Old Jan 23, 2013, 08:18 AM
Oenta is offline
Find More Posts by Oenta
Oenta's Avatar
Netherlands
Joined Mar 2011
As posted by james from horizon
Hi Guys,
The gyro gain is adjustable for the tail.
It uses channel 5 (gear channel).
For DX7s, DX8, and DX18 radios
Gyro menu off = 0% gain on channel 5. This is the stock gain and the helicopter will fly just fine here.
Gyro menu on
0% = stock gain.
Increasing the number will increase the gyro gain. Range: 0% to 100%
Decreasing the number decreases the gain. Range: -100% to 0%
For DX6i and DX7/SE radios
The neutral gain point changes from 0% to 50%
Gyro menu off = 50% gain on channel 5. This is the stock gain and the helicopter will fly just fine here.
Gyro menu on
50% = stock gain.
Increasing the number will increase the gyro gain. Range: 50% to 100%
Decreasing the number decreases the gain. Range: 0% to 50%
I hope this clarifies this for you guys.
James
__________________
Horizon Hobby Product Development
Oenta is offline Find More Posts by Oenta
Old Jan 23, 2013, 09:35 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Adjustable gain from the TX, Fantastic!!!!
I don't like having to use the sticks and blinking leds on the 130X.
jhroof is offline Find More Posts by jhroof
Old Jan 23, 2013, 09:40 AM
CaptJac is offline
Find More Posts by CaptJac
Rotor Controller
CaptJac's Avatar
Aachen Germany
Joined Dec 2007
Hi Guys,
The gyro gain is adjustable for the tail. It uses channel 5 (gear channel).
For DX7s, DX8, and DX18 radios - Gyro menu off = 0% gain on channel 5.
This is the stock gain and the helicopter will fly just fine here. Gyro menu on
0% = stock gain. Increasing the number will increase the gyro gain.
Range: 0% to 100% - decreasing the number decreases the gain.
Range: -100% to 0%
Just back from a test flight with 2 more batteries - did everything by the "book" and ABSOLUTELY NO DIFFERENCE in tail-wag no matter if the gyro gain is 0 or 100 or anything in between. Won't rush to judgement if it just my heli or me - but I'll be watching this forum with interest to see what the findings of other BL mCPx are doing - or not doing.
CaptJac is offline Find More Posts by CaptJac
Old Jan 23, 2013, 10:12 AM
WI_Hedgehog is offline
Find More Posts by WI_Hedgehog
Crashing Spectacularly daily
WI_Hedgehog's Avatar
United States, WI, Milwaukee
Joined Jan 2013
Lose the charger
Since this is BNF only and targeted at the experienced pilot, please tell Marketing they can position themselves better against Walkera by not including a non-balancing battery charger and by using a battery with balancing connector.
You have a top-notch heli at 2.5x the price of Walkera's new model--for that price consumers shouldn't have to make any mods to bring a down-graded battery system up to standard, and at this level we all own multiple high-end chargers. You spent a lot on R&D, finish polishing the product, and for heaven's sake, put a good looking canopy on it. Finally, while your manuals are good, kick it up to "great" by including the gyro settings and other details; manuals are marketing tools, people download them and base purchases on them.
WI_Hedgehog is offline Find More Posts by WI_Hedgehog
Old Jan 23, 2013, 10:23 AM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Come on - that would mean HH products had to go through QA and testing! hahahaa
They basically just send out everything and keep their fingers crossed that it all works.
TurboRacer is offline Find More Posts by TurboRacer
Old Jan 23, 2013, 10:41 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
The battery does have a balance cable and needs no mods to charge with a regular balancer, nor is the battery a down grade for micro heli's.
What is the Walkera heli that you speak of that that is 2.5 times lower than this heli? As far as I know (I have owned most walkera models) they have nothing similar.
The manuals do sound like they could use an extra page though
indoorheli is offline Find More Posts by indoorheli
Old Jan 23, 2013, 10:46 AM
CaptJac is offline
Rotor Controller
CaptJac's Avatar
Aachen Germany
Joined Dec 2007
I sure can an AGREE with that one!! Their charger is a JOKE! It blinks for 2 hours and you have no idea what it is doing. I finally gave up with it and made an adapter for my charger that I could charge and balance the battery with their ONE connector. PITA !
Old Jan 23, 2013, 11:47 AM
Joined Jan 2013
Your battery has a balance connector??? No connector would be the downgrade, obviously S2 is a huge improvement.
Walkera Super CP, $100 BNF, and their TX are inexpensive.
Before you blow a feathering spindle saying it can't perform 3-D as well as the BL, realize the price isn't close either, it does good 3-D, and should be priced around $150-$175 U.S.D. based on abilities.
With that said, the BL is revolutionary, as is the Super CP.
SCP + Devo 10 is $250
BL + DX8 is $580
So you can buy a SCP + TX + 3 backup SCPs + $30 in parts vs. one BL + TX, which is why a polished product from Horizon is important.
Old Jan 23, 2013, 11:57 AM
indoorheli's Avatar
Joined Sep 2007
Yes every single battery that is a 2s from Blade has a balance connector, take a close look at the plug. It takes away unneeded weight from the battery for redundant plugs. Like most heli batteries, you need to buy or make a plug to connect it to your higher grade charger and balance them.
On the Super CP, that is just another version of the miniCP.... It is not really new and not much different than the mini at all.
The super cp is more like the standard mcpx, same goes for the miniCP which actually does have a better gyro than the mcpx. The mini CP and super are a good value for what they are, but so is a mcpx that can be had for near the same price.
Also no you cant compare brushed to brushless or say the super CP is revolutionary, it is really the same product as before with a few (very minor) tweaks
On the radios, yes Walkera does offer good value. But having owned the devo8, 8s and 12s I can say with certainty that they are not built as nicely as the dx8 or the dx18 or with the actual backing of a company if issues arise. The really odd thing about the Walkera tx line up is each radio always seems to be missing a few switches and such, though the color touch screens are nice and I am not sure while all brands of radios are not offering that yet
Though I am not really curious about their tx offerings, only if they had something new and comparable to this new edition to the Blade line up, which they apparently do not
Old Jan 23, 2013, 01:41 PM
pela is offline
Find More Posts by pela
pela's Avatar
Lodose, Sweden
Joined Aug 2004
This is my experience as well, I went from -90 to +90 and no difference what so ever..
pela is offline Find More Posts by pela
Old Jan 23, 2013, 03:08 PM
Joined Jan 2013
That's like saying the BL is just another version, nothing to look at, please move along...but it's not.
The Super CP has servo control on the main board, so is much lighter & servo replacement is cheap (which is good because they strip often). Gyro is better, fly time is up, price is way down.
The BL has great integration, better gyro, more performance and the other benefits of brushless, plus higher quality and better support.
So can you compare a fleet of SCPs to one BL...sure, look at price vs. performance. What total package does each offer and how good is it?
Old Jan 23, 2013, 03:37 PM
CaptJac is offline
Rotor Controller
CaptJac's Avatar
Aachen Germany
Joined Dec 2007
This is starting to have a familiar ring - the first buyers identifying what appears as a glitch - HorizonHobby saying everything is fine. The blade holders flying off the first mCPx was blamed on everything but the truth. Intermittent tail-wag is a glitch. If the BL mCPx has a design problem it should be identified - not justified. There is more than one player on this playing field. Lets make sure we are getting what we are paying for and not what HorizonHobby says we are paying for.
Old Jan 23, 2013, 03:40 PM
indoorheli's Avatar
Joined Sep 2007
No it is not like that at all, and the brushless mcpx is really an entirely new heli.
On the other hand Walkera does this all the time. They really only have one 100 size heli under 5 or so names with different features and price points. It isnt really a Super CP it is a genius v5...economy version. Same with their 120 line up...
The Super CP is nothing more than a lower price point miniCP, without Telemetry or "smart" servos and comes with updated gyro software and a genius motor in it so the flights last longer. The servos are not only made to be cheap replacements for the consumers, but made to be cheap to manufacture.
The brushless mcpx has many physical changes along with a completely new power plant and no i just dont see the comparison you are trying to make, it is really apples and oranges. Price vs performance ~ 2s and brushless is just incomparable to a 1s economy version Super CP.
It is similar to trying to compare a 120d02s to a 130x, which having owned multiples of each can say they do not fly remotely similar.
I think it more sounds like non complete documentation, so the end users are not getting access to the gyro functionality. It probably is something simple being left out for gyro control programming. Since it is setup as 0 as standard something on setup could differ to
Old Jan 23, 2013, 04:59 PM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
I just received word that the mCP X BL began shipping today to HCP dealers in the US.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Jan 23, 2013, 05:12 PM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
I think I'll be holding off on my purchase until these issues are answered...
Seems they get avoided by the people whom should know and answer.
Billz_01 is offline Find More Posts by Billz_01
Sold Blade MCPx KIDGLOVES00 Aircraft - Electric - Helis (FS/W) 2 Jan 09, 2013 06:17 PM
Sold Reduced -- Blade MCPX Version 2 - 90.00 shipped Roly72 Aircraft - Electric - Helis (FS/W) 3 Jan 05, 2013 10:22 AM
Wanted Blade mcpx batteries and parts xdbrix Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 04, 2013 11:47 AM
Sold blade mcpx v2 with extras forsale or trade. Wildcat29 Aircraft - Electric - Helis (FS/W) 0 Jan 04, 2013 01:52 AM
For Sale Upgraded Blade MCPx - Upgraded Blade MCPx - $160 Shipped Sl0flyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2012 09:21 AM
