Old Jan 16, 2013, 10:35 PM
BigRob1823 is offline
Find More Posts by BigRob1823
Joined Jan 2013
I need help....im a noob doublehorse 9053 battery question
hi there.....im new to this whole thing...i recently ordered the Duratrax Onyx 245 DUAL charger with built in balancing. I also want to buy new batterys for the 9053 heli cause they suck. I dont have skill in soder that deans adapter on the heli. If i go with
Minimum Capacity: 1500mAh
Configuration: 2S1P / 7.4v / 2Cell
Constant Discharge: 25C
Peak Discharge (10sec): 35C
Pack Weight: 88g
Pack Size: 80 x 34 x 18mm
Charge Plug: JST-XH
Discharge plug: JST
will this battery plug into that onyx charger with no problems? do i need special adaptor? also will this battery plug into the stock 9053 heli thx
BigRob1823 is offline Find More Posts by BigRob1823
Old Jan 16, 2013, 10:42 PM
Joined Jan 2013
the battery is from turnigy and hobbyking.com
Old Jan 16, 2013, 11:51 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
It comes with the needed adapters. Your battery should plug right in.
JST-XH connector is the standard charging connector on most LiPo's.
I can't imagine a charger that costs over $100 would not include
everything you need
It looks like an awesome unit, and will pay for itself over time with increased
battery life, due to more precise charging and matching cycles.
It looks like the stock pack is 1300, and if you don't want to fry your
motors, I would stay close to that. 1500 is probably the max.
Plus, LiPo packs give your helicopter slightly more power due to lower internal
resistance. Keep your flights under 6 minutes for maximum battery and
motor life.
The only way to fly continuously with brushed helis is to own a fleet.
Otherwise you spend a bunch of time letting them cool down.
A good hobby grade heli with a brushless motor will fly pretty much
non-stop. At least my HK250GT will anyway.
Steve_ is offline Find More Posts by Steve_
Question Double Horse 9053 Battery help... ckanroh Coaxial Helicopters 5 Jan 02, 2013 10:44 AM
Question Im a noob, and I have many questions... Also need some help 10switch Multirotor Talk 10 Oct 08, 2012 08:54 PM
Discussion last help needed please!! battery question help!!! jasperchris2007 Racing Boats - Electric 12 Sep 21, 2012 02:12 PM
Help! Im so confused!! noob quad help. jabu32 Multirotor Talk 63 Jul 10, 2012 05:53 AM
Discussion I need help. Volitation 9053 Battery upgrade tloker Electric Heli Talk 0 Jan 06, 2012 04:08 PM
