCB
Old Jan 17, 2013, 08:06 AM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
this the 3rd battery issue they have had im betting a bad batch or some one ordered from HK lol
but really seems like a bad batch of batteries
any one know what chemistry they are using?
DERP its in the story
they are Li-Ion huh im going to say its a bad batch OR there charging circuit sucks
Elios000 is offline Find More Posts by Elios000
Old Jan 17, 2013, 08:10 AM
The Tug is offline
Barbados
Joined Jan 2011
i read in the news Lithium Ion
Old Jan 17, 2013, 08:12 AM
The Tug is offline
Barbados
Joined Jan 2011
looks like they were in a cannister to contain the fire,they must be reading RC Groups as well.
Old Jan 17, 2013, 08:37 AM
Beckler is online now
Find More Posts by Beckler
Beckler's Avatar
Canada
Joined Apr 2008
How big are the servos on the 787 anyway, that they would draw that much current...
Beckler is online now Find More Posts by Beckler
Old Jan 17, 2013, 08:43 AM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Sounds like several of us should submit a resume to Boeing. LOL
My guess is they under sized the pack or are charging it too fast over a bad design or a bad batch of cells. That would not slip through QA...or would it?
Rick
rampman is online now Find More Posts by rampman
Old Jan 17, 2013, 09:12 AM
bzfrank is offline
Find More Posts by bzfrank
4.2V of pure Kraut power
bzfrank's Avatar
Germany
Joined Nov 2006
The 787 has two rather large Li-Ion batteries, one in the forward EE compartment, one in the rear with the APU. Since the plane does not use engine bleed air for air conditioning / heating / de-icing (except for the engines themself), but does almost everything electric the needed power levels are rather high. The APU has two 225 kVA generators and the batteries have to compensate in case of failure.
The batteries are made by Yuasa:
http://www.gsyuasa-lp.com/aviation-lithium-batteries
Spec sheets: http://www.s399157097.onlinehome.us/...s/LVP10-65.pdf
From their spec sheet they seem to use a lithium cobalt cathode based cell chemistry. I don't know about the electrolyte but I suspect it to be lithium hexafluorophosphate based. (Rather similar to lipos for hobby purposes btw Good energy density but its comes with a price...)
The trouble - so I believe - is that this type of battery chemistry is not known to be self limiting in case of failure. In case of separator failure, overcharging or overheating it can sustain a thermal runaway resulting in the self destruction of the battery with fire and (toxic) smoke.
In hindsight maybe it would have been better if they had used LiFePO4/ LiFeYPO4 batteries. Maybe not quite the energy density but safer.
bzfrank is offline Find More Posts by bzfrank
Old Jan 17, 2013, 09:15 AM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
Originally Posted by jrb View Post
Ugh:
LOL
Hmm. This is making me rethink my commute. I drive a Nissan Leaf, so I'm sitting on about 500 pounds of LiIon batteries. The car has seat warmers, but now I'm wondering if they could go into turbo mode. Why didn't someone warn me that Lipos could go up in flames before I bought this car?
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Jan 17, 2013, 09:17 AM
Elios000 is offline
Elios000's Avatar
Joined Jul 2010
using APUs for primary power where have i heard that be for...
OH RIGHT the shuttle and they had all kinds of issues with the APUs (mind you Shuttles APUs ran on Hydrazine lol) but using an APU as primary power seems to be asking for trouble
not sure whats worse hydrazine fire or Li fire?
yes i know the 787s APU runs on JP-1
from that site that was linked
[B]attery management electronics which guarantees multiple levels of safety features.
lol sounds like the safety features need some bugs worked out... Boeing must be LIVID
Old Jan 17, 2013, 10:08 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The 787 has twice the number of generators as traditional designs and they're double the wattage of those on a 777. Each engine has 2X 250kW generators, as does the APU, for a total of 6 generators. The total of four generators on the engines are the primary power source and provide a lot of redundancy.
The battery that caught fire in Boston was the starter battery for the APU.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jan 17, 2013, 10:57 AM
bzfrank is offline
bzfrank's Avatar
Germany
Joined Nov 2006
The batteries in the 787 are backup power, thats right.
But this is not a just puffed battery with a little discoloration of its paint. If the battery company say this is just "swollen" I would not want to see what a burnt one looks like:
http://www.nycaviation.com/2013/01/n...g-787-battery/
In case of a fire in the forward EE compartment no amount backup power will help you. One of the Common Core Resource cabinets is a few inches away (the "brain" of the plane). The SOP in this case will be to land as fast as possible.
Old Jan 17, 2013, 10:58 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Did Boeing send (1) a photo? (2) a video? (3) a signed letter from "mother?"
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Jan 17, 2013, 12:53 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
I told them to go with Turnigy from Hong Kong.
Did they listen... ?
The results say they didn't !
sparklet is offline Find More Posts by sparklet
Discussion FBI, DEA thwart terror plot in U.S. involving Iran, officials say Michael in Toronto Life, The Universe, and Politics 80 Oct 14, 2011 07:28 PM
Discussion New Battery Technology - Scientists say paper battery could be in the works Bombay Batteries and Chargers 10 Dec 09, 2009 07:04 AM
Discussion Official Announcement from AirThunder Li-Poly Battery, LLC barryhu Batteries and Chargers 2 Nov 22, 2007 01:02 AM
Discussion uce-bestbuy, site says they are in Calif but they ship from China ???? rcer2007 Electric Plane Talk 8 Sep 19, 2007 08:56 PM
Swollen LiPo 1500Mah Battery. GeorgeZilla Pusher Prop Jet Models 6 Jun 12, 2005 07:34 PM
