Old Jan 17, 2013, 12:39 AM
SilentHunter is offline
Find More Posts by SilentHunter
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Question
What size pipe?
Where to get a single wall, simple pipe sized for a Wren44 or P-60 size turbine? I need a 17" section minimum. I assume they would be close to the same diameter for these two engines? Whats the recommended diameters anyway BTW? I'm assuming they are about the same... Is it the same diam as the turbine wheel?
I already have an outer wall, I need an inner to complete my pipe.
Also where are fiberglass bypass sections for these sized engine?
Thanks for your help!
SilentHunter is offline Find More Posts by SilentHunter
Old Jan 17, 2013, 06:58 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
If the Wren Pipe won't work for you... contact Tamjets. They make custom pipes.
As far as a bypass... I'm not sure there is one for the Wren 44. Check with BVM on that.
Dr Honda is offline Find More Posts by Dr Honda
Old Jan 17, 2013, 10:49 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hummm..what ya buildin???
Old Jan 18, 2013, 05:23 PM
Joined Aug 2003
fly fly f-100 I think the p-60 ideally is one notch too big, but probably safely do-able. The 44 is perfect though and I really want that one.
I can make my own bypass, thanks for the idea though
Old Jan 23, 2013, 05:06 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
hell a p20 would fly that thing..Ha..whats the weight now
Larry wolf has pipes for wren 44
Old Feb 01, 2013, 02:13 PM
yakhakker is offline
Find More Posts by yakhakker
still trying to get it right
yakhakker's Avatar
Belgium, Région wallonne, Tournai
Joined Feb 2009
If you don't have luck with what has already been put up on here then contact mickreevesmodels.co.uk in the UK he does custom ones at a good price.
yakhakker is offline Find More Posts by yakhakker
Old Feb 02, 2013, 01:33 PM
joeflier is offline
Find More Posts by joeflier
joeflier's Avatar
United States, MI, Plymouth
Joined Jan 2005
Wren sells a single wall pipe made for the 44. You can shorten it to whatever length you need without affecting performance. Check Wren USA's website for details.
Joe
joeflier is offline Find More Posts by joeflier
Old Feb 05, 2013, 06:44 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
You can do it two diffrent ways... either fly it as a foamy, scale like speeds with a Kolibri T25 rear mounted, or reinforce and glass it properly and jam in any larger engine. I think the MW44 drops inbetween the chairs here... to heavy for tailmount and too little power to fly it if glassed in a proper way to hold up for the heavier load.
Still there are better choices then a P60 which is the most inefficiant engine RCJI have ever tested.
henke is online now Find More Posts by henke
Old Feb 12, 2013, 04:54 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
im sorry... But as the owner of the same model... This is not a very good idea. Putting a P60 in that thing would garrentee that the wings snap right off. I can see the wing tips wanting to touch each other on a gentle pull out. At high speeds the wings will flutter to no end. The wings would need to be reinforced with CF and sheeted and glassed.
The best idea is to put a T-25 in the rear as Henke mentioned.
vettster is offline Find More Posts by vettster
For Sale 40-46 size Header & Pipe redball8 Aircraft - Fuel - Engines and Accessories (FS/W) 16 Mar 03, 2012 07:48 PM
Sold Complete (.60-.90 engine size) tuned pipe setup(everything is here) Only $45.00 tyd 540RCflyer Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 01, 2012 02:10 PM
For Sale Complete (.60-.90 engine size) tuned pipe setup(everything is here) Only $45.00 tyd 540RCflyer Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 25, 2012 08:53 AM
Discussion What size tuned pipe for a .61? cannondale1974 Fuel Plane Talk 3 May 12, 2011 11:01 PM
