Old Feb 26, 2013, 08:27 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
The nice thing about wing fences is that they are quick to fabricate and then just stick them on with hot glue to do a test fly to see if they solve your control issues.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Mar 26, 2015, 12:02 AM
HaventFlownSince2014 is online now
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am about to put this model together for SEFF, can you share what your power setup was please?
HaventFlownSince2014 is online now Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Mar 26, 2015, 11:00 PM
guitarcher is online now
Find More Posts by guitarcher
Living on the Dark Side.
guitarcher's Avatar
Australia, QLD, Maryborough
Joined Jan 2013
Answer and recent flight report.
The original power setup was 28-30 motor and 3S 2200mAh LiPo.
After the initial tip stalling problems the wing was relegated the a dark and dusty shelf in my workshop. It saw the light of day again a couple of months ago and underwent some surgery.
To decrease weight I moved the motor as far forward as I could get it. I then hacked into the nose of the pod to install a shelf for a 1300mAh battery. This resulted in reducing the weight from 850gms to 750gms. Well worth the effort in my opinion.
By flying with about 1mm downtrim on the flaps the tendency to tip stall is greatly reduced even at very high bank angles as long as a bit of air speed is maintained.
Flap deployment appears to be pitch neutral and can greatly increase lift. I look forward to more flying time with this wing in the near future.
guitarcher is online now Find More Posts by guitarcher
Old Mar 29, 2015, 01:25 AM
USA, GA, Atlanta
Joined Nov 2008
Thanks! What prop are you running?
Old Mar 29, 2015, 05:04 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Fences will reduce the glide because they increase induced drag at all speeds. Vortilons at the same position that miniphase mentioned will do almost the same job without making any induced drag until very near the stall speed. A strip of foam mounting tape about 1/8 inch wide and 1/2" long applied to the lower surface as shown here should reduce the tendency to spin a lot. Most full scale airplanes with swept wings use one or more of these to tailor the stall characteristics or some other stall delaying device. The beauty of vortilons is that they are easy to move to find the best place for them.
--------/V\
----(^^)---(^^) --Norm
Originally Posted by miniphase View Post
They help prevent spanwise migration of the air flow....ie help they stop the airflow moving along the wing rather than across it
I think the general concensus is to put them in line with the elevon break, they can be made out of card or plastic and taped into position
info here- http://www.b2streamlines.com/WingFences.pdf
and here- http://en.wikipedia.org/wiki/Wing_fence
aim for this kind of arrangement....
nmasters is online now Find More Posts by nmasters
Old Mar 29, 2015, 06:25 PM
guitarcher's Avatar
Joined Jan 2013
8" x 6" folding prop.
Old Mar 29, 2015, 06:34 PM
guitarcher's Avatar
Joined Jan 2013
--------/V\
Thanks for the extra science Norm. Vortilons sound easy enough to have a go at.
Discussion Topsoaring manta ray flying wing, help wanted guitarcher Flying Wings 1 Jan 16, 2013 03:42 AM
Sold Manta Ray Flying Wing 2M Electric Joe Pierson Aircraft - Sailplanes (FS/W) 10 Jun 08, 2012 11:59 PM
Cool Festo Air Ray... manta ray blimp Accu157 Blimps 2 Nov 09, 2008 09:14 AM
Miss 2 and the spiral dive of death! Pat Daily Parkflyers 4 May 05, 2002 10:17 AM
Flash! SR's first Cutie prototype does a spiral dive into contrete from 150' ! Larry @ SR Electric Plane Talk 29 Jun 20, 2001 10:17 AM
